Origin:
https://armbian.atlassian.net/projects/AR/issues/AR-497
Description:
While it is possible to customize Armbian images at build time using the customize-image.sh script is not as comfortable as a chroot shell inside the image would be.
Destination:
https://github.com/armbian/build
Skills required:
Bash
06.12.2020 в 21:43, Werner сказал:
What do you want to say? Stop the execution of the build system and output the command line in the chroot environment?
And provide the user with the ability to enter commands, install or remove packages, fix system scripts?
1 час назад, Werner сказал:
Exactly. Once the user "exits" this chroot shell building continues.
This opportunity is necessary for professionals.
I have almost implemented such an opportunity to build and develop packages in a chroot environment.
And this remains only in my local branch for now.
First, we need to make a small adjustment in the logic of choosing goals.
  • Igor locked this topic
