I don't know if you can see originals before edit, but it was meant to be the not working original code
and the now working code until i copied them and realised it was now the same.
ok, for some reason, i changed the code in wireless-settings.conf and connected, i rebooted to make sure it was still working
it failed the first time then worked the second time, now i see wicd keeps renewing the contents with something old,
even details of a hotspot i tried with my phone.
I have it working, I'm using it to type this.
Where is wicd getting the data from to delete any changes i make. it can't just be the current available networks,
it is putting details from a network that hasn't been active for a week.
how do i tell wicd to shutup and do what i tell it?.
disconnect, connect, FAIL.
i managed to connect manually through terminal - wpa_supplicant earlier today and it worked, once.
in other distros built ontop of 5.14 & 5.15, the built-in wifi(opipc+) does not work, however my usb dongle works fine
and with wpa.
my usb dongle does not work in 5.14>5.16.
i don't want to use it anyway.
is there a way to remove wicd completely and reinstall it without tears?.
There most likely is, but I doubt you'll get the point. Before flooding the forum with your rants, please show some respect for the hard-working Armbian team providing an excellent product.
@igor, a major if not the source of Armbian,  has given you precise instructions. Follow them and succeed.
sudo systemctl disable wicd.service
this will disable wicd from starting up after boot
