After installing Arbian on Rock pi 4 c the sound on the Jack does not work because the sound card driver is. 8316 is not supported
The sound goes out anyway on the HDMI of my television
Would there be a solution
Providing logs with
armbianmonitor -u
 helps with troubleshooting and significantly raises chances that issue gets addressed.
Also choosing an appropriate topic title helps finding your topic.
This is what the Armbian -U command gives
I don't see the first lines but maybe this will be enough to give you an idea of my problem
  1660    On-line CPU(s) list: 0-5
  1661    Thread(s) per core:  1
  1662    Core(s) per socket:  3
  1663    Socket(s):           2
  1664    NUMA node(s):        1
  1665    Vendor ID:           ARM
  1666    Model:               4
  1667    Model name:          Cortex-A53
  1668    Stepping:            r0p4
  1669    CPU max MHz:         2016,0000
  1670    CPU min MHz:         408,0000
  1671    BogoMIPS:            48.00
  1672    NUMA node0 CPU(s):   0-5
  1673    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1674
  1675    ### cpuinfo:
  1676
  1677    processor    : 0
  1678    BogoMIPS    : 48.00
  1679    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1680    CPU implementer    : 0x41
  1681    CPU architecture: 8
  1682    CPU variant    : 0x0
  1683    CPU part    : 0xd03
  1684    CPU revision    : 4
  1685
  1686    processor    : 1
  1687    BogoMIPS    : 48.00
  1688    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1689    CPU implementer    : 0x41
  1690    CPU architecture: 8
  1691    CPU variant    : 0x0
  1692    CPU part    : 0xd03
  1693    CPU revision    : 4
  1694
  1695    processor    : 2
  1696    BogoMIPS    : 48.00
  1697    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1698    CPU implementer    : 0x41
  1699    CPU architecture: 8
  1700    CPU variant    : 0x0
  1701    CPU part    : 0xd03
  1702    CPU revision    : 4
  1703
  1704    processor    : 3
  1705    BogoMIPS    : 48.00
  1706    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1707    CPU implementer    : 0x41
  1708    CPU architecture: 8
  1709    CPU variant    : 0x0
  1710    CPU part    : 0xd03
  1711    CPU revision    : 4
  1712
  1713    processor    : 4
  1714    BogoMIPS    : 48.00
  1715    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1716    CPU implementer    : 0x41
  1717    CPU architecture: 8
  1718    CPU variant    : 0x0
  1719    CPU part    : 0xd08
  1720    CPU revision    : 2
  1721
  1722    processor    : 5
  1723    BogoMIPS    : 48.00
  1724    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1725    CPU implementer    : 0x41
  1726    CPU architecture: 8
  1727    CPU variant    : 0x0
  1728    CPU part    : 0xd08
  1729    CPU revision    : 2
  1730
  1731
  1732    ### meminfo:
  1733
  1734    MemTotal:        3891300 kB
  1735    MemFree:         3631132 kB
  1736    MemAvailable:    3606472 kB
  1737    Buffers:           14692 kB
  1738    Cached:            78780 kB
  1739    SwapCached:            0 kB
  1740    Active:            74508 kB
  1741    Inactive:          47624 kB
  1742    Active(anon):      37296 kB
  1743    Inactive(anon):     5144 kB
  1744    Active(file):      37212 kB
  1745    Inactive(file):    42480 kB
  1746    Unevictable:        8100 kB
  1747    Mlocked:               0 kB
  1748    SwapTotal:       1945648 kB
  1749    SwapFree:        1945648 kB
  1750    Dirty:              2556 kB
  1751    Writeback:             0 kB
  1752    AnonPages:         36720 kB
  1753    Mapped:            26552 kB
  1754    Shmem:             13480 kB
  1755    KReclaimable:      28928 kB
  1756    Slab:              69572 kB
  1757    SReclaimable:      28928 kB
  1758    SUnreclaim:        40644 kB
  1759    KernelStack:        3376 kB
  1760    PageTables:         2944 kB
  1761    NFS_Unstable:          0 kB
  1762    Bounce:                0 kB
  1763    WritebackTmp:          0 kB
  1764    CommitLimit:     3891296 kB
  1765    Committed_AS:     151768 kB
  1766    VmallocTotal:   135290159040 kB
  1767    VmallocUsed:       27184 kB
  1768    VmallocChunk:          0 kB
  1769    Percpu:             2280 kB
  1770    AnonHugePages:         0 kB
  1771    ShmemHugePages:        0 kB
  1772    ShmemPmdMapped:        0 kB
  1773    FileHugePages:         0 kB
  1774    FilePmdMapped:         0 kB
  1775    CmaTotal:         131072 kB
  1776    CmaFree:          121856 kB
  1777    HugePages_Total:       0
  1778    HugePages_Free:        0
  1779    HugePages_Rsvd:        0
  1780    HugePages_Surp:        0
  1781    Hugepagesize:       2048 kB
  1782    Hugetlb:               0 kB
  1783
  1784    ### virtual memory:
  1785
  1786    vm.admin_reserve_kbytes = 8192
  1787    vm.block_dump = 0
  1788    vm.compact_unevictable_allowed = 1
  1789    vm.dirty_background_bytes = 0
  1790    vm.dirty_background_ratio = 10
  1791    vm.dirty_bytes = 0
  1792    vm.dirty_expire_centisecs = 3000
  1793    vm.dirty_ratio = 20
  1794    vm.dirtytime_expire_seconds = 43200
  1795    vm.dirty_writeback_centisecs = 500
  1796    vm.extfrag_threshold = 500
  1797    vm.hugetlb_shm_group = 0
  1798    vm.laptop_mode = 0
  1799    vm.legacy_va_layout = 0
  1800    vm.lowmem_reserve_ratio = 256    256    32    0
  1801    vm.max_map_count = 65530
  1802    vm.min_free_kbytes = 45056
  1803    vm.min_slab_ratio = 5
  1804    vm.min_unmapped_ratio = 1
  1805    vm.mmap_min_addr = 4096
  1806    vm.mmap_rnd_bits = 18
  1807    vm.mmap_rnd_compat_bits = 11
  1808    vm.nr_hugepages = 0
  1809    vm.nr_hugepages_mempolicy = 0
  1810    vm.nr_overcommit_hugepages = 0
  1811    vm.numa_stat = 1
  1812    vm.numa_zonelist_order = Node
  1813    vm.oom_dump_tasks = 1
  1814    vm.oom_kill_allocating_task = 0
  1815    vm.overcommit_kbytes = 0
  1816    vm.overcommit_memory = 0
  1817    vm.overcommit_ratio = 50
  1818    vm.page-cluster = 0
  1819    vm.panic_on_oom = 0
  1820    vm.percpu_pagelist_fraction = 0
  1821    vm.stat_interval = 1
  1822    vm.swappiness = 100
  1823    vm.user_reserve_kbytes = 120540
  1824    vm.vfs_cache_pressure = 100
  1825    vm.watermark_boost_factor = 15000
  1826    vm.watermark_scale_factor = 10
  1827    vm.zone_reclaim_mode = 0
  1828
  1829    ### ip addr:
  1830
  1831    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1832        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1833        inet XXX.XXX.0.1/8 scope host lo
  1834           valid_lft forever preferred_lft forever
  1835        inet6 ::1/128 scope host
  1836           valid_lft forever preferred_lft forever
