Using acronyms feature
Go to solution Solved by Werner,
It is possible to add explanations to certain expression or acronyms.
The example above shows the (in this case case-sensitive) expression OOB (you see it is "underdot'ed") with the explanation "out of the box" while pointing with the cursor on it.
Do you think this is a useful feature and if so what acronyms could/should be added to be automatically highlighted?
Ideas:
  • dtc - device tree compiler
  • dtb - device tree blob
  • dts - device tree source
  • IRC - internet relay chat
  • sunxi - board family of Allwinner 32bit ARM SoCs
  • sunxi64 - board family of Allwinner 64bit ARM SoCs
  • XU4 - Odroid XU4
  • OPi - Orange Pi
  • N2 - Odroid N2
  • C2 - Odroid C2
  • C4 - Odroid C4
  • RK - Rockchip
  • AML - Amlogic
  • AW - Allwinner
  • M4 - NanoPi M4
  • M4V2 - NanoPi M4V2
  • P2P - peer to peer
  • eMMC - embeeded MultiMediaCard
  • OS - operating system
  • VPU - video processing unit
  • panfrost - driver for Mali Midgard and Bifrost GPUs
  • cedrus - driver for hardware accelerated video de-/encoding
  • PSU - power supply unit
  • RC - release candidate
  • WG - Wireguard
On 9/14/2020 at 4:52 PM, Werner said:
embeeded
embedded,
VPU - video processing unit (encoding/decoding)
GPU - graphic processing unit (3D acceleration)
SoC - System on a Chip
SBC - Single Board Computer
WIP - Work in progress
NAND - Flash storage
GPIO - general purpose input/output
CSC - the weirdo.. no support abbreviation
EOS - End of Support -  Hey Werner, die beiden schreien nahe zu nach einer Zusammenführung.
CSC - Community Supported Chip?
It is actually not the same as EOS.
I think I'll just add some of the suggestion and see what happens. It should not break anything (and if we can blame Invision :P)
Hm it does not add the acronyms to already existing posts. Not immediately at least. Maybe there is a cronjob or something that will take care of.
  • Solution
Since nobody complains I assume it is fine and can stay :P
Suggestions for additional acronyms are welcome.
Sorry, read it on the mobile - had an answer in my mind, but wanted to write on the PC and forgot it :(
Well, both are no longer supported. So, when you  change an SBC from Supported to Not-Supported - it doesn't matter for the user whether you call it  EOS or CSC - to this person it is the same.  No supported images.
As soon as someone steps in and want to support it again - its status would change to "supported".  As it is anyway on best effort - there is no difference at all. The EOS/CSC never made any sense.
