kudzu Posted June 26, 2016 Posted June 26, 2016 (edited) Hi, I've got: ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun4i My problem is: root@cubieboard:~# aplay -l**** List of PLAYBACK Hardware Devices ****card 0: sunxicodec [sunxi-CODEC], device 0: M1 PCM [sunxi PCM] Subdevices: 1/1 Subdevice #0: subdevice #0 - no spdif. Why? Script.bin is ok. It seems that the driver is not built into the kernel... Please help. Edited June 26, 2016 by kudzu
Igor Posted June 30, 2016 Posted June 30, 2016 Yes, AFAIK driver was done only for A20 boards. BTW: that topic is unrelated.
kudzu Posted July 2, 2016 Author Posted July 2, 2016 Thank you. So, if I understand correctly, in Cubieboard1 I can't use s/pdif output? But it applies to Armbian or generally Debian?
Igor Posted July 3, 2016 Posted July 3, 2016 Thank you. So, if I understand correctly, in Cubieboard1 I can't use s/pdif output? But it applies to Armbian or generally Debian? Driver patches breaks building kernel for Allwinner A10 - I haven't go into details. Those are audio related patches applied on sunxi kernel source, enabled on A20 builds: https://github.com/igorpecovnik/lib/blob/master/patch/kernel/sun7i-default/0028-nikkov-i2s-spdif-2.0.patch https://github.com/igorpecovnik/lib/blob/master/patch/kernel/sun7i-default/0029-HDMI-8ch-and-alsa-fix-2.0.patch https://github.com/igorpecovnik/lib/blob/master/patch/kernel/sun7i-default/1017-SPDIF-experiments.patch SPDIF is also disabled in config by default: https://github.com/igorpecovnik/lib/blob/master/config/fex/cubieboard.fex#L834 It's kernel / sys config related.
kudzu Posted July 6, 2016 Author Posted July 6, 2016 Hmmm... It's too hard for me. But thanks for help:)
maruprez Posted March 8, 2017 Posted March 8, 2017 Excuse me!! Just to check if I understood well.... There is no possibility to connect a DAC via I2s to Cubieboard 1 ? Thanks
Igor Posted March 8, 2017 Posted March 8, 2017 Theoretical yes, practical no since the driver was made for A20 and it breaks while building for A10. Not without rework.
maruprez Posted March 8, 2017 Posted March 8, 2017 (edited) @Igor Thanks. So, OPI one or Lite , could be a good alternative? Edited March 8, 2017 by maruprez Complete phrase