  1837    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  1838        link/ether 32:01:71:a5:c5:2a brd ff:ff:ff:ff:ff:ff
  1839    3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
  1840        link/ether c0:84:7d:6b:11:ab brd ff:ff:ff:ff:ff:ff
  1841
  1842    ### partitions:
  1843
  1844    major minor  #blocks  name
  1845
  1846     179        0   30375936 mmcblk1
  1847     179        1   30055792 mmcblk1p1
  1848     179       32   30310400 mmcblk2
  1849     179       33       4000 mmcblk2p1
  1850     179       34       4096 mmcblk2p2
  1851     179       35       4096 mmcblk2p3
  1852     179       36     262144 mmcblk2p4
  1853     179       37   30031855 mmcblk2p5
  1854     259        0  244198584 nvme0n1
  1855     259        1  244197376 nvme0n1p1
  1856     252        0      51200 zram0
  1857     252        1    1945652 zram1
  1858
  1859    ### df:
  1860
  1861    udev               1,8G       0  1,8G   0% /dev
  1862    tmpfs              381M    5,4M  375M   2% /run
  1863    /dev/nvme0n1p1     229G    9,6G  208G   5% /
  1864    tmpfs              1,9G       0  1,9G   0% /dev/shm
  1865    tmpfs              5,0M    4,0K  5,0M   1% /run/lock
  1866    tmpfs              1,9G       0  1,9G   0% /sys/fs/cgroup
  1867    tmpfs              1,9G    4,0K  1,9G   1% /tmp
  1868    /dev/mmcblk1p1      29G    5,7G   22G  22% /media/mmcboot
  1869    /dev/zram0          49M    2,7M   43M   6% /var/log
  1870
  1871    ### lsblk:
  1872
  1873    NAME         FSTYPE   SIZE MOUNTPOINT     UUID
  1874    mmcblk1                29G
  1875    └─mmcblk1p1  ext4    28,7G /media/mmcboot 6361ac39-75a6-4210-8ea2-e2739617bfaa
  1876    mmcblk2              28,9G
  1877    ├─mmcblk2p1           3,9M
  1878    ├─mmcblk2p2             4M
  1879    ├─mmcblk2p3             4M
  1880    ├─mmcblk2p4  vfat     256M                827A-5617
  1881    └─mmcblk2p5  ext4    28,7G                f57cc154-673a-43b5-9210-0a3fc8b5f6e7
  1882    mmcblk2boot0            4M
  1883    mmcblk2boot1            4M
  1884    zram0                  50M /var/log
  1885    nvme0n1             232,9G
  1886    └─nvme0n1p1  ext4   232,9G /              68b86594-6897-47d7-b97b-ae0bfd98ad5c
  1887
  1888    ### zramctl:
  1889
  1890    NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  1891    /dev/zram1 lzo-rle       1,9G    4K   74B   12K       6 [SWAP]
  1892    /dev/zram0 zstd           50M  184K 13,8K  124K       6 /var/log
  1893
  1894    ### mtab:
  1895
  1896    /dev/mmcblk1p1 /boot ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1897    /dev/mmcblk1p1 /media/mmcboot ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1898    /dev/nvme0n1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1899    /dev/nvme0n1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1900    /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
  1901
  1902    ### mmc2:0001 info:
  1903
  1904                   fwrev: 0x1400020000000000
  1905                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=SLD32G MODALIAS=mmc:block
  1906                     cid: 880103534c4433324747f91c69a04700
  1907             rel_sectors: 0x1
  1908    enhanced_rpmb_supported: 0x1
  1909                     rca: 0x0001
  1910            pre_eol_info: 0x01
  1911                     csd: d0ffff329f5903ffffffffe796400000
  1912                  manfid: 0x000088
  1913                     ocr: 0x00000080
  1914    preferred_erase_size: 4194304
  1915    enhanced_area_offset: 18446744073709551594
  1916      raw_rpmb_size_mult: 0x20
  1917                    type: MMC
  1918                   hwrev: 0x0
  1919                    date: 04/2020
  1920                     prv: 0x47
  1921             ffu_capable: 1
  1922                     dsr: 0x404
  1923              erase_size: 524288
  1924               life_time: 0x01 0x00
  1925      enhanced_area_size: 4294967274
  1926                   oemid: 0x0103
  1927                  serial: 0xf91c69a0
  1928                 cmdq_en: 1
  1929                     rev: 0x8
  1930                    name: SLD32G
  1931
  1932    ### mmc1:0007 info:
  1933
  1934                   fwrev: 0x0
  1935                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SL32G MODALIAS=mmc:block
  1936                     cid: 035054534c33324730da05496c00faa9
  1937                     rca: 0x0007
  1938                     csd: 400e00325b590000e7bf7f800a40008d
  1939                  manfid: 0x000003
  1940                     ocr: 0x00200000
  1941    preferred_erase_size: 4194304
  1942                    type: SD
  1943                   hwrev: 0x3
  1944                    date: 10/2015
  1945                     dsr: 0x404
  1946              erase_size: 512
  1947                   oemid: 0x5054
  1948                  serial: 0xda05496c
  1949                     ssr: 00000000050000000400900200aa0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1950                     scr: 0235800201000000
  1951                    name: SL32G
  1952
  1953    ### Boot system health:
  1954
  1955    Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  1956    18:19:53: 2016/1512MHz  0.28  27%  12%  14%   0%   0%   0% 21.7°C  0/6
  1957    18:19:53:  600/1512MHz  0.28  22%  12%   8%   0%   0%   0% 20.6°C  0/6
  1958    18:19:54: 2016/1512MHz  0.28  95%  33%  55%   0%   1%   4% 25.0°C  0/6
  1959    18:19:54: 2016/1512MHz  0.28  99%  26%  70%   0%   0%   1% 25.6°C  0/6
  1960    18:19:55: 2016/1512MHz  0.28  99%  23%  75%   0%   0%   0% 25.0°C  0/6
  1961
  1962    ### lsusb:
  1963
  1964    Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1965    Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1966    Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1967    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1968    Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1969    Bus 002 Device 003: ID 0d62:001c Darfon Electronics Corp. Benq X120 Internet Keyboard Pro
  1970    Bus 002 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  1971    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1972    Bus 003 Device 002: ID 03f0:8207 HP, Inc FHA-3510 2.4GHz Wireless Optical Mobile Mouse
  1973    Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1974    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1975
  1976    /:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
  1977    /:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
  1978    /:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
  1979    /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
