Hi,
I have a Amlogix S905 with Armbian and The Home Assistant running on Docker.
My problem is... i dont have any free space :( ... i have a simple instalation of Home assistant and i delete all the logs...
See the picture and help me if you can :(
How can i free space the storage?
@ - Sorry for my porr english.
Thanks,
But this file isn't were is installed all the OS + Docker + Home Assistant?
I´am afraid delete the file and.... lost all my configuration :(
Is any way to enter inside of this "partition" and delete unwanted files?
I dont have any backup of my config :(:(:(:( I dont want lost all my hours in Hoem Assistant
Or you can clone the SD card to a larger one, and then use parted (or gparted) to resize the root partition to fill the bigger SD card.
My little docker knowledge, I guess the container grew above and beyond, but @Luis Belo is looking at the logs of armbian - this is like searching in the kitchen for the bathtub.
docker ps -a    lists all Container
docker exec -it put-here-your-containername bash   once in the container do: cd / && ls -la
Now your are in the container and can clean its log file.
  On 8/13/2020 at 1:31 PM, Tido said:
You explain nothing about that command - good for you to know exactly what it does.
Expand
What it does is prune images that are not in use by containers, but that's pretty much what the command says.
  On 8/12/2020 at 5:23 PM, Werner said:
Something filled up your space. It is up to you to investigate what the reason is.
You can try to search for big directories with commands like "du -a / | sort -n -r | head -n 10"
Found via web: https://duckduckgo.com/?t=ffab&q=linux+find+big+files&ia=web
Expand
Please try this or something similar to get an idea where on your sdcard are big files hidden.
