Thought I'd download the latest image in the hope that it might be more stable ... kernel panic on reboot, booted second time and then whlst trying to update kernel panic again. This board seems to be so unstable it's bascially unuseable :(
|_| |_|\___|_|_|\___/|___/\___/   |_|
Welcome to Armbian 21.02.1 Buster with Linux 5.10.12-rockchip64
No end-user support: work in progress
System load:   24%              Up time:       1 min
Memory usage:  4% of 3.71G      IP:            195.198.8.121
CPU temp:      54°C             Usage of /:    6% of 29G
[ General system configuration (beta): armbian-config ]
helios@helios64:~$ apt-get update
Reading package lists... Done
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission denied)
W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission denied)
helios@helios64:~$ exit
logout
Armbian 21.02.1 Buster ttyS2
helios64 login: root
Password:
Last login: Fri Feb 19 16:23:53 GMT 2021 on ttyS2
 _   _      _ _            __   _  _
| | | | ___| (_) ___  ___ / /_ | || |
| |_| |/ _ \ | |/ _ \/ __| '_ \| || |_
|  _  |  __/ | | (_) \__ \ (_) |__   _|
System load:   18%              Up time:       2 min
CPU temp:      52°C             Usage of /:    6% of 29G
root@helios64:~# apt-get update
Get:1 http://security.debian.org buster/updates InRelease [65.4 kB]
Get:2 http://deb.debian.org/debian buster InRelease [122 kB]
Get:4 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Get:5 http://deb.debian.org/debian buster-backports InRelease [46.7 kB]
Get:6 http://security.debian.org buster/updates/main arm64 Packages [329 kB]
Get:7 http://security.debian.org buster/updates/main armhf Packages [328 kB]
Get:8 http://deb.debian.org/debian buster/main armhf Packages [10.5 MB]
Get:3 https://mirrors.dotsrc.org/armbian-apt buster InRelease [18.3 kB]
Get:9 https://mirrors.dotsrc.org/armbian-apt buster/main arm64 Packages [928 kB]
Get:10 https://mirrors.dotsrc.org/armbian-apt buster/main armhf Packages [778 kB]
Get:11 https://mirrors.dotsrc.org/armbian-apt buster/main arm64 Contents (deb) [13.4 MB]
Get:12 https://mirrors.dotsrc.org/armbian-apt buster/main armhf Contents (deb) [20.7 MB]
Get:13 http://deb.debian.org/debian buster-updates/main armhf Packages.diff/Index [5,656 B]
Get:14 http://deb.debian.org/debian buster-updates/main arm64 Packages.diff/Index [5,656 B]
Get:15 http://deb.debian.org/debian buster-updates/main arm64 Contents (deb).diff/Index [5,164 B]
Get:16 http://deb.debian.org/debian buster-updates/main armhf Contents (deb).diff/Index [5,164 B]
Get:17 http://deb.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB]
Get:18 http://deb.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB]
Get:19 http://deb.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [27.9 kB]
Get:20 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB]
Get:21 http://deb.debian.org/debian buster-backports/contrib armhf Packages.diff/Index [24.8 kB]
Get:22 http://deb.debian.org/debian buster-backports/contrib arm64 Packages.diff/Index [24.8 kB]
Get:23 http://deb.debian.org/debian buster-backports/contrib arm64 Contents (deb).diff/Index [20.9 kB]
Get:24 http://deb.debian.org/debian buster-backports/contrib armhf Contents (deb).diff/Index [19.4 kB]
Get:25 http://deb.debian.org/debian buster-updates/main armhf Packages 2021-02-07-1359.56.pdiff [2,328 B]
Get:26 http://deb.debian.org/debian buster-updates/main arm64 Packages 2021-02-07-1359.56.pdiff [2,291 B]
Get:27 http://deb.debian.org/debian buster-updates/main arm64 Contents (deb) 2021-02-07-1359.56.pdiff [11.8 kB]
Get:28 http://deb.debian.org/debian buster-updates/main armhf Contents (deb) 2021-02-07-1359.56.pdiff [11.9 kB]
Get:29 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-04-1402.43.pdiff [476 B]
Get:30 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-04-2001.58.pdiff [594 B]
Get:31 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-05-0200.10.pdiff [1,741 B]
Get:32 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-05-0800.01.pdiff [1,040 B]
Get:33 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-05-1405.08.pdiff [473 B]
Get:34 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-05-2000.51.pdiff [687 B]
Get:35 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-06-1404.54.pdiff [204 B]
Get:36 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-06-1959.41.pdiff [191 B]
Get:37 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-07-0159.49.pdiff [803 B]
Get:38 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-07-0759.53.pdiff [256 B]
Get:39 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-07-1359.56.pdiff [180 B]
Get:40 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-07-2004.03.pdiff [1,066 B]
Get:41 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-08-0201.53.pdiff [187 B]
Get:42 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-08-0800.00.pdiff [274 B]
Get:43 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-08-1400.04.pdiff [299 B]
Get:44 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-08-1959.50.pdiff [711 B]
Get:45 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-09-0159.52.pdiff [327 B]
Get:46 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-09-1359.56.pdiff [1,260 B]
Get:47 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-09-2000.45.pdiff [2,100 B]
Get:48 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-10-0159.55.pdiff [1,118 B]
Get:49 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-10-0759.42.pdiff [597 B]
Get:50 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-10-1359.42.pdiff [824 B]
Get:51 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-10-1959.58.pdiff [2,225 B]
Get:52 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-11-0159.46.pdiff [2,278 B]
Get:53 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-11-0759.49.pdiff [294 B]
Get:54 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-11-1400.04.pdiff [6,439 B]
Get:55 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-11-1959.46.pdiff [13.1 kB]
Get:56 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-12-0159.45.pdiff [1,800 B]
Get:57 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-12-0801.37.pdiff [188 B]
Get:58 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-13-0159.59.pdiff [4,182 B]
Get:59 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-13-1359.55.pdiff [932 B]
Get:60 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-14-1359.48.pdiff [206 B]
Get:61 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-14-2000.12.pdiff [199 B]
Get:62 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-15-0200.05.pdiff [191 B]
Get:63 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-16-1400.52.pdiff [2,043 B]
Get:64 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-16-2000.50.pdiff [2,562 B]
Get:65 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-17-0159.56.pdiff [2,647 B]
Get:66 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-17-0759.56.pdiff [1,412 B]
Get:67 http://deb.debian.org/debian buster-backports/main armhf Packages 2021-02-17-2000.05.pdiff [786 B]
Get:68 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-04-1402.43.pdiff [476 B]
Get:69 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-04-2001.58.pdiff [595 B]
Get:70 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-05-0200.10.pdiff [1,745 B]
Get:71 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-05-0800.01.pdiff [1,040 B]
Get:72 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-05-1405.08.pdiff [472 B]
Get:73 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-05-2000.51.pdiff [690 B]
Get:74 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-06-1404.54.pdiff [205 B]
Get:75 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-06-1959.41.pdiff [190 B]
Get:76 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-07-0159.49.pdiff [799 B]
Get:77 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-07-0759.53.pdiff [256 B]
Get:78 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-07-1359.56.pdiff [196 B]
Get:79 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-07-2004.03.pdiff [1,069 B]
Get:80 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-08-0201.53.pdiff [189 B]
Get:81 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-08-0800.00.pdiff [275 B]
Get:82 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-08-1400.04.pdiff [408 B]
Get:83 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-08-1959.50.pdiff [715 B]
Get:84 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-09-0159.52.pdiff [331 B]
Get:85 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-09-1359.56.pdiff [1,262 B]
Get:86 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-09-2000.45.pdiff [2,143 B]
Get:87 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-10-0159.55.pdiff [1,121 B]
Get:88 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-10-0759.42.pdiff [597 B]
Get:89 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-10-1359.42.pdiff [823 B]
Get:90 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-10-1959.58.pdiff [2,090 B]
