add wifi driver Ralink_RT5572 rt2800usb
Guest sandmen
Gent's
currently I run Igor's Debian Image on a BananaPi (kernel 3.4.105).
I want to add the wifi driver for Ralink_RT5527.
What is to do?
Here my thoughts,
- install header's
- pull sunxi-kernel
- copy config from running kernel
- make menuconfig
- add the driver
- make
correct ?
Regards
No. Everything is prepared until:
"Get driver source & type make ARCH=arm
From there you are on your own. I can guarantee that the driver will work. Install part is also on your own / from the driver if exits.
P.S.
But there is a driver already on the system:
rt2500usb  rt2800lib  rt2800usb  rt2x00lib  rt2x00usb
Guest sandmen
modprobe rt2800usb is loading, and usbcore say's register device.
But nothing more. :-(
No wifi device available.
iw list is empty...
Any hints? ralink-firmware is installed.
Same here.
"lshw", "lsusb -t" and dmesg see the device recognized but no driver is applied. Firmware-Ralink package is also installed.
Device output from "lsusb" is "Bus 002 Device 005: ID 148f:5572 Ralink Technology, Corp. RT5572 Wireless Adapter".
Haven't looked at the kernelconfig yet, could it be a old version of the driver?
I have currently an edimax usb wifi dongle rt8192cu and the mentioned ralink one attached.
lsmod:
root@cubieboard2:~# lsmod
cpufreq_userspace       3524  0
snd_usb_audio          99287  0
snd_hwdep               5811  1 snd_usb_audio
snd_usbmidi_lib        17859  1 snd_usb_audio
snd_seq_midi            4682  0
snd_seq_midi_event      6339  1 snd_seq_midi
snd_seq                51584  2 snd_seq_midi_event,snd_seq_midi
snd_rawmidi            20567  2 snd_usbmidi_lib,snd_seq_midi
snd_seq_device          6371  3 snd_seq,snd_rawmidi,snd_seq_midi
8192cu                454584  0
bnep                   14462  2
sunxi_ir                4037  0
hidp                   17640  0
rfcomm                 58686  0
hci_uart               25000  0
bluetooth             264185  12 bnep,hidp,hci_uart,rfcomm
"dmesg | grep usb":
[    0.392114] usbcore: registered new interface driver usbfs
[    0.396439] usbcore: registered new interface driver hub
[    0.400615] usbcore: registered new device driver usb
[    0.435010] [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG
[    0.438802] [sw_hcd0]: usb host driver initialize........
[    0.443020] [sw_hcd0]: open_usb_clock
[    0.468245] [sw_hcd0]: platform is usb host
[    0.513155] [sw_hcd0]: sw_usb_host0_disable start
[    0.530011] [sw_hcd0]: close_usb_clock
[    0.532475] [sw_hcd0]: sw_usb_host0_disable end
[    1.428009] usbcore: registered new interface driver usb-storage
[    1.436526] usbcore: registered new interface driver ums-alauda
[    1.441526] usbcore: registered new interface driver ums-cypress
[    1.446550] usbcore: registered new interface driver ums-datafab
[    1.451721] usbcore: registered new interface driver ums_eneub6250
[    1.457175] usb 2-1: new high-speed USB device number 2 using sw-ehci
[    1.462141] usbcore: registered new interface driver ums-freecom
[    1.467078] usbcore: registered new interface driver ums-isd200
[    1.472182] usbcore: registered new interface driver ums-jumpshot
[    1.477032] usbcore: registered new interface driver ums-karma
[    1.482119] usbcore: registered new interface driver ums-onetouch
[    1.487148] usbcore: registered new interface driver ums-realtek
[    1.492059] usbcore: registered new interface driver ums-sddr09
[    1.496990] usbcore: registered new interface driver ums-sddr55
[    1.501815] usbcore: registered new interface driver ums-usbat
[    1.761780] usbcore: registered new interface driver usbhid
[    1.764604] usbhid: USB HID core driver
[    1.939510] usb 2-1.1: new high-speed USB device number 3 using sw-ehci
[    2.144246] usb 2-1.2: new full-speed USB device number 4 using sw-ehci
[    2.261712] input: C-Media USB Headphone Set   as /devices/platform/sw-ehci.1/usb2/2-1/2-1.2/2-1.2:1.3/input/input1
[    2.273398] generic-usb 0003:0D8C:000C.0001: input,hidraw0: USB HID v1.00 Device [C-Media USB Headphone Set  ] on usb-sw-ehci-1.2/input3
[    7.238643] ERR: script_parser_fetch usb_controller_type failed
