Hello. Good day.
I managed to installed Android on the OrangePi RK3399 using the Linux_Upgrade_tool (v 1.49), but, I'm struggling to get the board to boot back to Linux. I created an sdcard from the debian image from the OragenPi website, but, when I try to boot is with the sdcard insert, I get the messages below on the serial terminal.
Removing the sdcard boots normally on Android (installed on emmc). Pressing spacebard doesn't do anything during boot. Also, trying to flash the Linux image via the Linux_Upgrade_tool doesn't work (always return a fail).
Any ideas how to make this board boot back on Linux?
Thank you.
DDR Version 1.07 20161103
In
Channel 0: DDR3, 666MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: DDR3, 666MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C172C1, stride = 0xD
OUT
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1835
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 0
BootCapSize=0
UserCapSize=29983MB
FwPartOffset=2000 , 0
StorageInit ok = 97615
LoadTrustBL
LoadTrustBL error:-1
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 116015
LoaderFlag2: 0x0
WARNING: plat_rockchip_comm_sram_init:code:ff8d9000, 67000, ef0
NOTICE:  BL31: v1.2(debug):b995f80
NOTICE:  BL31: Built : 16:53:56, Nov  7 2016
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    boot cpu mask: 0
INFO:    Vesion: 2016.0.01
INFO:    plat_rockchip_pmu_init(1211): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2014.10-RK3399-10 (Jul 23 2020 - 18:40:21)
CPU: rk3399
CPU's clock information:
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 594000000HZ
               aclk_periph_h = 148500000HZ, hclk_periph_h = 74250000HZ, pclk_periph_h = 37125000HZ
               aclk_periph_l0 = 99000000HZ, hclk_periph_l0 = 99000000HZ, pclk_periph_l0 = 49500000HZ
               hclk_periph_l1 = 99000000HZ, pclk_periph_l1 = 49500000HZ
    cpll = 800000000HZ
    dpll = 660000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
Board:    Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Adding bank:0000000000200000(00000000ffe00000)
128 MiB
SdmmcInit = 0 0
SDCard Update.
storage init OK!
Using default environment
GetParam
W: Invalid Parameter's tag (0x00000000)!
Invalid parameter
No pmic detect.
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 0000-00-00#0.00
empty serial no.
normal boot.
no fuel gauge found
no fuel gauge found
read logo on state from dts [0]
no fuel gauge found
'recovery' does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
'backup' does not seem to be a partition nor an address
Unable to boot:backup
try to start rockusb
Then you should state your question to the OrangePi folks themselves. Armbian has nothing to do wih these (badly hacked together) images.
Hi @Werner Thanks for the reply.
I also tried with a pre-built Armbian image. The serial log when booting with a Armbian flash sd-card is below.
Any suggestion/idea of what might be wrong?
Thank you.
256B stride
OUT
CPUId = 0x0
ChipType = 10 1838
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=29983MB
StorageInit ok = 135062
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 219165
LoaderFlag2: 0x0
Unhandled Exception in EL3.
x30 =        0xUnhandled Exception in EL3.
This does not look much like Armbian...
Did you properly clear your sd card before flashing Armbian on it? Since OrangePi images come with two partitions and Armbian with only one.
Better erase the partition table of your sd card before trying to flash anything on it.
I was able to overcome that error by powering the board from the USB-C directly instead of the barrel jack power supply (!?).
Doing that allowed me to boot the OPI image and I was able to transfer it to eMMC.
My next step is to boot Armbian on this board and install in on eMMC. AT first, I wrote an sdcard an pre-built Armbian Opi RK3399 (Armbian_20.08_Orangepi-rk3399_bionic_legacy_4.4.213_desktop), but when I try to boot from that, using the setenv devnum 1 and run mmc_boot, I got the error below.
I'm kind of lost on what to look next for solution. I'll continue trying different things but any pointers or suggestions is appreciated.
Thank you.