Get:91 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-11-0159.46.pdiff [2,518 B]
Get:92 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-11-0759.49.pdiff [295 B]
Get:93 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-11-1400.04.pdiff [6,600 B]
Get:94 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-11-1959.46.pdiff [14.1 kB]
Get:95 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-12-0159.45.pdiff [910 B]
Get:96 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-12-0801.37.pdiff [188 B]
Get:97 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-13-1359.55.pdiff [928 B]
Get:98 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-14-1359.48.pdiff [206 B]
Get:99 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-14-2000.12.pdiff [203 B]
Get:100 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-15-0200.05.pdiff [193 B]
Get:101 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-16-1400.52.pdiff [2,044 B]
Get:102 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-16-2000.50.pdiff [2,557 B]
Get:103 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-17-0159.56.pdiff [2,613 B]
Get:104 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-17-0759.56.pdiff [1,416 B]
Get:105 http://deb.debian.org/debian buster-backports/main arm64 Packages 2021-02-17-2000.05.pdiff [785 B]
Get:106 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-04-1402.43.pdiff [208 B]
Get:107 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-05-0200.10.pdiff [289 B]
Get:108 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-05-0800.01.pdiff [546 B]
Get:109 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-05-1405.08.pdiff [197 B]
Get:110 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-05-2000.51.pdiff [88 B]
Get:111 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-06-1404.54.pdiff [8,655 B]
Get:112 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-07-0759.53.pdiff [520 B]
Get:113 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-07-2004.03.pdiff [221 B]
Get:114 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-08-0800.00.pdiff [5,192 B]
Get:115 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-08-1959.50.pdiff [353 B]
Get:116 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-09-0159.52.pdiff [373 B]
Get:117 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-09-1359.56.pdiff [292 B]
Get:118 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-09-2000.45.pdiff [424 B]
Get:119 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-10-0159.55.pdiff [948 B]
Get:120 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-10-0759.42.pdiff [262 B]
Get:121 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-10-1359.42.pdiff [1,933 B]
Get:122 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-10-1959.58.pdiff [525 B]
Get:123 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-11-0159.46.pdiff [2,215 B]
Get:124 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-11-1400.04.pdiff [384 kB]
Get:125 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-11-1959.46.pdiff [113 kB]
Get:126 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-12-0159.45.pdiff [4,533 B]
Get:127 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-12-0801.37.pdiff [193 kB]
Get:128 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-13-0159.59.pdiff [271 kB]
Get:129 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-13-1359.55.pdiff [501 B]
Get:130 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-14-1359.48.pdiff [32 B]
Get:131 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-14-2000.12.pdiff [166 B]
Get:132 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-15-0200.05.pdiff [68 B]
Get:133 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-16-1400.52.pdiff [10.4 kB]
Get:134 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-16-2000.50.pdiff [3,168 B]
Get:135 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-17-0159.56.pdiff [270 B]
Get:136 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-17-0759.56.pdiff [305 B]
Get:137 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2021-02-17-2000.05.pdiff [139 B]
Get:138 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-04-1402.43.pdiff [207 B]
Get:139 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-05-0200.10.pdiff [291 B]
Get:140 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-05-0800.01.pdiff [548 B]
Get:141 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-05-1405.08.pdiff [195 B]
Get:142 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-05-2000.51.pdiff [86 B]
Get:143 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-06-1404.54.pdiff [8,638 B]
Get:144 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-07-0759.53.pdiff [522 B]
Get:145 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-07-2004.03.pdiff [222 B]
Get:146 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-08-0800.00.pdiff [5,269 B]
Get:147 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-08-1959.50.pdiff [353 B]
Get:148 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-09-0159.52.pdiff [374 B]
Get:149 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-09-1359.56.pdiff [293 B]
Get:150 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-09-2000.45.pdiff [422 B]
Get:151 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-10-0159.55.pdiff [947 B]
Get:152 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-10-0759.42.pdiff [260 B]
Get:153 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-10-1359.42.pdiff [2,005 B]
Get:154 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-10-1959.58.pdiff [530 B]
Get:155 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-11-0159.46.pdiff [2,267 B]
Get:156 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-11-1400.04.pdiff [384 kB]
Get:157 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-11-1959.46.pdiff [116 kB]
Get:158 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-12-0159.45.pdiff [740 B]
Get:159 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-12-0801.37.pdiff [193 kB]
Get:160 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-13-1359.55.pdiff [497 B]
Get:161 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-14-1359.48.pdiff [32 B]
Get:162 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-14-2000.12.pdiff [163 B]
Get:163 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-15-0200.05.pdiff [68 B]
Get:164 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-16-1400.52.pdiff [10.4 kB]
Get:165 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-16-2000.50.pdiff [3,257 B]
Get:166 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-17-0159.56.pdiff [271 B]
Get:167 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-17-0759.56.pdiff [304 B]
Get:168 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2021-02-17-2000.05.pdiff [138 B]
Get:169 http://deb.debian.org/debian buster-backports/contrib armhf Packages 2021-02-11-1400.04.pdiff [558 B]
Get:170 http://deb.debian.org/debian buster-backports/contrib arm64 Packages 2021-02-05-1405.08.pdiff [836 B]
Get:171 http://deb.debian.org/debian buster-backports/contrib arm64 Packages 2021-02-11-1400.04.pdiff [558 B]
Get:172 http://deb.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2021-02-05-1405.08.pdiff [252 B]
Get:173 http://deb.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2021-02-11-1400.04.pdiff [1,901 B]
Get:174 http://deb.debian.org/debian buster-backports/contrib armhf Contents (deb) 2021-02-11-1400.04.pdiff [1,927 B]
Get:175 http://deb.debian.org/debian buster/main arm64 Packages [10.5 MB]
Get:176 https://mirrors.dotsrc.org/armbian-apt buster/buster-utils armhf Packages [7,475 B]
Get:177 https://mirrors.dotsrc.org/armbian-apt buster/buster-utils arm64 Packages [10.7 kB]
Get:178 https://mirrors.dotsrc.org/armbian-apt buster/buster-utils arm64 Contents (deb) [47.0 kB]
Get:179 https://mirrors.dotsrc.org/armbian-apt buster/buster-utils armhf Contents (deb) [8,999 B]
Get:180 https://mirrors.dotsrc.org/armbian-apt buster/buster-desktop arm64 Packages [26.5 kB]
Get:181 http://deb.debian.org/debian buster/main arm64 Contents (deb) [36.5 MB]
Get:182 http://deb.debian.org/debian buster/main armhf Contents (deb) [36.5 MB]
Get:183 http://deb.debian.org/debian buster/non-free arm64 Packages [64.3 kB]
Get:184 http://deb.debian.org/debian buster/non-free armhf Packages [74.5 kB]
Get:185 http://deb.debian.org/debian buster/non-free armhf Contents (deb) [779 kB]
Fetched 134 MB in 1min 19s (1,689 kB/s)
N: Repository 'http://deb.debian.org/debian buster InRelease' changed its 'Version' value from '10.7' to '10.8'
root@helios64:~#
root@helios64:~#
root@helios64:~# apt -y install tuned
Building dependency tree
The following additional packages will be installed:
  gawk python3-configobj python3-decorator python3-pyudev python3-six
  virt-what
Suggested packages:
  gawk-doc python-configobj-doc
Recommended packages:
  linux-cpupower
The following NEW packages will be installed:
  gawk python3-configobj python3-decorator python3-pyudev python3-six tuned
  virt-what
0 upgraded, 7 newly installed, 0 to remove and 37 not upgraded.