[    7.770111] usbcore: registered new interface driver rtl8192cu
[    7.874895] usbcore: registered new interface driver snd-usb-audio
[  549.444389] usb 2-1.3: new high-speed USB device number 5 using sw-ehci
[  789.076039] usb 2-1.3: USB disconnect, device number 5
[89774.141031] usb 2-1.3: new high-speed USB device number 6 using sw-ehci
"uname -a":
Linux cubieboard2 3.4.109-sun7i #5 SMP PREEMPT Wed Oct 14 20:33:00 CEST 2015 armv7l armv7l armv7l GNU/Linux
Edited by kernelpaniclite
Thank you for your interest:-)
rt2800usb              13671  0
rt2800lib              48693  1 rt2800usb
rt2x00usb              11033  1 rt2800usb
rt2x00lib              41780  3 rt2x00usb,rt2800lib,rt2800usb
mac80211              245765  3 rt2x00lib,rt2x00usb,rt2800lib
sg                     23765  0
snd_seq_midi            4682  0
8192cu                454584  0
bnep                   14462  2
sunxi_ir                4037  0
hidp                   17640  0
rfcomm                 58686  0
hci_uart               25000  0
root@cubieboard2:~# lsusb
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 006: ID 148f:5572 Ralink Technology, Corp. RT5572 Wireless Adapter
Bus 002 Device 004: ID 0d8c:000c C-Media Electronics, Inc. Audio Adapter
Bus 002 Device 003: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 002 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@cubieboard2:~# lsusb -t
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=sw-ohci/1p, 12M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=sw-ehci/1p, 480M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=sw-ohci/1p, 12M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=sw-ehci/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
        |__ Port 2: Dev 4, If 0, Class=Audio, Driver=snd-usb-audio, 12M
        |__ Port 2: Dev 4, If 1, Class=Audio, Driver=snd-usb-audio, 12M
        |__ Port 2: Dev 4, If 2, Class=Audio, Driver=snd-usb-audio, 12M
        |__ Port 2: Dev 4, If 3, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 3: Dev 6, If 0, Class=Vendor Specific Class, Driver=, 480M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=sw_hcd_host0/1p, 480M
root@cubieboard2:~# dmesg
[  765.625913] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  769.933587] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  780.671412] wlan0: no IPv6 routers present
[169986.157307] usbcore: registered new interface driver rt2800usb
Nothing more:-(
Okay, This exact ID 148f:5572 is not supported by this driver in this kernel version, I checked kernel sources.
Next you may try this solution: https://unix.stackexchange.com/questions/234315/rt5572-shown-in-lsusb-but-not-iwconfig
Minimum kernel version supporting this chip is 3.10.
Looking at module commit history, you may need to compile new module version (which probably won't work due to possible changes in other modules in kernel wireless stack), upgrade to mainline kernel (depends on your use case) or buy different wireless adapter (easiest solution).
I like this idea of badrianiulian's hardware-mod on R1 ( http://forum.armbian.com/index.php/topic/372-hardware-mod-bpi-r1/) and looked for that chip/driver.
http://elinux.org/RPi_USB_Wi-Fi_Adapters
    RT5572 USB ID 148f:5572 native driver available in Kernel 3.10.36+ (rt2800usb)
    uname -a
       3.4.108schaschr1+ #2 SMP PREEMPT Thu Oct 22 08:59:09 CEST 2015 armv7l GNU/Linux
http://www.ctheroux.com/category/rt5572/
#patched version for older DPO_RT5572_LinuxSTA_2.6.0.1_20120629.tar.bz2.bz2
#I think no need to patch (first) patches
        wget https://dl.dropboxusercontent.com/u/11876059/DPO_RT5572_LinuxSTA_2.6.1.3_20121022.tar.gz
        tar -xvf DPO_RT5572_LinuxSTA_2.6.1.3_20121022.tar.gz
        cd DPO_RT5572_LinuxSTA_2.6.1.3_20121022
        patch
           no need to patch ( os/linux/config.mk os/linux/usb_main_dev.c), allready up-to-date
           pathed common/cmm_mac_usb.c
        make / make install (compile ok)
        modprobe rt5572sta
i do not have hardware yet, but this should work...
hi,
only for info:
The DPO_RT5572_LinuxSTA_2.6.1.3_20121022.tar.gz / rt5572sta.ko -stuff does not work with sunxi-3.4.10x-kernel.