  1980    /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  1981    /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  1982        |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
  1983    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  1984        |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
  1985            |__ Port 2: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
  1986            |__ Port 2: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
  1987    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  1988
  1989    ### lspci:
  1990
  1991    00:00.0 PCI bridge: Fuzhou Rockchip Electronics Co., Ltd RK3399 PCI Express Root Port
  1992    01:00.0 Non-Volatile memory controller: Kingston Technologies Device 2263 (rev 03)
  1993
  1994    ### Installed packages:
  1995
  1996    ii  armbian-buster-desktop                        20.08.7                              all          Armbian desktop for Debian buster
  1997    ii  armbian-config                                20.08.7                              all          Armbian configuration utility
  1998    ii  armbian-firmware-full                         20.08.7                              all          Linux firmware-full
  1999    ii  hostapd                                       3:2.9-102~armbian20.05.2+1           arm64        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
  2000    ii  htop                                          3.1.0-0~armbian20.08.2+1             arm64        interactive processes viewer
  2001    ii  linux-base                                    4.6                                  all          Linux image base package
  2002    ii  linux-buster-root-current-rockpi-4c           20.08.7                              arm64        Armbian tweaks for buster on rockpi-4c (current branch)
  2003    ii  linux-dtb-current-rockchip64                  20.08.7                              arm64        Linux DTB, version 5.8.13-rockchip64
  2004    ii  linux-headers-current-rockchip64              20.08.7                              arm64        Linux kernel headers for 5.8.13-rockchip64 on arm64
  2005    ii  linux-image-current-rockchip64                20.08.7                              arm64        Linux kernel, version 5.8.13-rockchip64
  2006    ii  linux-libc-dev:arm64                          4.19.146-1                           arm64        Linux support headers for userspace development
  2007    ii  linux-u-boot-rockpi-4c-current                20.08.1                              arm64        Uboot loader 2020.07
  2008
  2009    ### Loaded modules:
  2010
  2011    Module                  Size  Used by
  2012    rfcomm                 94208  16
  2013    governor_performance    16384  0
  2014    bnep                   32768  2
  2015    zstd                   16384  6
  2016    zram                   40960  2
  2017    snd_soc_hdmi_codec     20480  1
  2018    rc_cec                 16384  0
  2019    dw_hdmi_cec            16384  0
  2020    dw_hdmi_i2s_audio      16384  0
  2021    btsdio                 20480  0
  2022    snd_soc_audio_graph_card    24576  0
  2023    snd_soc_simple_card    24576  2
  2024    snd_soc_simple_card_utils    28672  2 snd_soc_audio_graph_card,snd_soc_simple_card
  2025    hci_uart              155648  0
  2026    snd_soc_es8316         49152  0
  2027    snd_soc_rockchip_i2s    24576  2
  2028    btqca                  20480  1 hci_uart
  2029    btrtl                  24576  1 hci_uart
  2030    btbcm                  24576  1 hci_uart
  2031    panfrost               69632  0
  2032    btintel                32768  1 hci_uart
  2033    brcmfmac              409600  0
  2034    brcmutil               24576  1 brcmfmac
  2035    gpu_sched              45056  1 panfrost
  2036    snd_soc_core          258048  6 snd_soc_hdmi_codec,snd_soc_audio_graph_card,snd_soc_simple_card_utils,snd_soc_rockchip_i2s,snd_soc_simple_card,snd_soc_es8316
  2037    bluetooth             675840  43 btrtl,btqca,btsdio,btintel,hci_uart,btbcm,bnep,rfcomm
  2038    snd_pcm_dmaengine      20480  1 snd_soc_core
  2039    hantro_vpu             90112  0
  2040    rockchip_vdec          32768  0
  2041    rockchip_rga           24576  0
  2042    snd_pcm               139264  4 snd_soc_hdmi_codec,snd_soc_core,snd_soc_es8316,snd_pcm_dmaengine
  2043    videobuf2_dma_sg       24576  1 rockchip_rga
  2044    v4l2_h264              16384  2 rockchip_vdec,hantro_vpu
  2045    videobuf2_dma_contig    24576  2 rockchip_vdec,hantro_vpu
  2046    videobuf2_vmalloc      20480  1 hantro_vpu
  2047    snd_timer              45056  1 snd_pcm
  2048    v4l2_mem2mem           45056  3 rockchip_vdec,hantro_vpu,rockchip_rga
  2049    cfg80211              897024  1 brcmfmac
  2050    videobuf2_memops       20480  3 videobuf2_vmalloc,videobuf2_dma_contig,videobuf2_dma_sg
  2051    snd                   102400  8 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm
  2052    soundcore              16384  1 snd
  2053    videobuf2_v4l2         36864  4 rockchip_vdec,hantro_vpu,rockchip_rga,v4l2_mem2mem
  2054    videobuf2_common       65536  5 rockchip_vdec,videobuf2_v4l2,hantro_vpu,rockchip_rga,v4l2_mem2mem
  2055    rfkill                 40960  7 bluetooth,cfg80211
  2056    videodev              311296  6 rockchip_vdec,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_common,v4l2_mem2mem
  2057    mc                     65536  6 rockchip_vdec,videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem
  2058    rockchipdrm           147456  3
  2059    dw_mipi_dsi            20480  1 rockchipdrm
  2060    dw_hdmi                53248  2 dw_hdmi_i2s_audio,rockchipdrm
  2061    analogix_dp            53248  1 rockchipdrm
  2062    drm_kms_helper        258048  4 dw_mipi_dsi,rockchipdrm,dw_hdmi,analogix_dp
  2063    cec                    81920  3 drm_kms_helper,dw_hdmi_cec,dw_hdmi
  2064    rc_core                61440  3 rc_cec,cec
  2065    drm                   634880  10 gpu_sched,drm_kms_helper,dw_mipi_dsi,rockchipdrm,dw_hdmi,panfrost,analogix_dp
  2066    drm_panel_orientation_quirks    20480  1 drm
  2067    cpufreq_dt             20480  0
  2068    ip_tables              32768  0
  2069    x_tables               49152  1 ip_tables
  2070    autofs4                49152  2
  2071    realtek                24576  1
  2072    dwmac_rk               28672  0
  2073    stmmac_platform        24576  1 dwmac_rk
  2074    stmmac                217088  2 stmmac_platform,dwmac_rk
  2075    mdio_xpcs              20480  1 stmmac
  2076
  2077    ### nand-sata-install.log:
  2078
  2079    Thu 01 Oct 2020 03:42:03 PM UTC: Start nand-sata-install.
  2080
  2081
  2082    Old UUID:  UUID=6361ac39-75a6-4210-8ea2-e2739617bfaa
  2083    SD UUID:   UUID=6361ac39-75a6-4210-8ea2-e2739617bfaa
  2084    SATA UUID: UUID=68b86594-6897-47d7-b97b-ae0bfd98ad5c
  2085    eMMC UUID:
  2086    Boot: $1
  2087    Root: $2 /dev/nvme0n1p1 ext4
  2088    Usage: 5832
  2089    Dest: 221706
  2090
  2091    /etc/fstab:
  2092    UUID=6361ac39-75a6-4210-8ea2-e2739617bfaa / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
  2093    tmpfs /tmp tmpfs defaults,nosuid 0 0
  2094
  2095    /etc/mtab:
  2096    /dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2097    /dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2098    /dev/nvme0n1p1 /mnt/nand-sata-install.3ViTss/rootfs ext4 rw,relatime 0 0
  2099    /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
  2100
  2101    Files currently open for writing:
  2102    sh        1509    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2103    sh        1509    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2104    xfce4-ses 1557    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2105    xfce4-ses 1557    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2106    xfce4-ses 1557    bernard   11w   REG  179,1    10958 256586 /home/bernard/.xfce4-session.verbose-log
  2107    xfwm4     1568    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2108    xfwm4     1568    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2109    xfce4-pan 1572    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2110    xfce4-pan 1572    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2111    Thunar    1574    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2112    Thunar    1574    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2113    xfdesktop 1576    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2114    xfdesktop 1576    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2115    dhclient  1579       root    4w   REG  179,1     1220  74429 /var/lib/NetworkManager/dhclient-54572d98-e2ea-4078-84d8-69c746259e7a-wlan0.lease
  2116    pasystray 1580    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2117    pasystray 1580    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2118    blueman-a 1581    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2119    blueman-a 1581    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2120    polkit-gn 1584    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2121    polkit-gn 1584    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2122    applet.py 1586    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2123    applet.py 1586    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2124    nm-applet 1590    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2125    nm-applet 1590    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2126    xfsetting 1598    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2127    xfsetting 1598    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2128    pulseaudi 1609    bernard   10u   REG  179,1    12288 256589 /home/bernard/.config/pulse/dc2ab0973f654565835a4e6716c7f0c9-device-volumes.tdb
  2129    pulseaudi 1609    bernard   11u   REG  179,1    12288 256590 /home/bernard/.config/pulse/dc2ab0973f654565835a4e6716c7f0c9-stream-volumes.tdb
  2130    pulseaudi 1609    bernard   12u   REG  179,1    16384 256591 /home/bernard/.config/pulse/dc2ab0973f654565835a4e6716c7f0c9-card-database.tdb
  2131    panel-6-s 1992    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2132    panel-6-s 1992    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2133    panel-2-a 2002    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2134    panel-2-a 2002    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2135    xfce4-ter 2945    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2136    xfce4-ter 2945    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2137
  2138    Trying to stop running services to minimize open files:
  2139    Stopping cron.service
  2140
  2141    Checking again for open files:
  2142    sh        1509    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2143    sh        1509    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2144    xfce4-ses 1557    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2145    xfce4-ses 1557    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2146    xfce4-ses 1557    bernard   11w   REG  179,1    10958 256586 /home/bernard/.xfce4-session.verbose-log
  2147    xfwm4     1568    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2148    xfwm4     1568    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2149    xfce4-pan 1572    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2150    xfce4-pan 1572    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2151    Thunar    1574    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2152    Thunar    1574    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2153    xfdesktop 1576    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2154    xfdesktop 1576    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2155    pasystray 1580    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2156    pasystray 1580    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2157    blueman-a 1581    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2158    blueman-a 1581    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2159    polkit-gn 1584    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2160    polkit-gn 1584    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2161    applet.py 1586    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2162    applet.py 1586    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2163    nm-applet 1590    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2164    nm-applet 1590    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2165    xfsetting 1598    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2166    xfsetting 1598    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2167    pulseaudi 1609    bernard   10u   REG  179,1    12288 256589 /home/bernard/.config/pulse/dc2ab0973f654565835a4e6716c7f0c9-device-volumes.tdb
  2168    pulseaudi 1609    bernard   11u   REG  179,1    12288 256590 /home/bernard/.config/pulse/dc2ab0973f654565835a4e6716c7f0c9-stream-volumes.tdb
  2169    pulseaudi 1609    bernard   12u   REG  179,1    16384 256591 /home/bernard/.config/pulse/dc2ab0973f654565835a4e6716c7f0c9-card-database.tdb
  2170    panel-6-s 1992    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2171    panel-6-s 1992    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2172    panel-2-a 2002    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2173    panel-2-a 2002    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2174    xfce4-ter 2945    bernard    1w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2175    xfce4-ter 2945    bernard    2w   REG  179,1     6852 256536 /home/bernard/.xsession-errors
  2176
  2177    Copying 129330 files to /dev/nvme0n1p1. Finishing transfer to disk, boot from SD/eMMC
  2178
  2179    Checking again for open files:
  2180    sh        1509    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2181    sh        1509    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2182    xfce4-ses 1557    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2183    xfce4-ses 1557    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2184    xfce4-ses 1557    bernard   11w   REG  179,1    10958 256586 /home/bernard/.xfce4-session.verbose-log
  2185    xfwm4     1568    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2186    xfwm4     1568    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2187    xfce4-pan 1572    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2188    xfce4-pan 1572    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2189    Thunar    1574    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2190    Thunar    1574    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2191    xfdesktop 1576    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2192    xfdesktop 1576    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2193    pasystray 1580    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2194    pasystray 1580    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2195    blueman-a 1581    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2196    blueman-a 1581    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2197    polkit-gn 1584    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2198    polkit-gn 1584    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2199    applet.py 1586    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2200    applet.py 1586    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2201    nm-applet 1590    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2202    nm-applet 1590    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2203    xfsetting 1598    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2204    xfsetting 1598    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2205    pulseaudi 1609    bernard   10u   REG  179,1    12288 256589 /home/bernard/.config/pulse/dc2ab0973f654565835a4e6716c7f0c9-device-volumes.tdb
  2206    pulseaudi 1609    bernard   11u   REG  179,1    12288 256590 /home/bernard/.config/pulse/dc2ab0973f654565835a4e6716c7f0c9-stream-volumes.tdb
  2207    pulseaudi 1609    bernard   12u   REG  179,1    16384 256591 /home/bernard/.config/pulse/dc2ab0973f654565835a4e6716c7f0c9-card-database.tdb
  2208    panel-6-s 1992    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2209    panel-6-s 1992    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2210    panel-2-a 2002    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2211    panel-2-a 2002    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2212    xfce4-ter 2945    bernard    1w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2213    xfce4-ter 2945    bernard    2w   REG  179,1     7144 256536 /home/bernard/.xsession-errors
  2214
  2215    Thu 01 Oct 2020 03:48:33 PM UTC: Finished
  2216
  2217    ### Current system health:
  2218
  2219    Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  2220    14:59:10:   ---      1.10  15%   2%  13%   0%   0%   0% 28.8°C  0/6
  2221    14:59:11:   ---      1.10   7%   2%   4%   0%   0%   0% 26.9°C  0/6
  2222    14:59:11:   ---      1.10   8%   2%   5%   0%   0%   0% 26.9°C  0/6
  2223    14:59:11:   ---      1.10   7%   2%   4%   0%   0%   0% 26.9°C  0/6
  2224    14:59:12:   ---      1.10   9%   3%   4%   0%   0%   0% 26.9°C  0/6
  2225    14:59:14:   ---      1.01  16%   2%  13%   0%   0%   0% 36.9°C  0/6
  2226    14:59:15:   ---      1.01  98%   3%  95%   0%   0%   0% 32.8°C  0/6
  2227    14:59:15:   ---      1.01  29%   2%  26%   0%   0%   0% 28.8°C  0/6
  2228    14:59:16:   ---      1.01   8%   1%   5%   0%   0%   0% 27.5°C  0/6
  2229    14:59:16:   ---      1.01  11%   2%   7%   0%   0%   0% 27.5°C  0/6
  2230
  2231    ### resolv.conf
  2232
  2233    -rw-r--r-- 1 root root 286 oct.  11 18:20 /etc/resolv.conf
  2234    # Generated by NetworkManager
  2235    search telenet.be home
  2236    nameserver 2a02:1800:100::45:2
  2237    nameserver 2a02:1800:100::45:1
  2238    nameserver XXX.XXX.130.5
  2239    # NOTE: the libc resolver may not support more than 3 nameservers.
  2240    # The nameservers listed below may not be recognized.