Need to get 845 kB of archives.
After this operation, 3,465 kB of additional disk space will be used.
Get:1 http://deb.debian.org/debian buster/main arm64 gawk arm64 1:4.2.1+dfsg-1 [628 kB]
Get:2 http://deb.debian.org/debian buster/main arm64 python3-six all 1.12.0-1 [15.7 kB]
Get:3 http://deb.debian.org/debian buster/main arm64 python3-configobj all 5.0.6-3 [35.7 kB]
Get:4 http://deb.debian.org/debian buster/main arm64 python3-decorator all 4.3.0-1.1 [14.5 kB]
Get:5 http://deb.debian.org/debian buster/main arm64 python3-pyudev all 0.21.0-1 [40.2 kB]
Get:6 http://deb.debian.org/debian buster/main arm64 virt-what arm64 1.19-1 [15.5 kB]
Get:7 http://deb.debian.org/debian buster/main arm64 tuned all 2.10.0-1 [96.1 kB]
Fetched 845 kB in 2s (478 kB/s)
Selecting previously unselected package gawk.
(Reading database ... 39228 files and directories currently installed.)
Preparing to unpack .../0-gawk_1%3a4.2.1+dfsg-1_arm64.deb ...
Unpacking gawk (1:4.2.1+dfsg-1) ...
Selecting previously unselected package python3-six.
Preparing to unpack .../1-python3-six_1.12.0-1_all.deb ...
Unpacking python3-six (1.12.0-1) ...
Selecting previously unselected package python3-configobj.
Preparing to unpack .../2-python3-configobj_5.0.6-3_all.deb ...
Unpacking python3-configobj (5.0.6-3) ...
Selecting previously unselected package python3-decorator.
Preparing to unpack .../3-python3-decorator_4.3.0-1.1_all.deb ...
Unpacking python3-decorator (4.3.0-1.1) ...
Selecting previously unselected package python3-pyudev.
Preparing to unpack .../4-python3-pyudev_0.21.0-1_all.deb ...
Unpacking python3-pyudev (0.21.0-1) ...
Selecting previously unselected package virt-what.
Preparing to unpack .../5-virt-what_1.19-1_arm64.deb ...
Unpacking virt-what (1.19-1) ...
Selecting previously unselected package tuned.
Preparing to unpack .../6-tuned_2.10.0-1_all.deb ...
Unpacking tuned (2.10.0-1) ...
Setting up virt-what (1.19-1) ...
Setting up gawk (1:4.2.1+dfsg-1) ...
Setting up python3-six (1.12.0-1) ...
Setting up python3-decorator (4.3.0-1.1) ...
Setting up python3-configobj (5.0.6-3) ...
Setting up python3-pyudev (0.21.0-1) ...
Setting up tuned (2.10.0-1) ...
Created symlink /etc/systemd/system/multi-user.target.wants/tuned.service → /lib/systemd/system/tuned.service.
Processing triggers for dbus (1.12.20-0+deb10u1) ...
Processing triggers for man-db (2.8.5-2) ...
root@helios64:~# tuned-adm profile server-powersave
root@helios64:~# systemctl restart tuned
root@helios64:~# cd /boot
root@helios64:/boot# ls
armbianEnv.txt                  dtb-5.10.12-rockchip64
armbian_first_run.txt.template  Image
boot.bmp                        initrd.img-5.10.12-rockchip64
boot.cmd                        System.map-5.10.12-rockchip64
boot.scr                        uInitrd
config-5.10.12-rockchip64       uInitrd-5.10.12-rockchip64
dtb                             vmlinuz-5.10.12-rockchip64
root@helios64:/boot# nano armbianEnv.txt
  GNU nano 3.2                     armbianEnv.txt
verbosity=7
bootlogo=false
console=serial
extraargs=earlyprintk ignore_loglevel
overlay_prefix=rockchip
rootdev=UUID=e4e3bcd6-3f03-4362-bbe0-f1654138c5d8
rootfstype=ext4
verbosity=7
bootlogo=false
console=serial
extraargs=earlyprintk ignore_loglevel fsck.repair=yes
rootfstype=ext4
boot.scr                        uInitrd
root@helios64:/boot# more boot.scr
'V▒▒A▒`▒
▒▒More--(0%)
# Please edit /boot/armbianEnv.txt to set supported parameters
setenv load_addr "0x9000000"
setenv overlay_error "false"
# default values
setenv rootdev "/dev/mmcblk0p1"
setenv verbosity "1"
setenv console "both"
setenv bootlogo "false"
setenv rootfstype "ext4"
setenv docker_optimizations "on"
setenv earlycon "off"
echo "Boot script loaded from ${devtype} ${devnum}"
if test -e ${devtype} ${devnum} ${prefix}armbianEnv.txt; then
        load ${devtype} ${devnum} ${load_addr} ${prefix}armbianEnv.txt
        env import -t ${load_addr} ${filesize}
fi
if test "${logo}" = "disabled"; then setenv logo "logo.nologo"; fi
if test "${console}" = "display" || test "${console}" = "both"; then setenv cons
oleargs "console=tty1"; fi
if test "${console}" = "serial" || test "${console}" = "both"; then setenv conso
leargs "console=ttyS2,1500000 ${consoleargs}"; fi
if test "${earlycon}" = "on"; then setenv consoleargs "earlycon ${consoleargs}";
 fi
if test "${bootlogo}" = "true"; then setenv consoleargs "bootsplash.bootfile=boo
tsplash.armbian ${consoleargs}"; fi
# get PARTUUID of first partition on SD/eMMC the boot script was loaded from
if test "${devtype}" = "mmc"; then part uuid mmc ${devnum}:1 partuuid; fi
setenv bootargs "root=${rootdev} rootwait rootfstype=${rootfstype} ${consoleargs
} consoleblank=0 loglevel=${verbosity} ubootpart=${partuuid} usb-storage.quirks=
${usbstoragequirks} ${extraargs} ${extraboardargs}"
if test "${docker_optimizations}" = "on"; then setenv bootargs "${bootargs} cgro
up_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1"; fi
load ${devtype} ${devnum} ${ramdisk_addr_r} ${prefix}uInitrd
load ${devtype} ${devnum} ${kernel_addr_r} ${prefix}Image
load ${devtype} ${devnum} ${fdt_addr_r} ${prefix}dtb/${fdtfile}
fdt addr ${fdt_addr_r}
fdt resize 65536
for overlay_file in ${overlays}; do
        if load ${devtype} ${devnum} ${load_addr} ${prefix}dtb/rockchip/overlay/
${overlay_prefix}-${overlay_file}.dtbo; then
                echo "Applying kernel provided DT overlay ${overlay_prefix}-${ov
