aprayoga Posted November 12, 2020 Posted November 12, 2020 To continue discussion from Helios64 Support On 11/9/2020 at 4:39 PM, ebin-dev said: @aprayoga I am still interested in controlling the power of rail A and B. You mentioned that the power is controlled by the bootloader, but that the delay would be user configurable sometime. I would like to almost always power off rail A: In my use case rail A contains two hard disks supposed to alternatively back up the content of the SSDs in rail B - i.e once a day or even only once a week. The remaining time it would be beneficial to power off the hard drives in order to eliminate start/stop cycles and to make those drives inaccessible (protection against malware). Would there be a solution to make this user configurable - i.e by setting the delay to a very large number ? Expand Currently there is no plan to support to disable the power but it's interesting to know such use case. If we implemented this feature, you would need to go u-boot prompt to enable and disable the power. would this acceptable for you? Under Linux device tree, the power rail declared as regulator node with regulator-always-on property. This prevent kernel (and user) to turn off the regulator. Unless we are able to create device node for the SATA port, to act as consumer of the regulator, we can't remove the regulator-always-on property.
ebin-dev Posted November 12, 2020 Posted November 12, 2020 On 11/12/2020 at 4:06 AM, aprayoga said: Currently there is no plan to support to disable the power but it's interesting to know such use case. If we implemented this feature, you would need to go u-boot prompt to enable and disable the power. would this acceptable for you? Expand Actually I just picked up a suggestion to completely power off rails A and/or B by @gprovost three months ago ( see here ). It would be really appeciated if you implemented this feature. Once it is implemented I would try to seek a way to configure u-boot from linux such that the power to rails A and/or B is enabled/disabled upon the next reboot.
ebin-dev Posted December 20, 2020 Posted December 20, 2020 @aprayoga @gprovost May I ask if there is any progress regarding powering on/off rails A and/or B ?
aprayoga Posted January 8, 2021 Author Posted January 8, 2021 @ebin-dev, unfortunately there is no progress.
ebin-dev Posted January 8, 2021 Posted January 8, 2021 On 1/8/2021 at 3:32 AM, aprayoga said: @ebin-dev, unfortunately there is no progress. Expand Sad. Gauthier himself advertised this feature: "Also with Helios64 you will be able to control the HDD power rails (rail A and rail B ) if you want to completely power off the drives. Could be useful in some use cases."
allen--smithee Posted January 9, 2021 Posted January 9, 2021 @ebin-dev I notice that the effects of the advertisement are let to the free interpretation of the clients, but it is always instructive. The same configuration as you I use 3 SSD for separate services (Sync, Cloud, Server) and two hard disks for archiving. My two disks are both 10 years old and make a shitty noise but it's still spinning for the moment. I put and remove the disk from unit to avoid the noise of the whole house, if I can let the disks in the unit and just run a special reboot for maintenance this is not a problem for me. @aprayoga if you can create a parameter on the boot loader to choose the option like power rails I will be the happiest of your customers, but if I can learn how to do it myself I will be the happiest user
allen--smithee Posted January 13, 2021 Posted January 13, 2021 I'm missing a universe of understanding I lack knowledge Please what am I missing? Can i have pin 32 & 33 HW schematic? Reveal hidden contents cat /sys/kernel/debug/regulator/regulator_summary vcc12v_dcin 3 2 0 unknown 12000mV 0mA 12000mV 12000mV f8000000.pcie-vpcie12v 1 0mA 0mV 0mV vcc12v_dcin_bkup 5 4 0 unknown 12000mV 0mA 12000mV 12000mV vcc12v_hdd 1 0 0 unknown 12000mV 0mA 12000mV 12000mV vcc5v0_hdd 1 0 0 unknown 5000mV 0mA 5000mV 5000mV power_hdd_a 1 0 0 unknown 0mV 0mA 0mV 0mV power_hdd_b 1 0 0 unknown 0mV 0mA 0mV 0mV Reading Kernel User cat /sys/kernel/debug/regulator/regulator_summary