U-Boot 2017.09-g17808ce (Aug 21 2020 - 13:03:33 -0300)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM:  3.8 GiB
Sysmem: init
Relocation Offset is: f5be5000
dwmmc@fe320000: 1, sdhci@fe330000: 0
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
get part misc fail -1
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
Android header version 0
Hotkey: ctrl+c
I2c speed: 400000Hz
PMIC:  RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
LDO_REG4 init 3000000 uV
vdd_log 1000000 uV
Warn: can't find connect driver
Model: OrangePi RK3399
Rockchip UBOOT DRM driver version: v1.0.1
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
  aplll 816000 KHz
  apllb 24000 KHz
  dpll 800000 KHz
  cpll 24000 KHz
  gpll 800000 KHz
  npll 600000 KHz
  vpll 24000 KHz
  aclk_perihp 133333 KHz
  hclk_perihp 66666 KHz
  pclk_perihp 33333 KHz
  aclk_perilp0 266666 KHz
  hclk_perilp0 88888 KHz
  pclk_perilp0 44444 KHz
  hclk_perilp1 100000 KHz
  pclk_perilp1 50000 KHz
Net:   eth0: ethernet@fe300000
Hit key to stop autoboot('CTRL+C'):  0
=> <INTERRUPT>
=> <INTERRUPT>
=> <INTERRUPT>
=> setenv devnum 1
=> run mmc_boot
RKPARM: Invalid parameter part table
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
3185 bytes read in 19 ms (163.1 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
116 bytes read in 16 ms (6.8 KiB/s)
"Synchronous Abort" handler, esr 0x96000010
* Relocate offset = 00000000f5be5000
* ELR(PC)    =   000000000028abf0
* LR         =   0000000000289104
* SP         =   00000000e9dd74e0
* ESR_EL2    =   0000000096000010
	EC[31:26] == 100101, Exception from a Data abort, from current exception level
	IL[25] == 1, 32-bit instruction trapped
* DAIF       =   00000000000003c0
	D[9] == 1, DBG masked
	A[8] == 1, ABORT masked
	I[7] == 1, IRQ masked
	F[6] == 1, FIQ masked
* SPSR_EL2   =	 0000000080000349
	I[7] == 0, IRQ not masked
	M[4] == 0, Exception taken from AArch64
	M[3:0] == 1001, EL2h
* SCTLR_EL2  =	 0000000030c51835
	I[12] == 1, Icaches enabled
	C[2] == 1, Dcache enabled
	M[0] == 1, MMU enabled
* HCR_EL2    =   000000000800003a
* VBAR_EL2   =   00000000f5de5800
* TTBR0_EL2  =   00000000f7ff0000
x0 : 00000000e9e5d6d0 x1 : 0000000009000000
x2 : 0000000000000074 x3 : 0000000000000000
x4 : 0000000000000070 x5 : 000000000000000e
x6 : 0000000000000000 x7 : 0000000000000000
x8 : 00000000e9e5d660 x9 : 0000000000000008
x10: 00000000e9e5d6e0 x11: 00000000e9de4190
x12: 0000000000000000 x13: 0000000000000200
x14: 0000000008300000 x15: 00000000ffffffff
x16: 000000002ef72001 x17: 00000000b0a20028
x18: 00000000e9ddcd10 x19: 0000000000000000
x20: 0000000000000074 x21: 0000000009000000
x22: 00000000e9e5d6d0 x23: 00000000f5eae4d8
x24: 0000000000000000 x25: 00000000e9e5d5e8
x26: 000000000000000a x27: 0000000000000001
x28: 0000000000000000 x29: 00000000e9dd76d0
SP:
e9dd74e0:  00000000 00000000 00000000 00000000
e9dd74f0:  00000000 00000000 f5e9dedc 00000000
e9dd7500:  00000000 00000000 00000000 00000000
e9dd7510:  f5e9df23 00000000 f5e9df49 00000000
e9dd7520:  f5e9df96 00000000 f5e9dfe3 00000000