erlay_file}.dtbo"
                fdt apply ${load_addr} || setenv overlay_error "true"
        fi
done
for overlay_file in ${user_overlays}; do
        if load ${devtype} ${devnum} ${load_addr} ${prefix}overlay-user/${overla
y_file}.dtbo; then
                echo "Applying user provided DT overlay ${overlay_file}.dtbo"
        fi
done
if test "${overlay_error}" = "true"; then
        echo "Error applying DT overlays, restoring original DT"
else
${overlay_prefix}-fixup.scr; then
                echo "Applying kernel provided DT fixup script (${overlay_prefix
}-fixup.scr)"
                source ${load_addr}
        fi
        if test -e ${devtype} ${devnum} ${prefix}fixup.scr; then
                load ${devtype} ${devnum} ${load_addr} ${prefix}fixup.scr
                echo "Applying user provided fixup script (fixup.scr)"
                source ${load_addr}
        fi
fi
booti ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r}
# Recompile with:
root@helios64:/boot# mkimage -C none -A arm -T scrit -d /boot/boot.cmd /boot/boot.scr
Invalid image type, supported are:
        Unknown image type  Unknown image type
        aisimage         Davinci AIS image
        atmelimage       ATMEL ROM-Boot Image
        filesystem       Filesystem Image
        firmware         Firmware
        firmware_ivt     Firmware with HABv4 IVT
        flat_dt          Flat Device Tree
        fpga             FPGA Image
        gpimage          TI Keystone SPL Image
        imx8image        NXP i.MX8 Boot Image
        imx8mimage       NXP i.MX8M Boot Image
        imximage         Freescale i.MX Boot Image
        invalid          Invalid Image
        kernel           Kernel Image
        kernel_noload    Kernel Image (no loading done)
        kwbimage         Kirkwood Boot Image
        lpc32xximage     LPC32XX Boot Image
        mtk_image        MediaTek BootROM loadable Image
        multi            Multi-File Image
        mxsimage         Freescale MXS Boot Image
        omapimage        TI OMAP SPL With GP CH
        pblimage         Freescale PBL Boot Image
        pmmc             TI Power Management Micro-Controller Firmware
        ramdisk          RAMDisk Image
        rkimage          Rockchip Boot Image
        rksd             Rockchip SD Boot Image
        rkspi            Rockchip SPI Boot Image
        script           Script
        socfpgaimage     Altera SoCFPGA CV/AV preloader
        socfpgaimage_v1  Altera SoCFPGA A10 preloader
        standalone       Standalone Program
        stm32image       STMicroelectronics STM32 Image
        tee              Trusted Execution Environment Image
        ublimage         Davinci UBL image
        vybridimage      Vybrid Boot Image
        x86_setup        x86 setup.bin
        zynqimage        Xilinx Zynq Boot Image
        zynqmpbif        Xilinx ZynqMP Boot Image (bif)
        zynqmpimage      Xilinx ZynqMP Boot Image
Error: Invalid image type
Usage: mkimage -l image
          -l ==> list image header information
       mkimage [-x] -A arch -O os -T type -C comp -a addr -e ep -n name -d data_file[:data_file...] image
          -A ==> set architecture to 'arch'
          -O ==> set operating system to 'os'
          -T ==> set image type to 'type'
          -C ==> set compression type 'comp'
          -a ==> set load address to 'addr' (hex)
          -e ==> set entry point to 'ep' (hex)
          -n ==> set image name to 'name'
          -d ==> use image data from 'datafile'
          -x ==> set XIP (execute in place)
       mkimage [-D dtc_options] [-f fit-image.its|-f auto|-F] [-b <dtb> [-b <dtb>]] [-i <ramdisk.cpio.gz>] fit-image
           <dtb> file is used with -f auto, it may occur multiple times.
          -D => set all options for device tree compiler
          -f => input filename for FIT source
          -i => input filename for ramdisk file
Signing / verified boot not supported (CONFIG_FIT_SIGNATURE undefined)
       mkimage -V ==> print version information and exit
Use '-T list' to see a list of available image types
root@helios64:/boot# mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
Image Name:
Created:      Fri Feb 19 16:30:44 2021
Image Type:   ARM Linux Script (uncompressed)
Data Size:    3121 Bytes = 3.05 KiB = 0.00 MiB
Load Address: 00000000
Entry Point:  00000000
Contents:
   Image 0: 3113 Bytes = 3.04 KiB = 0.00 MiB
'VQ>W4`/▒
▒▒More--(0%)
# default values
fi
 fi
fdt resize 65536
erlay_file}.dtbo"
        fi
done
y_file}.dtbo; then
        fi
done
else
}-fixup.scr)"
                source ${load_addr}
        fi
                source ${load_addr}
        fi
fi
# Recompile with:
Image Name:
Created:      Fri Feb 19 16:31:00 2021
Contents:
root@helios64:/boot# apt-get dist-upgrade
Calculating upgrade... Done
The following packages will be upgraded:
  armbian-config armbian-firmware armbian-zsh base-files bind9-host
  device-tree-compiler dnsutils file iproute2 libbind9-161 libdns-export1104
  libdns1104 libgnutls30 libirs161 libisc-export1100 libisc1100 libisccc161
  libisccfg163 liblwres161 libmagic-mgc libmagic1 libnss-myhostname
  libpam-systemd libssl-dev libssl1.1 libsystemd0 libudev1 libzstd1
  linux-buster-root-current-helios64 linux-dtb-current-rockchip64
  linux-image-current-rockchip64 openssl systemd systemd-sysv udev unzip
  wireguard-tools
37 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 66.4 MB of archives.
