Problems with Zram on H2/3/5 boards - zram: Decompression failed! err=-22
Hammy
Go to solution Solved by Icenowy,
Armbianmonitor:
Good evening,
I ran into some problems with sbc-bench on a couple of Allwinner boards Orange Pi Zero, Orange Pi Zero+, Orange Pi One and Nanopi Neo 2 spcifically. The 7 Zip benchmark causes the following error:
./sbc-bench.sh: Zeile 611:  4206 Bus-Zugriffsfehler      "${SevenZip}" b >> ${TempLog}
Most likely due to a problem with the ZRam:
This happens on all boards under Debian and focal with different SD cards and power supplies. The benchmark ran previously on this setups without any issues – unfortunately I don’t know when it stopped working and hence cannot narrow down the change that caused the problem.
The benchmark results and armbianmonitor output from the Orange Pi one as an example:
http://ix.io/2EPZ
http://ix.io/2ES2
Is this a known issue? Is there a solution?
Daniel
Thanks for the info, is there any work around?
Switching to zstd caused the same error and crashed the board while benchmarking. After a reboot: http://ix.io/2F3t  - Interestingly it says:
### Activated 1 lzo-rle zram swap devices with 491 MB each
While
root@orangepizero:~# zramctl
NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram1 zstd        491,6M    4K    58B    4K       4 [SWAP]
/dev/zram0 zstd           50M  1,4M 184,1K  572K       4 /var/log
Daniel