  2241    nameserver XXX.XXX.131.5
  2242
  2243    ### Current sysinfo:
  2244
  2245    Linux 5.8.13-rockchip64 (rockpi-4c)     13/10/2020     _aarch64_    (6 CPU)
  2246
  2247    avg-cpu:  %user   %nice %system %iowait  %steal   %idle
  2248              13,69    0,05    2,55    0,04    0,00   83,67
  2249
  2250    Device             tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
  2251    mmcblk1           0,74        23,16         0,28      10765        132
  2252    mmcblk1p1         0,42        16,37         0,28       7609        132
  2253    mmcblk2           1,11        22,93         0,00      10658          0
  2254    mmcblk2p1         0,19         3,64         0,00       1692          0
  2255    mmcblk2p2         0,12         0,46         0,00        216          0
  2256    mmcblk2p3         0,12         0,46         0,00        216          0
  2257    mmcblk2p4         0,19         6,71         0,00       3120          0
  2258    mmcblk2p5         0,39        11,15         0,00       5182          0
  2259    mmcblk2boot1      0,12         0,50         0,00        232          0
  2260    mmcblk2boot0      0,12         0,50         0,00        232          0
  2261    nvme0n1          35,41      1754,35        87,74     815617      40792
  2262    nvme0n1p1        34,88      1750,83        87,74     813977      40792
  2263    zram0             0,69         1,57        11,68        728       5432
  2264    zram1             0,64         2,56         0,01       1188          4
  2265    zram2             0,00         0,00         0,00          0          0
  2266
  2267    procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
  2268     r  b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
  2269     1  0            0      2016420        39712       641520    0    0   299    17  329  484  14   3  84   0   0
  2270
  2271                  total        used        free      shared  buff/cache   available
  2272    Mem:          3,7Gi       1,1Gi       1,9Gi       103Mi       665Mi       2,3Gi
  2273    Swap:         1,9Gi          0B       1,9Gi
  2274
  2275    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  2276    /dev/zram1 lzo-rle       1,9G    4K    74B   12K       6 [SWAP]
  2277    /dev/zram0 zstd           50M  2,6M 401,4K  796K       6 /var/log
  2278
  2279     14:59:17 up 7 min,  1 user,  load average: 1,01, 0,95, 0,48
  2280
  2281    [    2.943072] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
  2282    [    2.944703] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
  2283    [    2.946342] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
  2284    [    2.949220] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
  2285    [    2.952760] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
  2286    [    2.962978] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
  2287    [    2.967087] ledtrig-cpu: registered to indicate activity on CPUs
  2288    [    2.968480] hid: raw HID events driver (C) Jiri Kosina
  2289    [    2.968739] usbcore: registered new interface driver usbhid
  2290    [    2.968745] usbhid: USB HID core driver
  2291    [    2.974414] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  2292    [    2.974530] mmc1: new high speed SDHC card at address 0007
  2293    [    2.975614] drop_monitor: Initializing network drop monitor service
  2294    [    2.975673] mmcblk1: mmc1:0007 SL32G 29.0 GiB
  2295    [    2.976908] NET: Registered protocol family 10
  2296    [    2.978623]  mmcblk1: p1
  2297    [    3.009687] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
  2298    [    3.030074] Segment Routing with IPv6
  2299    [    3.030225] NET: Registered protocol family 17
  2300    [    3.030500] 8021q: 802.1Q VLAN Support v1.8
  2301    [    3.030585] Key type dns_resolver registered
  2302    [    3.031482] registered taskstats version 1
  2303    [    3.031497] Loading compiled-in X.509 certificates
  2304    [    3.035109] Loaded X.509 cert 'Build time autogenerated kernel key: 1a615defcee757adf2bf64b663f650e9da59d559'
  2305    [    3.035335] zswap: loaded using pool lzo/zbud
  2306    [    3.035828] Key type ._fscrypt registered
  2307    [    3.035834] Key type .fscrypt registered
  2308    [    3.035840] Key type fscrypt-provisioning registered
  2309    [    3.038891] Btrfs loaded, crc32c=crc32c-generic
  2310    [    3.042331] usb 2-1: new high-speed USB device number 2 using ehci-platform
  2311    [    3.056822] mmc2: Command Queue Engine enabled
  2312    [    3.056853] mmc2: new HS400 Enhanced strobe MMC card at address 0001
  2313    [    3.058028] mmcblk2: mmc2:0001 SLD32G 28.9 GiB
  2314    [    3.058462] mmcblk2boot0: mmc2:0001 SLD32G partition 1 4.00 MiB
  2315    [    3.058873] mmcblk2boot1: mmc2:0001 SLD32G partition 2 4.00 MiB
  2316    [    3.059149] mmcblk2rpmb: mmc2:0001 SLD32G partition 3 4.00 MiB, chardev (243:0)
  2317    [    3.062877]  mmcblk2: p1 p2 p3 p4 p5
  2318    [    3.067884] Key type encrypted registered
  2319    [    3.067904] AppArmor: AppArmor sha1 policy hashing enabled
  2320    [    3.150411] dwmmc_rockchip fe310000.mmc: Successfully tuned phase to 221
  2321    [    3.156164] mmc0: new ultra high speed SDR104 SDIO card at address 0001
  2322    [    3.184655] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
  2323    [    3.184696] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
  2324    [    3.184717] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
  2325    [    3.185044] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
  2326    [    3.185056] pci_bus 0000:00: root bus resource [bus 00-1f]
  2327    [    3.185066] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
  2328    [    3.185077] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
  2329    [    3.185119] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
  2330    [    3.185278] pci 0000:00:00.0: supports D1
  2331    [    3.185286] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
  2332    [    3.190157] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
  2333    [    3.190372] pci 0000:01:00.0: [2646:2263] type 00 class 0x010802
  2334    [    3.190507] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
  2335    [    3.190682] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 256)
  2336    [    3.191187] pci 0000:01:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x4 link at 0000:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
  2337    [    3.200197] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=32.98
  2338    [    3.200208] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  2339    [    3.200217] usb 2-1: Product: USB2.0 Hub
  2340    [    3.201061] hub 2-1:1.0: USB hub found
  2341    [    3.201440] hub 2-1:1.0: 4 ports detected
  2342    [    3.206912] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
  2343    [    3.206946] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
  2344    [    3.206962] pci 0000:01:00.0: BAR 0: assigned [mem 0xfa000000-0xfa003fff 64bit]
  2345    [    3.207011] pci 0000:00:00.0: PCI bridge to [bus 01]
  2346    [    3.207023] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
  2347    [    3.207233] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
  2348    [    3.207541] pcieport 0000:00:00.0: PME: Signaling with IRQ 240
  2349    [    3.207944] pcieport 0000:00:00.0: AER: enabled with IRQ 240
  2350    [    3.208507] nvme nvme0: pci function 0000:01:00.0
  2351    [    3.208591] nvme 0000:01:00.0: enabling device (0000 -> 0002)
  2352    [    3.210195] of_cfs_init
  2353    [    3.210228] of_cfs_init: OK
  2354    [    3.211965] nvme nvme0: missing or invalid SUBNQN field.
