maknho Posted September 24, 2020 Posted September 24, 2020 Armbianmonitor: http://ix.io/2yC6 Hello, I run armbian 20.08.3 on an Odroid N2 with a dongle wifi. I have upgraded the board from armbian-firmware full 20.08.3 to 20.08.4. After that the screen insn't recognize anymore (it's an AOC e2250Sda) and after some reboot it s doest start anymore. Have I to wait the nex update ? Thanks a lot
lanefu Posted September 24, 2020 Posted September 24, 2020 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
Igor Posted September 24, 2020 Posted September 24, 2020 1 hour ago, maknho said: Have I to wait the nex update ? You certainly need to read your support contract first: https://github.com/armbian/build#support Better hw support and less surprises you will have with stock legacy 4.9.y kernel, which is supported by hardware maker and they will always say "yes" even they are unable to fix all problems. Even less problems you will have if you freeze kernel (armbian-config -> system) and update only non hardware specifics components / package base. If you want modern kernel, this is the minimal price to pay.
maknho Posted September 25, 2020 Author Posted September 25, 2020 OK Thks. I freezed the updating of the firmware at 20.08.3. Good evening
