Hello Guys,
i'm positiv with Corona and in quaratine in my sleeping room while the rest of the family stays in the other rooms. So i can't backup my system with the MicroSD-Card...
Can i install the latest updates? 20.11.4? And the other stuff showing?
armbian-config/buster,buster 20.11.4 all [aktualisierbar von: 20.11.3]
linux-buster-root-current-helios64/buster 20.11.4 arm64 [aktualisierbar von: 20.11.3]
linux-dtb-current-rockchip64/buster 20.11.4 arm64 [aktualisierbar von: 20.11.3]
linux-image-current-rockchip64/buster 20.11.4 arm64 [aktualisierbar von: 20.11.3]
linux-u-boot-helios64-current/buster 20.11.4 arm64 [aktualisierbar von: 20.11.3]
openmediavault/usul,usul,usul,usul,usul,usul 5.5.19-1 all [aktualisierbar von: 5.5.18-1]
python3-lxml/stable,stable 4.3.2-1+deb10u2 arm64 [aktualisierbar von: 4.3.2-1+deb10u1]
salt-common/usul,usul,usul,usul,usul,usul 3002.2+ds-1 all [aktualisierbar von: 3002.1+ds-1]
salt-minion/usul,usul,usul,usul,usul,usul 3002.2+ds-1 all [aktualisierbar von: 3002.1+ds-1]
tzdata/stable-updates,stable-updates 2020e-0+deb10u1 all [aktualisierbar von: 2020d-0+deb10u1]
wsdd/usul,usul,usul,usul,usul,usul 0.6.2-1 all [aktualisierbar von: 0.5-1]
Thanks in advance.
Daniel
If you are unsure about updates and the system runs just fine at the moment then simply don't. Chances are low but this way you would not end up with a broken system if SHTF.
Sometime it chrashes...but don't know why. I guess i'm overload something. At the moment i got the time to do more on docker. Some apps didn't work at docker, so i had to install it on the system itself.
But you're right, never change a running system.
@dancgn if it crashes occasionally, you could try to use armbian-config to change the CPU speed / governor to 'performance' (armbian-config > System > CPU). I personally use 1800000 for CPU speed but I've seen 1200000 recommended elsewhere on the forum, YMMV.
