Antipatico78 Posted February 10, 2021 Posted February 10, 2021 Hi everyone, I have installed openmediavault and zfs. Since yesterday I have this error: Failed to execute command 'export PATH = / bin: / sbin: / usr / bin: / usr / sbin: / usr / local / bin: / usr / local / sbin; export LANG = C.UTF-8; zfs list -H -t snapshot -o name, used, refer 2> & 1 'with exit code' 1 ': The ZFS modules are not loaded. Try running '/ sbin / modprobe zfs' as root to load them. Click "show details" Error # 0: OMV \ ExecException: Failed to execute command 'export PATH = / bin: / sbin: / usr / bin: / usr / sbin: / usr / local / bin: / usr / local / sbin; export LANG = C.UTF-8; zfs list -H -t snapshot -o name, used, refer 2> & 1 'with exit code' 1 ': The ZFS modules are not loaded. Try running '/ sbin / modprobe zfs' as root to load them. in /usr/share/php/openmediavault/system/process.inc:182 Stack trace: # 0 /usr/share/omvzfs/Utils.php(438): OMV \ System \ Process-> execute (Array, 1) # 1 /usr/share/omvzfs/Utils.php(394): OMVModuleZFSUtil :: exec ('zfs list -H -t ...', Array, 1) # 2 /usr/share/openmediavault/engined/rpc/zfs.inc(194): OMVModuleZFSUtil :: getAllSnapshots () # 3 [internal function]: OMVRpcServiceZFS-> getAllSnapshots (Array, Array) # 4 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array (Array, Array) # 5 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV \ Rpc \ ServiceAbstract-> callMethod ('getAllSnapshots', Array, Array) # 6 / usr / sbin / omv-engined (537): OMV \ Rpc \ Rpc :: call ('ZFS', 'getAllSnapshots', Array, Array, 1) # 7 {main} Also I can no longer access the folders on the disks. Can someone help me?
Igor Posted February 10, 2021 Posted February 10, 2021 56 minutes ago, Antipatico78 said: Can someone help me? We have no knowledge of OMV internals. - Armbian works, otherwise you would not be able to install that software and ZFS on Armbian as well. I would say you should ask this on OMV forums. Here you need to provide at least: 56 minutes ago, Antipatico78 said: modprobe zfs This and the regular logs: armbianmonitor -u 1
wurmfood Posted February 10, 2021 Posted February 10, 2021 I suggest checking out this post and the solution a little below it, as it sounds like your same problem. 2
