Hanni3al Posted December 8, 2020 Posted December 8, 2020 (edited) I just updated my armbian kernel, I did it with: apt-cache search linux-generic to find the images and sudo apt-get install name of the image to install, the new kernel is in the /boot folder but if I restart It continues to start with the old one, and if I eliminate the old one it no longer starts. How do I select the new kernel to boot from it? i use orangepi+2e Edited December 8, 2020 by Hanni3al
Werner Posted December 8, 2020 Posted December 8, 2020 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
Igor Posted December 9, 2020 Posted December 9, 2020 16 hours ago, Hanni3al said: I just updated my armbian kernel, I did it with: apt-cache search linux-generic Armbian kernels are not updating that way. Debian (generic) kernels will work bad if at all. If you want to update to latest working (different) kernel use armbian-config -> system -> alternative kernels ... if you want to use generic kernels, you are anyway on your own. Why would you want to do that anyway?
