Crossplatform Vlad Posted August 24, 2020 Posted August 24, 2020 Can we switch a 64 bit image from downloads section to 32 bit kernel, repos and apps? I want a 32 bit (armhf) build server, but can see 64 bit OS images only. Do I need to build my custom armbian image? Are there command line examples for build script that produces armhf image instead of aarch64? I prefer H6 SoC instead of H3 because H6 is two times faster than H3, but the price of H6-based boards is very similar to H3-based boards. Thanks in advance
Werner Posted August 24, 2020 Posted August 24, 2020 It is not possible to create armhf images for arm64 boards.
martinayotte Posted August 24, 2020 Posted August 24, 2020 Why do you want armhf ? You can still run 32bits applications on 64bits kernel by installing additional libraries ...
Crossplatform Vlad Posted August 24, 2020 Author Posted August 24, 2020 On 8/24/2020 at 5:54 PM, martinayotte said: Why do you want armhf ? You can still run 32bits applications on 64bits kernel by installing additional libraries ... Expand Cool. Can I obtain "armv7..." instead of aarch64 as output for uname -m ? Similar question - Can I obtain ''arm" instead of "arm64" as output for docker version --format '{{.Server.Arch}}' ?
martinayotte Posted August 24, 2020 Posted August 24, 2020 On 8/24/2020 at 6:44 PM, Crossplatform Vlad said: Can I obtain "armv7..." instead of aarch64 as output for uname -m ? Expand No ! This reports the kernel version, which still aarch64. On 8/24/2020 at 6:44 PM, Crossplatform Vlad said: Similar question - Can I obtain ''arm" instead of "arm64" as output for docker version --format '{{.Server.Arch}}' ? Expand Maybe ... Probably if you install the 32bits version of docker ... 1
