I'm using Buster on the Neo3 but am having an issue using an MT7610 USB wireless NIC. I believe the 7610 is on the list of supported devices, so am not sure if I'm hitting an issue with the build?
Image Info: Armbian_20.11.10_Nanopineo3_buster_current_5.9.14.img.xz
Error message from dmesg:
[  385.819703] usb 4-1: new high-speed USB device number 4 using xhci-hcd
[  385.983275] usb 4-1: New USB device found, idVendor=0e8d, idProduct=7610, bcdDevice= 1.00
[  385.983299] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  385.983314] usb 4-1: Product: WiFi
[  385.983330] usb 4-1: Manufacturer: MediaTek
[  385.983344] usb 4-1: SerialNumber: 1.0
[  386.272183] usb 4-1: reset high-speed USB device number 4 using xhci-hcd
[  386.424849] mt76x0u 4-1:1.0: ASIC revision: 76100002 MAC revision: 76502000
[  386.431410] mt76x0u 4-1:1.0: mediatek/mt7610e.bin not found, switching to mediatek/mt7610u.bin
[  386.431488] mt76x0u 4-1:1.0: Direct firmware load for mediatek/mt7610u.bin failed with error -2
[  386.440783] mt76x0u: probe of 4-1:1.0 failed with error -2
[  386.440897] usbcore: registered new interface driver mt76x0u
The product ID seems to indicate its a 7610 (idProduct=7610), but there is a message about trying to load mt7610e.bin. Looking on the MediaTek site, it lists both the 7610e & 7610u chips under the title of MT7610.
Does the distribution only support the 7610u and I'm trying to use  a 7610e?
On the neo3 Armbian page, it lists a generic 7610 as being supported: https://www.armbian.com/nanopineo3/
Thanks in advance.
Nigel.