After this operation, 7,168 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:2 http://security.debian.org buster/updates/main arm64 libzstd1 arm64 1.3.8+dfsg-3+deb10u1 [216 kB]
Get:3 http://deb.debian.org/debian buster/main arm64 base-files arm64 10.3+deb10u8 [69.9 kB]
Get:9 http://deb.debian.org/debian buster/main arm64 libsystemd0 arm64 241-7~deb10u6 [314 kB]
Get:10 http://security.debian.org buster/updates/main arm64 libssl-dev arm64 1.1.1d-0+deb10u5 [1,686 kB]
Get:11 http://deb.debian.org/debian buster/main arm64 libnss-myhostname arm64 241-7~deb10u6 [122 kB]
Get:12 http://deb.debian.org/debian buster/main arm64 libpam-systemd arm64 241-7~deb10u6 [201 kB]
Get:6 https://mirrors.dotsrc.org/armbian-apt buster/main arm64 linux-buster-root-current-helios64 arm64 21.02.2 [416 kB]
Get:13 http://deb.debian.org/debian buster/main arm64 systemd arm64 241-7~deb10u6 [3,258 kB]
Get:4 https://imola.armbian.com/apt buster/main arm64 armbian-firmware all 21.02.2 [6,922 kB]
Get:1 https://mirrors.netix.net/armbian/apt buster/main arm64 armbian-config all 21.02.2 [44.8 kB]
Get:5 https://mirrors.netix.net/armbian/apt buster/main arm64 armbian-zsh all 21.02.2 [1,700 kB]
Get:14 http://security.debian.org buster/updates/main arm64 libssl1.1 arm64 1.1.1d-0+deb10u5 [1,382 kB]
Get:15 http://deb.debian.org/debian buster/main arm64 udev arm64 241-7~deb10u6 [1,245 kB]
Get:16 http://security.debian.org buster/updates/main arm64 dnsutils arm64 1:9.11.5.P4+dfsg-5.1+deb10u3 [361 kB]
Get:17 http://security.debian.org buster/updates/main arm64 bind9-host arm64 1:9.11.5.P4+dfsg-5.1+deb10u3 [270 kB]
Get:18 http://security.debian.org buster/updates/main arm64 libbind9-161 arm64 1:9.11.5.P4+dfsg-5.1+deb10u3 [245 kB]
Get:19 http://deb.debian.org/debian buster/main arm64 libudev1 arm64 241-7~deb10u6 [146 kB]
Get:20 http://deb.debian.org/debian buster/main arm64 systemd-sysv arm64 241-7~deb10u6 [100 kB]
Get:8 https://mirrors.netix.net/armbian/apt buster/main arm64 linux-image-current-rockchip64 arm64 21.02.2 [39.9 MB]
Get:21 http://deb.debian.org/debian buster/main arm64 libgnutls30 arm64 3.6.7-4+deb10u6 [1,062 kB]
Get:22 http://security.debian.org buster/updates/main arm64 libisccfg163 arm64 1:9.11.5.P4+dfsg-5.1+deb10u3 [265 kB]
Get:23 http://security.debian.org buster/updates/main arm64 libisccc161 arm64 1:9.11.5.P4+dfsg-5.1+deb10u3 [236 kB]
Get:24 http://security.debian.org buster/updates/main arm64 libirs161 arm64 1:9.11.5.P4+dfsg-5.1+deb10u3 [236 kB]
Get:25 http://security.debian.org buster/updates/main arm64 libdns1104 arm64 1:9.11.5.P4+dfsg-5.1+deb10u3 [1,130 kB]
Get:26 http://deb.debian.org/debian buster/main arm64 iproute2 arm64 4.20.0-2+deb10u1 [805 kB]
Get:27 http://deb.debian.org/debian buster/main arm64 file arm64 1:5.35-4+deb10u2 [66.5 kB]
Get:28 http://deb.debian.org/debian buster/main arm64 libmagic1 arm64 1:5.35-4+deb10u2 [115 kB]
Get:29 http://security.debian.org buster/updates/main arm64 libisc1100 arm64 1:9.11.5.P4+dfsg-5.1+deb10u3 [436 kB]
Get:30 http://deb.debian.org/debian buster/main arm64 libmagic-mgc arm64 1:5.35-4+deb10u2 [242 kB]
Get:31 http://security.debian.org buster/updates/main arm64 liblwres161 arm64 1:9.11.5.P4+dfsg-5.1+deb10u3 [249 kB]
Get:32 http://deb.debian.org/debian buster/main arm64 unzip arm64 6.0-23+deb10u2 [166 kB]
Get:33 http://security.debian.org buster/updates/main arm64 libisc-export1100 arm64 1:9.11.5.P4+dfsg-5.1+deb10u3 [369 kB]
Get:34 http://deb.debian.org/debian buster/main arm64 device-tree-compiler arm64 1.4.7-4 [251 kB]
Get:35 http://deb.debian.org/debian buster-backports/main arm64 wireguard-tools arm64 1.0.20200827-1~bpo10+1 [90.5 kB]
Get:36 http://security.debian.org buster/updates/main arm64 libdns-export1104 arm64 1:9.11.5.P4+dfsg-5.1+deb10u3 [901 kB]
Get:37 http://security.debian.org buster/updates/main arm64 openssl arm64 1.1.1d-0+deb10u5 [823 kB]
Get:7 https://imola.armbian.com/apt buster/main arm64 linux-dtb-current-rockchip64 arm64 21.02.2 [311 kB]
Fetched 66.4 MB in 40s (1,670 kB/s)
Extracting templates from packages: 100%
Preconfiguring packages ...
(Reading database ... 39691 files and directories currently installed.)
Preparing to unpack .../base-files_10.3+deb10u8_arm64.deb ...
Unpacking base-files (10.3+deb10u8) over (10.3+deb10u7) ...
Setting up base-files (10.3+deb10u8) ...
Installing new version of config file /etc/debian_version ...
Preparing to unpack .../libsystemd0_241-7~deb10u6_arm64.deb ...
Unpacking libsystemd0:arm64 (241-7~deb10u6) over (241-7~deb10u5) ...
Setting up libsystemd0:arm64 (241-7~deb10u6) ...
Preparing to unpack .../libnss-myhostname_241-7~deb10u6_arm64.deb ...
Unpacking libnss-myhostname:arm64 (241-7~deb10u6) over (241-7~deb10u5) ...
Preparing to unpack .../libpam-systemd_241-7~deb10u6_arm64.deb ...
Unpacking libpam-systemd:arm64 (241-7~deb10u6) over (241-7~deb10u5) ...
Preparing to unpack .../systemd_241-7~deb10u6_arm64.deb ...
Unpacking systemd (241-7~deb10u6) over (241-7~deb10u5) ...
