Available software with Softy / armbian-config
What does determine the software available in softy, found in armbian-config?
I easily installed NextCloudPi (ncp) using softy on a Buster based image for the OrangePi4. However it lacked an up to date python version needed for Home Assistant.
I reinstalled Armbian using the Focal based image. Sadly softy did not list ncp as an option anymore.
So I am a bit puzzled what software to expect from softy.  The documentation ( https://docs.armbian.com/User-Guide_Armbian-Config/#software )  did not mention anything about availability.
Hand picking + base system dependency (Debian / Ubuntu this and that version) Otherwise - take a look https://github.com/armbian/config
That means you choose wrong base system. If software provider tells you, that you need Buster, it will work on Armbian Buster. If software provider tells you it only works on latest Ubuntu, you go for Armbian Focal, etc. If you want / need different version of package, use Google, or asks in forums only if you don't find the answer. Its identical to Debian / Ubuntu.
Software installation part of armbian-config is purely optional and its maintenance, which is 100% our private cost, is also very limited.
I didn't check recently, but it seems better than the official install, since at the end you get hassio and not just home-assistant :). I'll try it for my net install!
I am in the OpenHab camp :P so don't know much about HA and how Hass.io differs from this and that version. Their OS is anyway some minimal for running Docker and presumably the same Docker image we are installing here.
That makes a lot of sense.
On 2/2/2021 at 11:00 AM, jeanrhum said:
For this software, I prefer to use the docker official installation method with standard linux install over docker: https://www.home-assistant.io/docs/installation/docker/
That is a great option!
I've now successfully installed NCP and Hass.io (docker) through softy, on a freshly installed Armbian Buster image.
Thank you all for all the help!