I got this "ralink rt5572" on kernel 3.4.10x to work with driver backports:
echo "see:https://backports.wi....php/Main_Page"
wget https://www.kernel.o....11.8-1.tar.bz2
tar xvf backports-3.12.8-1.tar.xz
cd backports-3.12.8-1
make defconfig-wifi
time make -J2
echo "BACKUP YOUR old 3.4.10x-modules in /lib/modules/3.4.10xy /lib/modules/3.4.10xy_backup to  if you want to switch back...ok?"
read
make install
reboot
root@Dev:~# modinfo rt2800usb | grep "version\|5572"
version:        backported from Linux (v3.12.8-0-g97f15f1) using backports v3.12.8-1-0-geb41fad
version:        2.3.0
srcversion:     D0035750636933A8C0E52C5
alias:          usb:v148Fp5572d*dc*dsc*dp*ic*isc*ip*
vermagic:       3.4.108schaschr1+ SMP preempt mod_unload modversions ARMv7 p2v8
regards
Hi all,
I have this configuration:
uname -a
Linux orangepione 3.4.110-sun8i #18 SMP PREEMPT Tue Mar 8 20:03:32 CET 2016 armv7l GNU/Linux
and also Ralink RT5572 and I can confirm, that driver DPO_RT5572_LinuxSTA_2.6.1.3_20121022 does not work for me either...
So I have tried to backport the rt2800usb drivers as pschasch proposed and I could get the same result:
modinfo ./rt2800usb.ko | grep "version\|5572"
version:        2.3.0
vermagic:       3.4.110 SMP preempt mod_unload modversions ARMv7 p2v8
Unfortunately, the module cannot be loaded and dmesg sais:
rt2800usb: disagrees about version of symbol rt2800_config_erp
rt2800usb: Unknown symbol rt2800_config_erp (err -22)
and many other symbols...
After a research, I have read, that this can happen when the module is compiled againt another Kernel version or when the configuration differs.
I have used the linux-headers-3.4.110-sun8i that came within the image and executed make scripts before compiling backports. My understanding of backports was, that it should take the .config file from /usr/src/linux-headers-... and do the configuration automatically...
Do you have any idea, where could be the problem?
Thank you very much for any help!
Regards.
Resolved!
I took this modified driver: https://github.com/shaun2029/rt5572sta(Btw, thank you so much shaun2029!)
Then you have to in ./include/os/rt_linux.h change the datatypes "kuid_t" to "uid_t" and "kgid_t" to "gid_t" (this is possibly valid only for kernels >= 3.4.0)
And then in driver's root just:
make -j4 ARCH=arm
make install
modprobe rt5572sta
Best regards
Hello Ikrk,
thanks for info!
The backported driver I compiled on my R1, but before I compiled the 3.4.108-git-kernel version too on my R1.
My backported driver works good (19 day uptime R1 as only AP) , but I got a lot of driver-messages in my logs.
I will try/test the shaun2029-driver too,
Did you compile on R1 or crosscompile by igors-toolchain?
@igor
can I somehow compile your 3.4.110-R1-kernel-version with all you patches on R1?
Does it support csi-cam?
regards
Hello Igor,
thanks for answering!
OK, I am not R1-ubuntu , I hoped I could clone a git and test it without your graet tooltchain.
regards
Hi pschasch,
as mentioned before, I have Orange Pi One with 3.4.110-sun8i kernel and I compiled directly on the device. I did not try to crosscompile.
Regards
Hello, i am also trying to use the "Ralink Technology, Corp. RT5572 Wireless Adapter", as suggested by Ikrk.
I have this:
$ lsmod
disp_ump                 850  0
mali_drm                2611  1
drm                   214553  2 mali_drm
cpufreq_userspace       3540  0
bridge                 76954  0
sg                     23918  0
rt5572sta             775499  0
spidev                  6339  0
mali                  112222  0
ump                    61778  4 mali,disp_ump
8021q                  18659  0
garp                    6084  1 8021q
stp                     2028  2 garp,bridge
llc                     5421  3 stp,garp,bridge
sunxi_ir                4044  0
hidp                   17740  0
rfcomm                 58820  0
hci_uart               25074  0
bluetooth             265449  5 hidp,hci_uart,rfcomm
$ iwconfig
lo        no wireless extensions.
br0       no wireless extensions.
tunl0     no wireless extensions.
ra0       Ralink STA
eth0      no wireless extensions.
bond0     no wireless extensions.
and
$ iwlist scan
lo        Interface doesn't support scanning.
br0       Interface doesn't support scanning.
tunl0     Interface doesn't support scanning.
ra0       Failed to read scan data : Network is down
eth0      Interface doesn't support scanning.
bond0     Interface doesn't support scanning.
# ip link set dev ra0 up
RTNETLINK answers: Operation not permitted
Any ideas?