[  608.261405] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[  608.261904] Modules linked in: rfkill governor_performance snd_soc_hdmi_codec r8152 snd_soc_rockchip_i2s hantro_vpu(C) rockchip_vdec(C) rockchip_rga snd_soc_core rockchipdrm v4l2_h264 snd_pcm_dmaengine videobuf2_dma_contig snd_pcm dw_mipi_dsi v4l2_mem2mem videobuf2_dma_sg videobuf2_vmalloc dw_hdmi snd_timer videobuf2_memops analogix_dp videobuf2_v4l2 leds_pwm gpio_charger panfrost drm_kms_helper videobuf2_common pwm_fan snd cec gpu_sched fusb302 videodev soundcore rc_core tcpm sg drm typec mc drm_panel_orientation_quirks gpio_beeper cpufreq_dt zram ledtrig_netdev lm75 ip_tables x_tables autofs4 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear md_mod realtek dwmac_rk stmmac_platform stmmac pcs_xpcs adc_keys
[  608.268027] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G         C        5.10.12-rockchip64 #21.02.1
[  608.268811] Hardware name: Helios64 (DT)
[  608.269166] pstate: 000003c5 (nzcv DAIF -PAN -UAO -TCO BTYPE=--)
[  608.269707] pc : do_undefinstr+0x2ec/0x318
[  608.270075] lr : do_undefinstr+0x1e4/0x318
[  608.270441] sp : ffff800011c13840
[  608.270738] x29: ffff800011c13840 x28: ffff000040311d00
[  608.271217] x27: ffff000040004300 x26: ffff800011cf3de0
[  608.271694] x25: 0000000000000001 x24: 0000000000000000
[  608.272172] x23: 00000000800003c5 x22: ffff800010e66f24
[  608.272649] x21: ffff800011c13a20 x20: ffff800011c138d0
[  608.273126] x19: ffff8000118b9948 x18: 0000000000000000
[  608.273603] x17: 0000000000000000 x16: 0000000000000000
[  608.274080] x15: 0000007325c21884 x14: 00000000000003b8
[  608.274557] x13: 0000000000000155 x12: 0000000000000001
[  608.275034] x11: 0000000000000040 x10: ffff80001194eea8
[  608.275511] x9 : ffff80001194eea0 x8 : ffff000040400270
[  608.275989] x7 : 0000000000000000 x6 : ffff800011c13898
[  608.276466] x5 : 00000000d5300000 x4 : ffff8000118c6270
[  608.276943] x3 : 0000000000010002 x2 : 0000000000010001
[  608.277421] x1 : ffff000040311d00 x0 : 00000000800003c5
[  608.277898] Call trace:
[  608.278123]  do_undefinstr+0x2ec/0x318
[  608.278464]  el1_undef+0x30/0x50
[  608.278757]  el1_sync_handler+0x88/0xe8
[  608.279103]  el1_sync+0x7c/0x100
[  608.279396]  enter_from_kernel_mode.isra.5+0x14/0x40
[  608.279839]  el1_undef+0x1c/0x50
[  608.280131]  el1_sync_handler+0x88/0xe8
[  608.280476]  el1_sync+0x7c/0x100
[  608.280770]  check_preemption_disabled+0x38/0x110
[  608.281190]  rcu_nmi_enter+0x28/0x150
[  608.281520]  rcu_irq_enter+0x10/0x70
[  608.281843]  enter_from_kernel_mode.isra.5+0x28/0x40
[  608.282285]  el1_abort+0x28/0x70
[  608.282577]  el1_sync_handler+0x64/0xe8
[  608.282922]  el1_sync+0x7c/0x100
[  608.283214]  enter_from_kernel_mode.isra.5+0x10/0x40
[  608.283657]  el1_undef+0x1c/0x50
[  608.283949]  el1_sync_handler+0x88/0xe8
[  608.284293]  el1_sync+0x7c/0x100
[  608.284588]  __radix_tree_lookup+0x68/0xb0
[  608.284958]  generic_handle_irq+0x1c/0x48
[  608.285318]  __handle_domain_irq+0x94/0x108
[  608.285697]  gic_handle_irq+0xc0/0x140
[  608.286033]  el1_irq+0xc0/0x180
[  608.286319]  arch_cpu_idle+0x18/0x28
[  608.286640]  default_idle_call+0x44/0x1bc
[  608.287002]  do_idle+0x204/0x278
[  608.287293]  cpu_startup_entry+0x24/0x60
[  608.287648]  secondary_start_kernel+0x170/0x180
[  608.288057] Code: f9401bf7 17ffff7d a9025bf5 f9001bf7 (d4210000)
[  608.288608] ---[ end trace cb8b19b43b3c01cd ]---
[  608.289021] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[  608.289678] SMP: stopping secondary CPUs
[  608.290036] Kernel Offset: disabled
[  608.290351] CPU features: 0x0240022,6100200c
[  608.290732] Memory Limit: none
[  608.291021] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]---
and again on the reboot
logout
Password:
 _   _      _ _            __   _  _
root@helios64:~#
root@helios64:~#
  virt-what
Suggested packages:
  linux-cpupower
  virt-what
boot.scr                        uInitrd
verbosity=7
bootlogo=false
console=serial
rootfstype=ext4
verbosity=7
bootlogo=false
console=serial
rootfstype=ext4
boot.scr                        uInitrd
'V▒▒A▒`▒
▒▒More--(0%)
# default values
fi
 fi
fdt resize 65536
erlay_file}.dtbo"
        fi
done
y_file}.dtbo; then
        fi
done
else
}-fixup.scr)"
                source ${load_addr}
        fi
                source ${load_addr}
        fi
fi
# Recompile with:
        firmware         Firmware
        fpga             FPGA Image
        kernel           Kernel Image
        script           Script
Image Name:
Contents:
'VQ>W4`/▒
▒▒More--(0%)
# default values
fi
 fi
fdt resize 65536
erlay_file}.dtbo"
        fi
done
y_file}.dtbo; then
        fi
done
else
}-fixup.scr)"
                source ${load_addr}
        fi
                source ${load_addr}
        fi
fi
# Recompile with:
Image Name:
Contents:
  wireguard-tools
DDR Version 1.24 20191016
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 928MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 928 MHz, current 856MHz
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 254
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
StorageInit ok = 80561
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xe5af4
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.10-armbian (Feb 03 2021 - 22:43:46 +0100)
SoC: Rockchip rk3399
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
MMC:   mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Revision: 1.2 - 4GB non ECC
Net:   eth0: ethernet@fe300000
scanning bus for devices...
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus dwc3: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus usb@fe380000 for devices... 1 USB Device(s) found
scanning bus dwc3 for devices... cannot reset port 4!?
4 USB Device(s) found
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
3185 bytes read in 5 ms (622.1 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
235 bytes read in 4 ms (56.6 KiB/s)
13857311 bytes read in 597 ms (22.1 MiB/s)
28582400 bytes read in 1214 ms (22.5 MiB/s)
81843 bytes read in 14 ms (5.6 MiB/s)
2698 bytes read in 8 ms (329.1 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
Moving Image from 0x2080000 to 0x2200000, end=3de0000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    13857247 Bytes = 13.2 MiB
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f51b8000, end f5eef1df ... OK
   Loading Device Tree to 00000000f513b000, end 00000000f51b7fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.12-rockchip64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 20:55:02 CET 2021
[    0.000000] Machine model: Helios64
[    0.000000] printk: debug: ignoring loglevel setting.