cat /sys/kernel/debug/pinctrl/*/gpio-ranges cat /sys/kernel/debug/pinctrl/*/pinmux-pins cat /sys/kernel/debug/pinctrl/*/pinmux-functions cat /sys/kernel/debug/pinctrl/*/pingroups cat /sys/kernel/debug/pinctrl/*/pinconf-pins cat /sys/kernel/debug/pinctrl/*/pinconf-groups Reading U-boot u-boot-helios64/doc/README.gpio u-boot-helios64/doc/README.bootmenu u-boot-helios64/drivers/power/regulator/regulator_common.c u-boot-helios64/include/power/regulator.h u-boot-helios64/arch/arm/dts/rk3399-helios.dts // SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (c) 2020 Aditya Prayoga (aditya@kobol.io) */ /dts-v1/; #include <dt-bindings/input/linux-event-codes.h> #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/input/input.h> #include <dt-bindings/usb/pd.h> #include "rk3399.dtsi" #include "rk3399-opp.dtsi" / { model = "Helios64"; compatible = "kobol,helios64", "rockchip,rk3399"; <...> /* Rail A Disk Down 1-3 */ power_hdd_a: power-hdd-a { compatible = "regulator-fixed"; enable-active-high; gpio = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; /* gpio 1-0 pin 32 */ pinctrl-names = "default"; pinctrl-0 = <&hdd_a_power>; regulator-name = "power_hdd_a"; regulator-always-on; regulator-boot-on; startup-delay-us = <2500000>; }; /* Rail B Disk Up 4-5 */ power_hdd_b: power-hdd-b { compatible = "regulator-fixed"; enable-active-high; gpio = <&gpio1 RK_PA1 GPIO_ACTIVE_HIGH>; /* gpio 1-1 pin 33 */ pinctrl-names = "default"; pinctrl-0 = <&hdd_b_power>; regulator-name = "power_hdd_b"; regulator-always-on; regulator-boot-on; startup-delay-us = <2500000>; }; <...> gpio-keys { compatible = "gpio-keys"; autorepeat; pinctrl-names = "default"; pinctrl-0 = <&pwrbtn>, <&user1btn>, <&wake_on_lan>; /* wol { debounce-interval = <100>; gpios = <&gpio0 RK_PB0 GPIO_ACTIVE_LOW>; label = "Wake-On-LAN"; linux,code = <KEY_WAKEUP>; wakeup-source; }; */ <...> }; }; &pinctrl { <...> power { hdd_a_power: hdd-a-power { rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; }; hdd_b_power: hdd-b-power { rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; }; <...> }; }; <..end> Path : /u-boot-helios64/board/kobol/helios64/helios64.c <...> #ifdef CONFIG_LAST_STAGE_INIT static void auto_power_enable(void) { struct gpio_desc *enable, *clock; if (gpio_hog_lookup_name("AUTO_ON_EN_D", &enable)) { debug("Fail to get AUTO_ON_EN_D\n"); return; } if (gpio_hog_lookup_name("AUTO_ON_EN_CLK", &clock)) { debug("Fail to get AUTO_ON_EN_CLK\n"); return; } dm_gpio_set_value(enable, 1); dm_gpio_set_value(clock, 1); mdelay(10); dm_gpio_set_value(clock, 0); } static void pcie_reset(void) { ofnode node; struct gpio_desc reset_gpio; node = ofnode_path("/pcie@f8000000"); if (!ofnode_valid(node)) { debug("%s: no /pcie@f8000000 node\n", __func__); return; } if (gpio_request_by_name_nodev(node, "ep-gpios", 0, &reset_gpio, GPIOD_IS_OUT)) { debug("%s: could not find a /config/sysreset-gpio\n", __func__); return; } m_gpio_set_value(&reset_gpio, 0); mdelay(1000); //dm_gpio_set_value(&reset_gpio, 1); gpio_free_list_nodev(&reset_gpio, 1); } int last_stage_init(void) { auto_power_enable(); /* Give some extra time for HDD to spin up */ //mdelay(6000); //pcie_reset(); #ifdef CONFIG_PCI //pci_init(); //mdelay(2000); scsi_scan(true); //mdelay(2000); #endif return 0; } #endif <...end>
aprayoga Posted January 14, 2021 Author Posted January 14, 2021 (edited) @allen--smithee if you need to modify the bootloader, you can start from these lines https://github.com/armbian/build/blob/master/patch/u-boot/u-boot-rockchip64-mainline/add-board-helios64.patch#L1671-L1687 You can add parameter checking there. Maybe check certain U-Boot environment variable, maybe check for certain file in the filesystem. You could also remove it completely and modify /boot/boot.scr instead, to enable/disable the HDD power. Another thing to explore, you could remove the afromentioned u-boot function and also remove the power rail nodes from linux device tree https://github.com/armbian/build/blob/master/patch/kernel/rockchip64-current/add-board-helios64.patch#L239-L259 and then when you need to enable it, just access the gpio from sysfs. Edited January 14, 2021 by aprayoga 2
