helios4noob Posted December 6, 2020 Posted December 6, 2020 As the title states I already have software raid setup on my NAS. I'm currently running OMV 4 and I'd like to do a fresh install of the latest Debian image and OMV 5. I do not want to lose my data and would like to simply re-mount my drives. Is this possible? Also if I mess up and I'm unable to mount the raid/volumes, could I create an image of my current micro sd card and simply reflash it back onto the card and have everything as it was?
SIGSEGV Posted December 6, 2020 Posted December 6, 2020 If you have a second microSD, you can flash the new OS there and keep your old microSD as backup - taking an image of the microSD is possible too. Use the dd command. If our information is already on the software raid - you should be able to back up and remount the drives without issues. I don't use OMV, but you should be able set it up again with out issue.
lanefu Posted December 6, 2020 Posted December 6, 2020 OMV has a plugin for backing up configutation. Look for that and save your setting. Then you should he able to import that config with a new OMV install. Definitely do your research before. Id look on OMV forums for info about that
gprovost Posted December 14, 2020 Posted December 14, 2020 @helios4noob Yeah as recommended by @SIGSEGV you can do a fresh install a new microSD card and keep the old one as backup in case you need access something that is not on your RAID array. When you do a fresh install (Debian10 + OMV5), the system will automatically detect you previous raid ARRAY, you won't loose your data. Then you just need to mount it again via OMV interface.
helios4noob Posted May 12, 2021 Author Posted May 12, 2021 Hey guys - thanks for all the advise. I finally got around to updating my system and bought a separate SD card just in case. The only issue I had was enabling SMB (which I was unable to do because of the browser, switched the browser and I was able to enable SMB). It just worked - I had recorded all the settings (using my phone) and just set everything up that way it was. Works fine. I'll keep the other sd card as a backup just in case something gets funky! 1