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x00000000ed000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xf77d9100-0xf77dafff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] On node 0 totalpages: 1015296
[    0.000000]   DMA zone: 4088 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 261632 pages, LIFO batch:63
[    0.000000]   DMA32 zone: 11776 pages used for memmap
[    0.000000]   DMA32 zone: 753664 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 32 pages/cpu s94040 r8192 d28840 u131072
[    0.000000] pcpu-alloc: s94040 r8192 d28840 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=e4e3bcd6-3f03-4362-bbe0-f1654138c5d8 rootwait rootfstype=ext4 console=ttyS2,1500000  consoleblank=0 loglevel=7 ubootpart=aaedb48e-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u earlyprintk ignore_loglevel fsck.repair=yes  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff000] (64MB)
[    0.000000] Memory: 3741216K/4061184K available (14848K kernel code, 2632K rwdata, 5968K rodata, 4352K init, 580K bss, 188896K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @40100000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000400d0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000400e0000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] random: get_random_bytes called from start_kernel+0x698/0x850 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001441] Console: colour dummy device 80x25
[    0.001588] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001612] pid_max: default: 32768 minimum: 301
[    0.001783] LSM: Security Framework initializing
[    0.001830] Yama: becoming mindful.
[    0.001979] AppArmor: AppArmor initialized
[    0.002086] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002123] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005830] rcu: Hierarchical SRCU implementation.
[    0.007020] Platform MSI: interrupt-controller@fee20000 domain created
[    0.007667] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.010035] EFI services will not be available.
[    0.010763] smp: Bringing up secondary CPUs ...
[    0.011941] Detected VIPT I-cache on CPU1
[    0.011993] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.012012] GICv3: CPU1: using allocated LPI pending table @0x00000000400f0000
[    0.012091] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.013512] Detected VIPT I-cache on CPU2
[    0.013562] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.013581] GICv3: CPU2: using allocated LPI pending table @0x0000000040180000
[    0.013658] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.015101] Detected VIPT I-cache on CPU3
[    0.015150] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.015170] GICv3: CPU3: using allocated LPI pending table @0x0000000040190000
[    0.015246] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.016741] CPU features: detected: Spectre-v2
[    0.016748] CPU features: detected: Spectre-v4
[    0.016753] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.016762] Detected PIPT I-cache on CPU4
[    0.016799] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.016814] GICv3: CPU4: using allocated LPI pending table @0x00000000401a0000
[    0.016863] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.018107] Detected PIPT I-cache on CPU5
[    0.018147] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.018162] GICv3: CPU5: using allocated LPI pending table @0x00000000401b0000
[    0.018213] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.018395] smp: Brought up 1 node, 6 CPUs
[    0.018502] SMP: Total of 6 processors activated.
[    0.018517] CPU features: detected: 32-bit EL0 Support
[    0.018531] CPU features: detected: CRC32 instructions
[    0.018545] CPU features: detected: 32-bit EL1 Support
[    0.045280] CPU: All CPU(s) started at EL2
[    0.045362] alternatives: patching kernel code
[    0.049159] devtmpfs: initialized
[    0.068121] Registered cp15_barrier emulation handler
[    0.068150] Registered setend emulation handler
[    0.068382] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.068459] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.071466] pinctrl core: initialized pinctrl subsystem
  [    2.843453] hub 3-0:1.0: USB hub found
[    2.843827] hub 3-0:1.0: 1 port detected
[    2.844527] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.845031] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[    2.845714] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    2.846365] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.847237] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    2.847967] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.848603] usb usb4: Product: xHCI Host Controller
[    2.849037] usb usb4: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[    2.849606] usb usb4: SerialNumber: xhci-hcd.0.auto
[    2.850568] hub 4-0:1.0: USB hub found
[    2.850978] hub 4-0:1.0: 1 port detected
[    2.851837] usbcore: registered new interface driver usb-storage
[    2.855033] mousedev: PS/2 mouse device common for all mice
[    2.856948] i2c /dev entries driver
[    2.861315] pca953x 2-0020: using no AI
[    2.871771] rk808 0-001b: chip id: 0x0
[    2.876004] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.876577] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.878234] vdd_center: supplied by vcc5v0_sys
[    2.879335] vdd_cpu_l: supplied by vcc5v0_sys
[    2.880089] vcc_ddr_s3: supplied by vcc5v0_sys
[    2.881155] vcc1v8_sys_s3: supplied by vcc5v0_sys
[    2.882232] vcc1v8_dvp: supplied by vcc5v0_sys
[    2.883151] vcc3v0_touch: supplied by vcc5v0_sys
[    2.884894] vcc1v8_s3: supplied by vcc5v0_sys
[    2.885564] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV
[    2.887272] vcc_sdio_s0: supplied by vcc5v0_sys
[    2.888206] vcca3v0_codec: supplied by vcc5v0_sys
[    2.889816] vcc1v5_s3: supplied by vcc5v0_sys
[    2.890722] vcca1v8_codec: supplied by vcc5v0_sys
[    2.892462] vcc3v0_s3: supplied by vcc5v0_sys
[    2.893010] vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER
[    2.893639] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3
[    2.894629] vcc3v3_s0: supplied by vcc3v3_sys_s3
[    2.898814] rk808-rtc rk808-rtc: registered as rtc0
[    2.899836] rk808-rtc rk808-rtc: setting system clock to 2021-02-19T16:36:53 UTC (1613752613)
[    2.903743] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.905607] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3
[    2.906145] avdd_0v9_s0: supplied by vcc1v8_sys_s3
[    2.906672] vdd_cpu_b: supplied by vcc5v0_sys
[    2.910154] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    2.912043] vdd_gpu: supplied by vcc5v0_sys
[    2.920082] dw_wdt ff848000.watchdog: No valid TOPs array specified
[    2.922456] sdhci: Secure Digital Host Controller Interface driver
[    2.923099] sdhci: Copyright(c) Pierre Ossman
[    2.923518] Synopsys Designware Multimedia Card Interface Driver
[    2.925366] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.926230] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    2.926940] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    2.927537] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    2.928129] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    2.928979] mmc2: CQHCI version 5.10
[    2.929805] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    2.930675] ledtrig-cpu: registered to indicate activity on CPUs
[    2.932489] hid: raw HID events driver (C) Jiri Kosina
[    2.933082] usbcore: registered new interface driver usbhid
[    2.933576] usbhid: USB HID core driver
[    2.939686] drop_monitor: Initializing network drop monitor service
[    2.941055] NET: Registered protocol family 10
[    2.943492] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.955081] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADM
  [    3.099436] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    3.100102] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    3.100857] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    3.160280] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    3.160874] pci_bus 0000:00: root bus resource [bus 00-1f]
[    3.161363] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[    3.161973] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[    3.162861] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
[    3.163599] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    3.164544] pci 0000:00:00.0: supports D1
[    3.164981] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    3.167616] dwmmc_rockchip fe320000.mmc: All phases bad!
