No Remotedesktop screen after Login
Go to solution Solved by Igor,
hi to all,
i try to use the remotedesktop on my armbian orange pi zero.
for now i have done the first login with putty, then this commands.
te, if installed, the packages
- sudo apt-get purge vnc4server
- sudo apt-get purge  tightvnc
- sudo apt-get purge xrdp
sudo apt-get install tightvncserver sudo apt-get install xrdp
- sudo apt-get install tightvncserver
- sudo apt-get install xrdp
- reboot
but when i now use remotedesktop to connect i just see a screen.
any idea what i forgot or have done wrong?
photos one putty and the other blank remotedesktop and one with massage "remote desktop connection problem giving up some problem"
during the first start i change the pw and add new user, all this i try for login without luck :-(
You could try with x11vnc.
To install
sudo apt install x11vnc
To run
x11vnc -usepw
To view I use xvncviewer.
And stop using apt-get. It's 2020. :)
  • Solution
Did you install desktop?
It was the little progress bar at the bottom (with apt) that won me over finally.  :D
Hi folks,
thank you again everything is running fine.
my mistake i expect that desktop is already installed
