J.M. Posted November 25, 2020 Posted November 25, 2020 Hi, I need to use the i2c in the u-boot stage. I've added a patch that enables this i2c bus in the device-tree, and when I run this command (just for example): sudo i2cset -y 2 0x1b 0x1 0xf AFTER the boot stage it seem to work. However when I try this command IN THE boot stage, I get: Unknown command 'i2cset' - try 'help'. 1. I guess I'm trying to use 'i2cset' in a too early stage - any idea how to control the i2c in the u-boot stage or how to make 'i2cset' available at the u-boot stage ? 2. Since 'i2cset' doesn't work in the u-boot stage, I don't know if the i2c is enabled at this stage (I know it's enabled after boot) - how can I check it ? Thanks, Joseph
Werner Posted November 25, 2020 Posted November 25, 2020 This is not a supported board. Therefore the support request is invalid.