  2355    [    3.216486] nvme nvme0: 6/0/0 default/read/poll queues
  2356    [    3.220038]  nvme0n1: p1
  2357    [    3.225471] Freeing unused kernel memory: 4160K
  2358    [    3.258547] Run /init as init process
  2359    [    3.258554]   with arguments:
  2360    [    3.258560]     /init
  2361    [    3.258565]   with environment:
  2362    [    3.258571]     HOME=/
  2363    [    3.258576]     TERM=linux
  2364    [    3.258581]     ubootpart=c7ae5d85-01
  2365    [    3.258586]     cgroup_enable=memory
  2366    [    3.258591]     cgroup_memory=1
  2367    [    3.286352] usb 3-1: new low-speed USB device number 2 using ohci-platform
  2368    [    3.490351] usb 2-1.2: new low-speed USB device number 3 using ehci-platform
  2369    [    3.516422] usb 3-1: New USB device found, idVendor=03f0, idProduct=8207, bcdDevice= 0.01
  2370    [    3.516439] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  2371    [    3.516450] usb 3-1: Product: Wireless Optical Mobile Mouse
  2372    [    3.516459] usb 3-1: Manufacturer: HP
  2373    [    3.526051] input: HP Wireless Optical Mobile Mouse as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:03F0:8207.0001/input/input0
  2374    [    3.526893] hid-generic 0003:03F0:8207.0001: input,hidraw0: USB HID v1.00 Mouse [HP Wireless Optical Mobile Mouse] on usb-fe3a0000.usb-1/input0
  2375    [    3.607331] usb 2-1.2: New USB device found, idVendor=0d62, idProduct=001c, bcdDevice= 2.02
  2376    [    3.607344] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  2377    [    3.607353] usb 2-1.2: Product: USB Combo Keyboard
  2378    [    3.607360] usb 2-1.2: Manufacturer: Darfon
  2379    [    3.613856] input: Darfon USB Combo Keyboard as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.2/2-1.2:1.0/0003:0D62:001C.0002/input/input1
  2380    [    3.671816] hid-generic 0003:0D62:001C.0002: input,hidraw1: USB HID v1.00 Keyboard [Darfon USB Combo Keyboard] on usb-fe3c0000.usb-1.2/input0
  2381    [    3.680735] input: Darfon USB Combo Keyboard System Control as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.2/2-1.2:1.1/0003:0D62:001C.0003/input/input2
  2382    [    3.738708] input: Darfon USB Combo Keyboard Consumer Control as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.2/2-1.2:1.1/0003:0D62:001C.0003/input/input3
  2383    [    3.739300] hid-generic 0003:0D62:001C.0003: input,hiddev96,hidraw2: USB HID v1.00 Device [Darfon USB Combo Keyboard] on usb-fe3c0000.usb-1.2/input1
  2384    [    3.840569] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
  2385    [    3.840581] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
  2386    [    3.840733] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
  2387    [    3.840890] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
  2388    [    3.840903] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
  2389    [    3.840912] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
  2390    [    3.840927] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
  2391    [    3.841017] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
  2392    [    3.841025] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
  2393    [    3.846068] rk_gmac-dwmac fe300000.ethernet: init for RGMII
  2394    [    3.846410] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
  2395    [    3.846423] rk_gmac-dwmac fe300000.ethernet:     DWMAC1000
  2396    [    3.846432] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
  2397    [    3.846440] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
  2398    [    3.846447] rk_gmac-dwmac fe300000.ethernet: COE Type 2
  2399    [    3.846453] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
  2400    [    3.846460] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
  2401    [    3.846507] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
  2402    [    3.846514] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
  2403    [    3.846521] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  2404    [    3.963904] libphy: stmmac: probed
  2405    [    3.963933] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
  2406    [    3.963949] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
  2407    [   14.910628] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
  2408    [   15.205501] systemd[1]: System time before build time, advancing clock.
  2409    [   15.215989] systemd[1]: Inserted module 'autofs4'
  2410    [   15.240902] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  2411    [   15.241769] systemd[1]: Detected architecture arm64.
  2412    [   15.281041] systemd[1]: Set hostname to <rockpi-4c>.
  2413    [   15.387140] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
  2414    [   15.665795] random: systemd: uninitialized urandom read (16 bytes read)
  2415    [   15.673628] random: systemd: uninitialized urandom read (16 bytes read)
  2416    [   15.674568] systemd[1]: Listening on Journal Socket.
  2417    [   15.676280] random: systemd: uninitialized urandom read (16 bytes read)
  2418    [   15.682817] systemd[1]: Starting Load Kernel Modules...
  2419    [   15.684780] systemd[1]: Created slice User and Session Slice.
  2420    [   15.685223] systemd[1]: Reached target Slices.
  2421    [   15.690127] systemd[1]: Mounting POSIX Message Queue File System...
  2422    [   15.695770] systemd[1]: Starting Nameserver information manager...
  2423    [   15.701768] systemd[1]: Starting Restore / save the current clock...
  2424    [   15.788079] EXT4-fs (nvme0n1p1): re-mounted. Opts: commit=600,errors=remount-ro
  2425    [   16.462498] rockchip-vop ff8f0000.vop: Adding to iommu group 2
  2426    [   16.463275] rockchip-vop ff900000.vop: Adding to iommu group 3
  2427    [   16.465569] mc: Linux media interface: v0.10
  2428    [   16.469871] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
  2429    [   16.469986] [drm] unsupported AFBC format[3231564e]
  2430    [   16.479440] videodev: Linux video capture interface: v2.00
  2431    [   16.504093] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
  2432    [   16.504255] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
  2433    [   16.521271] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
  2434    [   16.521285] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  2435    [   16.528858] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  2436    [   16.532114] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
  2437    [   16.563721] cfg80211: Loading compiled-in X.509 certificates for regulatory database
sysctl: permission denied on key 'vm.mmap_rnd_bits'
sysctl: permission denied on key 'vm.mmap_rnd_compat_bits'
sysctl: permission denied on key 'vm.stat_refresh'
  2438    [   16.564125] rockchip-rga ff680000.rga: HW Version: 0x03.02
  2439    [   16.566656] bootsplash: Loading splash file (563104 bytes)
  2440    [   16.566755] bootsplash: Loaded (563104 bytes, 2 pics, 76 blobs).