e9dd7530:  f5e9e023 00000000 f5e9e063 00000000
e9dd7540:  f5e9e0a0 00000000 00000000 00000000
e9dd7550:  00000000 00000000 f5e9e0dd 00000000
e9dd7560:  e9dd76d0 00000000 f5de5a0c 00000000
e9dd7570:  00000000 00000000 09000000 00000000
e9dd7580:  f7ff0000 00000000 0800003a 00000000
e9dd7590:  30c51835 00000000 e9dd74e0 00000000
e9dd75a0:  80000349 00000000 f5de5800 00000000
e9dd75b0:  000003c0 00000000 96000010 00000000
e9dd75c0:  f5e6fbf0 00000000 e9e5d6d0 00000000
e9dd75d0:  09000000 00000000 00000074 00000000
Call trace:
  PC:	[< 0028abf0 >]
  LR:	[< 00289104 >]
Stack:
	[< 0028abf0 >]
	[< 00210c5c >]
	[< 00228854 >]
	[< 00213a0c >]
	[< 00213bac >]
	[< 002132f8 >]
	[< 002137c8 >]
	[< 00213684 >]
	[< 00213bac >]
	[< 002132b0 >]
	[< 00227d84 >]
	[< 00205ea0 >]
	[< 00205fa8 >]
	[< 00228854 >]
	[< 00213a0c >]
	[< 00213bac >]
	[< 002132f8 >]
	[< 002137c8 >]
	[< 00213bac >]
	[< 002132b0 >]
	[< 00227e34 >]
	[< 00228854 >]
	[< 00213a0c >]
	[< 00213684 >]
	[< 00213684 >]
	[< 00213bac >]
	[< 002132b0 >]
	[< 00227e34 >]
	[< 00228854 >]
	[< 00213a0c >]
	[< 00213684 >]
	[< 00213bac >]
	[< 002132b0 >]
	[< 00227e34 >]
	[< 00228854 >]
	[< 00213a0c >]
	[< 00213684 >]
	[< 00213684 >]
	[< 00213bac >]
	[< 002132b0 >]
	[< 00227e34 >]
	[< 00228854 >]
	[< 00213a0c >]
	[< 00213684 >]
	[< 00213bac >]
	[< 002132b0 >]
	[< 00227e34 >]
	[< 00228854 >]
	[< 00213a0c >]
	[< 00213bac >]
	[< 002140f0 >]
	[< 00227f2c >]
	[< 00211ca0 >]
	[< 002147e8 >]
	[< 002727b4 >]
	[< 00214974 >]
	[< 0020196c >]
Copy above stack info to a file(eg. dump.txt), and
execute command in your U-Boot project: ./scripts/stacktrace.sh dump.txt
Resetting CPU ...
DDR Version 1.22 20190506
In
soft reset
SRX
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 308
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=29983MB
StorageInit ok = 65576
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT part:  0, name:            uboot, start:0x6000, size:0x2000
GPT part:  1, name:            trust, start:0x8000, size:0x2000
GPT part:  2, name:             boot, start:0xc000, size:0x10000
GPT part:  3, name:           rootfs, start:0x5c000, size:0x3a337df
find part:uboot OK. first_lba:0x6000.
find part:trust OK. first_lba:0x8000.
LoadTrust Addr:0x8000
LoadTrust Addr:0x8400
LoadTrust Addr:0x8800
LoadTrust Addr:0x8c00
LoadTrust Addr:0x9000
LoadTrust Addr:0x9400
LoadTrust Addr:0x9800
LoadTrust Addr:0x9c00
Addr:0x8000 No find trust.img!
LoadTrustBL error:-3
SecureMode = 0
SecureInit ret = -2, SecureMode = 0
As suggested by Werner get rid of recovery GPT partition table from your SD.
This is a known interoperability issue between Xunlong's images and Armbian. Below you can find instructions.
Also, did you short TP50265 to the ground for booting from SD according to the download page instructions? The first part of your log seems like booting from eMMC.
That's awesome! It worked.
I formatted the sdcard creating without creating any partition, then I wrote the Armbian image.
Thanks for the help!
PS: How can we marked this as "solved"?
Thank you.
