Installed next cloud on orange pi 3, it shows that it's running at my local address and port 443, when I enter that it says the requested url was not found on this server
Next cloud installed but when I enter my local address as it says on softy it give me not found error, tried http and https, idk what's the problem, also I get an error when I run sudo apt-get upgrade, image included
18 hours ago, markonjak said:
Here's the link :
/dev/loop1 253M 253M  0  100%   /snap/nextcloud/22408
Thank you.  It looks like it is a SNAP install. Ubuntu's NC-Snap is known to be quiet reliable.   Are you familiar with Ubuntu Snap?   You can try to uninstall und re-install it yourself.
Yeah i found out that you can install it with snap after i installed it with softy, but idk how to remove nextcloud that i installed from softy, i type sudo dpkg --list and nextcloud isn't listed i only see some nextcloud files in thunar file manager, do you know if i can remove nextcloud, btw now when i enter the ip and port that softy is showing for nextcloud i get to the activation page where i see usernames and two codes listed but when i enter the url where i can sign in it doesn't wanna connect
Softy only supports install.
I think Snao is the better way for NC.
Play around with ur install, take notes, once it fits ur needs. Flash the SDcard, customize it. Make a backup and enjoy
// sent from mobile phone //
So i can't remove it?, unless i delete it's files from file manager or reflash the os on the sd card but then i would have a lot of work, what if i install it with snap, will the 2 nextcloud installs disturb each other, what do you recommend me to do?
Ok i reinstalled the os and everything, didn't take me that much time, i installed nextcloud with snap, but when i enter https://my_ip:443 or 80 or http:// it says can't connect to server, why this again?, i also checked with sudo snap services nextcloud if it's enabled and it says yes
Posted (edited)
Softy, Igor usually just calls the install-script of the project from Github, so, there is sometimes on the project website a how-to-uninstall.
Search for "NextCloud", so you see the source: https://github.com/armbian/config/blob/master/debian-software
Did you install a SNAP for ARM?
Did you reboot?
SNAP install on ARM: https://technicallyinformed.com/install-nextcloud-on-raspberry-pi-using-snap/     or in your favorite search-engine look for: rpi snap nextcloud install
Edit: I almost forgot the project of @nachoparker  https://github.com/nextcloud/nextcloudpi   this maybe also interesting for you.
Edited by Tido
What's the password to access this website?
On 8/9/2020 at 11:06 PM, Tido said:
Also because the snap install didn't work i followed a different guide for install not using snap, but i'm gonna try the guide for snap install you recommended me, i also get this error now because the previous guide said to add this repository, do i just remove this repository from the list and then i will be able to update?
Posted (edited)
I guess this guy has done some changes and by accident.. I hope he is going to fix that soon.  Even the google Cache is already gone :(
Sure, remove it and then
sudo apt update && dist-upgrade
From your profile I cannot tell what language you speak, but maybe with google-translate:  https://curius.de/blog/13-betriebssysteme/open-source/446-exkurs-nextcloud-als-snap-installieren
Edited by Tido