  2441    [   16.569002] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
  2442    [   16.574250] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  2443    [   16.574514] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  2444    [   16.574518] cfg80211: failed to load regulatory.db
  2445    [   16.612066] rkvdec ff660000.video-codec: Adding to iommu group 1
  2446    [   16.612267] hantro-vpu ff650000.video-codec: Adding to iommu group 0
  2447    [   16.612878] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
  2448    [   16.613011] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
  2449    [   16.617163] Bluetooth: Core ver 2.22
  2450    [   16.617237] NET: Registered protocol family 31
  2451    [   16.617240] Bluetooth: HCI device and connection manager initialized
  2452    [   16.617257] Bluetooth: HCI socket layer initialized
  2453    [   16.617264] Bluetooth: L2CAP socket layer initialized
  2454    [   16.617279] Bluetooth: SCO socket layer initialized
  2455    [   16.663932] rockchip-pinctrl pinctrl: pin gpio3-30 already requested by vcc5v0-host-regulator; cannot claim for ff880000.i2s
  2456    [   16.663939] rockchip-pinctrl pinctrl: pin-126 (ff880000.i2s) status -22
  2457    [   16.663944] rockchip-pinctrl pinctrl: could not request pin 126 (gpio3-30) from group i2s0-8ch-bus  on device rockchip-pinctrl
  2458    [   16.663949] rockchip-i2s ff880000.i2s: Error applying setting, reverse things back
  2459    [   16.663976] rockchip-i2s: probe of ff880000.i2s failed with error -22
  2460    [   16.664178] es8316 1-0011: Failed to get IRQ 0: -22
  2461    [   16.668521] Console: switching to colour frame buffer device 240x67
  2462    [   16.669553] Bluetooth: HCI UART driver ver 2.3
  2463    [   16.669557] Bluetooth: HCI UART protocol H4 registered
  2464    [   16.669558] Bluetooth: HCI UART protocol BCSP registered
  2465    [   16.669587] Bluetooth: HCI UART protocol LL registered
  2466    [   16.669588] Bluetooth: HCI UART protocol ATH3K registered
  2467    [   16.669606] Bluetooth: HCI UART protocol Three-wire (H5) registered
  2468    [   16.669726] Bluetooth: HCI UART protocol Intel registered
  2469    [   16.669929] panfrost ff9a0000.gpu: clock rate = 500000000
  2470    [   16.670134] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
  2471    [   16.670180] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
  2472    [   16.677401] Bluetooth: HCI UART protocol Broadcom registered
  2473    [   16.677405] Driver 'hci_uart_qca' needs updating - please use bus_type methods
  2474    [   16.677454] Bluetooth: HCI UART protocol QCA registered
  2475    [   16.677456] Bluetooth: HCI UART protocol AG6XX registered
  2476    [   16.677472] Bluetooth: HCI UART protocol Marvell registered
  2477    [   16.678588] brcmfmac: F1 signature read @0x18000000=0x15294345
  2478    [   16.678789] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
  2479    [   16.678796] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
  2480    [   16.678802] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  2481    [   16.678807] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
  2482    [   16.682672] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1
  2483    [   16.684089] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
  2484    [   16.684413] usbcore: registered new interface driver brcmfmac
  2485    [   16.690402] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.radxa,rockpi4c.txt failed with error -2
  2486    [   16.709591] rockchip-drm display-subsystem: fb0: rockchipdrmfb frame buffer device
  2487    [   16.742986] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
  2488    [   16.786486] dw-apb-uart ff180000.serial: failed to request DMA
  2489    [   16.802811] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
  2490    [   16.802918] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
  2491    [   16.803250] random: crng init done
  2492    [   16.803253] random: 7 urandom warning(s) missed due to ratelimiting
  2493    [   16.803320] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Feb 11 2020 11:54:51 version XXX.XXX.96.61 (be7af2d@shgit) (r745790) FWID 01-a41d86bd es7.c5.n4.a3
  2494    [   16.853857] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
  2495    [   16.853879] asoc-simple-card hdmi-sound: ASoC: no DMI vendor name!
  2496    [   16.878330] Registered IR keymap rc-cec
  2497    [   16.878483] rc rc0: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0
  2498    [   16.878667] input: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0/input5
  2499    [   17.026818] Bluetooth: hci0: BCM: chip id 130
  2500    [   17.029117] Bluetooth: hci0: BCM: features 0x0f
  2501    [   17.052232] Bluetooth: hci0: BCM4345C5
  2502    [   17.052247] Bluetooth: hci0: BCM4345C5 (003.006.006) build 0000
  2503    [   17.052993] Bluetooth: hci0: BCM4345C5 'brcm/BCM4345C5.hcd' Patch
  2504    [   17.411184] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: commit=600,errors=remount-ro
  2505    [   17.655518] zram: Added device: zram0
  2506    [   17.656459] zram: Added device: zram1
  2507    [   17.657041] zram: Added device: zram2
  2508    [   17.690178] zram1: detected capacity change from 0 to 1992347648
  2509    [   17.742384] Adding 1945648k swap on /dev/zram1.  Priority:5 extents:1 across:1945648k SSFS
  2510    [   17.860789] zram0: detected capacity change from 0 to 52428800
  2511    [   17.957689] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
  2512    [   17.957720] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  2513    [   20.404053] systemd[1]: Started Armbian memory supported logging.
  2514    [   20.411931] systemd[1]: Starting Journal Service...
  2515    [   20.538632] systemd[1]: Started Journal Service.
  2516    [   20.568074] systemd-journald[721]: Received request to flush runtime journal from PID 1
  2517    [   21.055151] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  2518    [   21.055156] Bluetooth: BNEP filters: protocol multicast
  2519    [   21.055167] Bluetooth: BNEP socket layer initialized
  2520    [   21.553144] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
  2521    [   21.582410] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
  2522    [   21.582431] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
  2523    [   21.582444] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
  2524    [   21.977279] broken atomic modeset userspace detected, disabling atomic
  2525    [   22.220297] Bluetooth: hci0: BCM4345C5 Ampak_CL1 UART 37.4 MHz BT 5.0 [Version: Version: 0039.0089]
  2526    [   22.220312] Bluetooth: hci0: BCM4345C5 (003.006.006) build 0089
  2527    [   24.225479] Bluetooth: RFCOMM TTY layer initialized
  2528    [   24.225507] Bluetooth: RFCOMM socket layer initialized
  2529    [   24.225539] Bluetooth: RFCOMM ver 1.11
  2530    [   27.645688] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
  2531
  2532
  2533    vm.admin_reserve_kbytes = 8192
  2534    vm.block_dump = 0
  2535    vm.compact_unevictable_allowed = 1
  2536    vm.dirty_background_bytes = 0
  2537    vm.dirty_background_ratio = 10
  2538    vm.dirty_bytes = 0
  2539    vm.dirty_expire_centisecs = 3000
  2540    vm.dirty_ratio = 20
  2541    vm.dirtytime_expire_seconds = 43200
  2542    vm.dirty_writeback_centisecs = 500
  2543    vm.extfrag_threshold = 500
  2544    vm.hugetlb_shm_group = 0
  2545    vm.laptop_mode = 0
  2546    vm.legacy_va_layout = 0
  2547    vm.lowmem_reserve_ratio = 256    256    32    0
  2548    vm.max_map_count = 65530
  2549    vm.min_free_kbytes = 45056
  2550    vm.min_slab_ratio = 5
  2551    vm.min_unmapped_ratio = 1
  2552    vm.mmap_min_addr = 4096
  2553    vm.nr_hugepages = 0
  2554    vm.nr_hugepages_mempolicy = 0
  2555    vm.nr_overcommit_hugepages = 0
  2556    vm.numa_stat = 1
  2557    vm.numa_zonelist_order = Node
  2558    vm.oom_dump_tasks = 1
  2559    vm.oom_kill_allocating_task = 0
  2560    vm.overcommit_kbytes = 0
  2561    vm.overcommit_memory = 0
  2562    vm.overcommit_ratio = 50
  2563    vm.page-cluster = 0
  2564    vm.panic_on_oom = 0
  2565    vm.percpu_pagelist_fraction = 0
  2566    vm.stat_interval = 1
  2567    vm.swappiness = 100
  2568    vm.user_reserve_kbytes = 120540
  2569    vm.vfs_cache_pressure = 100
  2570    vm.watermark_boost_factor = 15000
  2571    vm.watermark_scale_factor = 10
  2572    vm.zone_reclaim_mode = 0
  2573
  2574    ### interrupts:
  2575               CPU0       CPU1       CPU2       CPU3       CPU4       CPU5
  2576     10:          0          0          0          0          0          0     GICv3  25 Level     vgic
  2577     12:          0          0          0          0          0          0     GICv3  27 Level     kvm guest vtimer
  2578     15:      42383      38664      44906      39937      48281      45141     GICv3  30 Level     arch_timer
  2579     17:          0          0          0          0          0          0     GICv3 113 Level     rk_timer
