I'm running Armbian 20.11.6 Buster with Linux 5.9.14-mvebu, on a ClearFog Base.
This is (or will be) a production machine, so I'd like to keep it stable where possible. The default OpenSSH version in the stable Armbian build is 7.9.
openssh-server/stable,now 1:7.9p1-10+deb10u2 armhf
I need to update this package to a version greater than v8.1. By switching to the nightly Ambian build, I see the package is at version 8.4, but I don't know if running the nightly build is great on a production machine.
Before I do anything stupid, could I get some feedback about the recommended/safest way to upgrade this package?
Thank you :)
Tri
One solution (without upgrading) would be to wait one or two month. The next armbian release is scheduled for February and will basically include all features currently on -dev (nightly). At least for mvebu. So the openssh server should also be updated then.
Although I'm curious how you got openssh-server to 8.4 just by switching to nightly? I'm running a clearfogpro with nightly and still am at 7.9...
If you need it faster, you can adjust your apt sources to include an apt with a newer version of openssh.
It is upstream (Debian's), you may add buster-backports (read what are pros and cons: https://wiki.debian.org/Backports). As you can see there are two versions:
[root@PKOTHER ~]# apt show openssh-server -a
Package: openssh-server
Version: 1:8.4p1-2~bpo10+1
Priority: optional
Section: net
Source: openssh
Maintainer: Debian OpenSSH Maintainers <debian-ssh@lists.debian.org>
Installed-Size: 1,299 kB
Provides: ssh-server
Depends: adduser (>= 3.9), dpkg (>= 1.9.0), libpam-modules (>= 0.72-9), libpam-runtime (>= 0.76-14), lsb-base (>= 4.1+Debian3), openssh-client (= 1:8.4p1-2~bpo10+1), openssh-sftp-server, procps, ucf (>= 0.28), debconf (>= 0.5) | debconf-2.0, libaudit1 (>= 1:2.2.1), libc6 (>= 2.28), libcom-err2 (>= 1.43.9), libgssapi-krb5-2 (>= 1.17), libkrb5-3 (>= 1.13~alpha1+dfsg), libpam0g (>= 0.99.7.1), libselinux1 (>= 1.32), libssl1.1 (>= 1.1.1), libsystemd0, libwrap0 (>= 7.6-4~), zlib1g (>= 1:1.1.4)
Recommends: default-logind | logind | libpam-systemd, ncurses-term, xauth
Suggests: molly-guard, monkeysphere, ssh-askpass, ufw
Conflicts: sftp, ssh-socks, ssh2
Replaces: openssh-client (<< 1:7.9p1-8), ssh, ssh-krb5
Homepage: http://www.openssh.com/
Download-Size: 345 kB
APT-Sources: http://deb.debian.org/debian buster-backports/main armhf Packages
Description: secure shell (SSH) server, for secure access from remote machines
Version: 1:7.9p1-10+deb10u2
Priority: optional
Section: net
Source: openssh
Installed-Size: 1,240 kB
Depends: adduser (>= 3.9), dpkg (>= 1.9.0), libpam-modules (>= 0.72-9), libpam-runtime (>= 0.76-14), lsb-base (>= 4.1+Debian3), openssh-client (= 1:7.9p1-10+deb10u2), openssh-sftp-server, procps, ucf (>= 0.28), debconf (>= 0.5) | debconf-2.0, libaudit1 (>= 1:2.2.1), libc6 (>= 2.28), libcom-err2 (>= 1.43.9), libgssapi-krb5-2 (>= 1.17), libkrb5-3 (>= 1.13~alpha1+dfsg), libpam0g (>= 0.99.7.1), libselinux1 (>= 1.32), libssl1.1 (>= 1.1.1), libsystemd0, libwrap0 (>= 7.6-4~), zlib1g (>= 1:1.1.4)
Suggests: molly-guard, monkeysphere, rssh, ssh-askpass, ufw
Tag: admin::login, implemented-in::c, interface::daemon, network::server,
 protocol::ssh, role::program, security::authentication,
 security::cryptography, use::login, use::transmission
Download-Size: 319 kB
APT-Manual-Installed: no
APT-Sources: http://deb.debian.org/debian buster/main armhf Packages
Nightly builds are Ubuntu 20.10 based ... @Triceraflops it's confusing what you are asking when data we request are missing.
