I am not sure if this is intended or bug,
When building the image for Nanopi duo2 I cannot add kvm.
This worked before so I guess that this is regression.
I get this search result for kvm in the build process:
┌──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────── Search Results ────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┐
  │ Symbol: KVM [=KVM]        │
  │ Type  : unknown        │
  │ Symbol: DRM_I915_GVT_KVMGT [=n]        │
  │ Type  : tristate        │
  │ Defined at drivers/gpu/drm/i915/Kconfig:122        │
  │   Prompt: Enable KVM/VFIO support for Intel GVT-g        │
  │   Depends on: HAS_IOMEM [=y] && DRM_I915_GVT [=n] && KVM && VFIO_MDEV [=n] && VFIO_MDEV_DEVICE [=n]        │
  │   Location:        │
  │     -> Device Drivers        │
  │ (1)   -> Graphics support        │
  │         -> Intel 8xx/9xx/G3x/G4x/HD Graphics (DRM_I915 [=n])        │
  │           -> Enable Intel GVT-g graphics virtualization host support (DRM_I915_GVT [=n])        │
  │ Symbol: KVM_GUEST [=KVM_GUEST]        │
  │ Type  : unknown        │
  │ Symbol: PTP_1588_CLOCK_KVM [=n]        │
  │ Type  : tristate        │
  │ Defined at drivers/ptp/Kconfig:106        │
  │   Prompt: KVM virtual PTP clock        │
  │   Depends on: PTP_1588_CLOCK [=y] && KVM_GUEST && X86        │
  │   Location:        │
  │ (2)   -> PTP clock support
Edited by Guy
Info