  2580     18:          0          0          0          0          0          0  GICv3-23   0 Level     arm-pmu
  2581     19:          0          0          0          0          0          0  GICv3-23   1 Level     arm-pmu
  2582     20:          0          0          0          0          0          0     GICv3  37 Level     ff6d0000.dma-controller
  2583     21:       4449          0          0          0          0          0     GICv3  38 Level     ff6d0000.dma-controller
  2584     22:          0          0          0          0          0          0     GICv3  39 Level     ff6e0000.dma-controller
  2585     23:          0          0          0          0          0          0     GICv3  40 Level     ff6e0000.dma-controller
  2586     24:          1          0          0          0          0          0     GICv3  81 Level     pcie-sys
  2587     26:          0          0          0          0          0          0     GICv3  83 Level     pcie-client
  2588     27:          0          0          0          0          0          0     GICv3  44 Level     eth0
  2589     28:      34183          0          0          0          0          0     GICv3  96 Level     dw-mci
  2590     29:      22017          0          0          0          0          0     GICv3  97 Level     dw-mci
  2591     30:       1070          0          0          0          0          0     GICv3  43 Level     mmc2
  2592     31:          2          0          0          0          0          0     GICv3  58 Level     ehci_hcd:usb1
  2593     32:      15385          0          0          0          0          0     GICv3  60 Level     ohci_hcd:usb3
  2594     33:        152          0          0          0          0          0     GICv3  62 Level     ehci_hcd:usb2
  2595     34:          0          0          0          0          0          0     GICv3  64 Level     ohci_hcd:usb4
  2596     35:          5          0          0          0          0          0     GICv3  94 Level     ff100000.saradc
  2597     36:          0          0          0          0          0          0     GICv3  91 Level     ff110000.i2c
  2598     37:        105          0          0          0          0          0     GICv3  66 Level     ff130000.i2c
  2599     38:       1337          0          0          0          0          0     GICv3 131 Level     ttyS0
  2600     39:          9          0          0          0          0          0     GICv3 132 Level     ttyS2
  2601     40:          0          0          0          0          0          0     GICv3 129 Level     rockchip_thermal
  2602     41:       7365          0          0          0          0          0     GICv3  89 Level     ff3c0000.i2c
  2603     42:          0          0          0          0          0          0     GICv3  88 Level     ff3d0000.i2c
  2604     43:          0          0          0          0          0          0     GICv3 146 Level     ff650000.video-codec
  2605     44:          0          0          0          0          0          0     GICv3 145 Level     ff650000.video-codec
  2606     45:          0          0          0          0          0          0     GICv3 147 Level     ff650800.iommu
  2607     46:          0          0          0          0          0          0     GICv3 148 Level     ff660000.video-codec
  2608     47:          0          0          0          0          0          0     GICv3 149 Level     ff660480.iommu
  2609     48:          0          0          0          0          0          0     GICv3  87 Level     ff680000.rga
  2610     53:      22636          0          0          0          0          0     GICv3 151 Level     ff8f3f00.iommu, ff8f0000.vop
  2611     54:          0          0          0          0          0          0     GICv3 150 Level     ff903f00.iommu, ff900000.vop
  2612     55:          0          0          0          0          0          0     GICv3  75 Level     ff914000.iommu
  2613     56:          0          0          0          0          0          0     GICv3  76 Level     ff924000.iommu
  2614     57:          1          0          0          0          0          0     GICv3  55 Level     ff940000.hdmi, dw-hdmi-cec
  2615     58:          0          0          0          0          0          0     GICv3  52 Level     panfrost-job
  2616     59:          0          0          0          0          0          0     GICv3  53 Level     panfrost-mmu
  2617     60:          4          0          0          0          0          0     GICv3  51 Level     panfrost-gpu
  2618     69:       2949          0          0          0          0          0  rockchip_gpio_irq   3 Edge      brcmf_oob_intr
  2619     70:         13          0          0          0          0          0  rockchip_gpio_irq   4 Edge      host_wake
  2620     73:          0          0          0          0          0          0  rockchip_gpio_irq   7 Edge      fe320000.mmc cd
  2621    119:          0          0          0          0          0          0  rockchip_gpio_irq  21 Level     rk808
  2622    226:          1          0          0          0          0          0     GICv3  59 Level     rockchip_usb2phy
  2623    227:          1          0          0          0          0          0     GICv3  63 Level     rockchip_usb2phy
  2624    228:          0          0          0          0          0          0     GICv3 137 Level     xhci-hcd:usb5
  2625    229:          0          0          0          0          0          0     GICv3 142 Level     xhci-hcd:usb7
  2626    235:          0          0          0          0          0          0     rk808   5 Edge      RTC alarm
  2627    240:          0          0          0          0          0          0   ITS-MSI   0 Edge      PCIe PME, aerdrv
  2628    241:          0         18          0          0          0          0   ITS-MSI 524288 Edge      nvme0q0
  2629    242:       1537          0          0          0          0          0   ITS-MSI 524289 Edge      nvme0q1
  2630    243:          0       1235          0          0          0          0   ITS-MSI 524290 Edge      nvme0q2
  2631    244:          0          0       1338          0          0          0   ITS-MSI 524291 Edge      nvme0q3
  2632    245:          0          0          0       1545          0          0   ITS-MSI 524292 Edge      nvme0q4
  2633    246:          0          0          0          0       7291          0   ITS-MSI 524293 Edge      nvme0q5
  2634    247:          0          0          0          0          0       3222   ITS-MSI 524294 Edge      nvme0q6
  2635    IPI0:     31350      66798      69689      62231      15073      27992       Rescheduling interrupts
  2636    IPI1:     45584      28300      24572      27532      71882      65167       Function call interrupts
  2637    IPI2:         0          0          0          0          0          0       CPU stop interrupts
  2638    IPI3:         0          0          0          0          0          0       CPU stop (for crash dump) interrupts
  2639    IPI4:         0          0          0          0          0          0       Timer broadcast interrupts
  2640    IPI5:       318        269        292        259        745        578       IRQ work interrupts
  2641    IPI6:         0          0          0          0          0          0       CPU wake-up interrupts
  2642    Err:          0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
bernard@rockpi-4c:~$ ^C
Edited by Werner
Add spoiler
Two options:
  • use -u instead of -U go get a nice and shiny URL from a paste service which will provide all the data
  • increase the buffer size of your by about 2000 lines
Also note that it is good practice to use the CODEgrafik.png tag to increas readability and if your code is longer also cascade into SPOILER grafik.png
Regardless which kernel you use (4.4 legacy or 5.8 current) CONFIG_SND_SOC_ES8316 is present, either as module or built-in.
  • Werner changed the title to Rock pi 4 c no sound via audio jack
indeed in the /boot/config-5.8.13-rockchip64
CONFIG_SND_SOC_ES8316 is present but why no sound on the jack and in the output device its Internal audio sound and not ES_8316
how to activate this jack
Thank you
I put the url of the armbianmonitor -u command below
http://ix.io/2AB2
Hello
I would be really happy if you could explain to me how to install the patch because I tried to install it but already the extension is different (DTB instead of DTS) and when it wants to install it I end up with several error
So my problem is still not solved
Thank you for your attention
And?
Since you might find something else not working (for you), make sure to read those links below, before beeing more upset and make us more support costs:
https://forum.armbian.com/topic/13721-nanopc-t4-usb-type-c-port-doesnt-work-with-buster-current-5431
https://forum.armbian.com/topic/15232-rock-pi4c/
If you need personal attention:
https://github.com/armbian/build#support
If you want to support project you have benefits from:
https://forum.armbian.com/subscriptions/
https://docs.armbian.com/Process_Contribute/
https://armbian.atlassian.net/browse/AR