[    3.168094] mmc1: tuning execution failed: -5
[    3.172571] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.173527] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
[    3.174121] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    3.174746] pci 0000:01:00.0: reg 0x10: [io  size 0x0080]
[    3.175270] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[    3.175893] pci 0000:01:00.0: reg 0x14: [io  size 0x0080]
[    3.176400] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[    3.177021] pci 0000:01:00.0: reg 0x18: [io  size 0x0080]
[    3.177527] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[    3.178149] pci 0000:01:00.0: reg 0x1c: [io  size 0x0080]
[    3.178655] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[    3.179331] pci 0000:01:00.0: reg 0x20: [io  size 0x0080]
[    3.179840] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[    3.180422] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    3.181065] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
[    3.182036] pci 0000:01:00.0: PME# supported from D3hot
[    3.182790] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    3.182915] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    3.189438] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
[    3.190047] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
[    3.190662] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
[    3.191316] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff]
[    3.191929] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0080]
[    3.192484] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0080]
[    3.193068] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0080]
[    3.193623] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0080]
[    3.194206] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0080]
[    3.194760] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0080]
[    3.195433] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    3.196307] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0080]
[    3.196860] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0080]
[    3.197444] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0080]
[    3.197998] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0080]
[    3.198586] pci 0000:00:00.0: PCI bridge to [bus 01]
[    3.199047] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
[    3.199886] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    3.200772] pcieport 0000:00:00.0: PME: Signaling with IRQ 90
[    3.201620] pcieport 0000:00:00.0: AER: enabled with IRQ 90
[    3.202444] ahci 0000:01:00.0: version 3.0
[    3.202829] ahci 0000:01:00.0: enabling device (0000 -> 0002)
[    3.203932] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
[    3.204610] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode
[    3.205334] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
[    3.209889] scsi host0: ahci
[    3.210974] scsi host1: ahci
[    3.211951] scsi host2: ahci
[    3.212902] scsi host3: ahci
[    3.213801] scsi host4: ahci
[    3.214287] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 91
[    3.214967] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 92
[    3.215622] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 93
[    3.216275] ata4: SATA max UDMA/133
                                       [    3.485411] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    3.603611] usb 4-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04
[    3.604336] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.604967] usb 4-1: Product: USB3.0 Hub
[    3.605415] usb 4-1: Manufacturer: VIA Labs, Inc.
[    3.630678] hub 4-1:1.0: USB hub found
[    3.631259] hub 4-1:1.0: 4 ports detected
[    4.278993] usb 4-1.4: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[    4.299983] usb 4-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00
[    4.300722] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    4.301366] usb 4-1.4: Product: USB 10/100/1G/2.5G LAN
[    4.301823] usb 4-1.4: Manufacturer: Realtek
[    4.302204] usb 4-1.4: SerialNumber: 000000001
[   13.166948] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   13.241353] ata1.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   13.241960] ata1.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   13.252813] ata1.00: configured for UDMA/133
[   13.253810] scsi 0:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   13.256008] sd 0:0:0:0: [sda] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   13.256711] sd 0:0:0:0: [sda] 4096-byte physical blocks
[   13.257251] sd 0:0:0:0: [sda] Write Protect is off
[   13.257689] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[   13.258269] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   13.315020]  sda: sda1 sda9
[   13.318311] sd 0:0:0:0: [sda] Attached SCSI disk
[   17.326920] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   17.400162] ata2.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   17.400779] ata2.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   17.411604] ata2.00: configured for UDMA/133
[   17.412536] scsi 1:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   17.414551] sd 1:0:0:0: [sdb] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   17.415301] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[   17.415835] sd 1:0:0:0: [sdb] Write Protect is off
[   17.416273] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[   17.416837] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   17.471573]  sdb: sdb1 sdb9
[   17.474864] sd 1:0:0:0: [sdb] Attached SCSI disk
[   18.010916] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   18.022704] ata3.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   18.023329] ata3.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   18.034052] ata3.00: configured for UDMA/133
[   18.035136] scsi 2:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   18.037252] sd 2:0:0:0: [sdc] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   18.037956] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[   18.038488] sd 2:0:0:0: [sdc] Write Protect is off
[   18.038954] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[   18.039521] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   18.097888]  sdc: sdc1 sdc9
[   18.101269] sd 2:0:0:0: [sdc] Attached SCSI disk
[   18.630939] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   18.653175] ata4.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   18.653782] ata4.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   18.664486] ata4.00: configured for UDMA/133
[   18.665274] scsi 3:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   18.667208] sd 3:0:0:0: [sdd] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   18.667911] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[   18.668443] sd 3:0:0:0: [sdd] Write Protect is off
[   18.668880] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[   18.669444] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   18.727505]  sdd: sdd1 sdd9
[   18.730837] sd 3:0:0:0: [sdd] Attached SCSI disk
[   18.981538] ata5: SATA link down (SStatus 0 SControl 300)
[   18.984939] Freeing unused kernel memory: 4352K
[   18.985519] Run /init as init process
[   18.985850]   with arguments:
[   18.986118]     /init
[   18.986327]     earlyprintk
[   18.986580]   with environment:
[   18.986863]     HOME=/
[   18.987105]     TERM=linux
[   18.987350]     ubootpart=aaedb48e-01
[   18.987678]     cgroup_enable=memory
[   18.987998]     cgroup_memory=1
Loading, please wait...
Starting version 241
[   19.625711] input: adc-keys as /devices/platform/adc-keys/input/input1
[   19.723699] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[   19.724296] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[   19.725000] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[   19.725789] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[   19.726420] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[   19.726949] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[   19.727462] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[   19.728085] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[   19.728700] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[   19.734258] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[   19.736262] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[   19.736926] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
[   19.737402] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[   19.738066] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[   19.738728] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[   19.739242] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[   19.739874] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[   19.740633] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[   19.741463] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[   19.741987] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   19.904242] libphy: stmmac: probed
[   19.904593] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[   19.905704] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
Begin: Loading essential drivers ... [   20.133666] async_tx: api initialized (async)
done.
[   20.415030] random: crng init done
done.
Begin: Will now check root file system ... fsck from util-linux 2.33.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk1p1] fsck.ext4 -y -C0 /dev/mmcblk1p1
e2fsck 1.44.5 (15-Dec-2018)
/dev/mmcblk1p1: recovering journal
Clearing orphaned inode 8812 (uid=0, gid=0, mode=0100644, size=278984)
Clearing orphaned inode 6804 (uid=0, gid=0, mode=0100644, size=75800)
Clearing orphaned inode 6863 (uid=0, gid=0, mode=0100644, size=639624)
Clearing orphaned inode 44201 (uid=0, gid=0, mode=0100644, size=421690)
Clearing orphaned inode 9812 (uid=0, gid=0, mode=0100644, size=3031632)
Setting free inodes count to 1835064 (was 1835828)
Setting free blocks count to 7186984 (was 7217325)
/dev/mmcblk1p1: clean, 45384/1880448 files, 522744/7709728 blocks
done.
[   21.667188] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom ... /scripts/local-bottom/mdadm: 2: /scripts/local-bottom/mdadm: rm: not found
done.
[   22.665872] systemd[1]: Inserted module 'autofs4'
[   22.743601] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   22.746941] systemd[1]: Detected architecture arm64.
Welcome to Debian GNU/Linux 10 (buster)!
[   22.788002] systemd[1]: Set hostname to <helios64>.
[   23.298166] systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
[   23.387324] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[  OK  ] Set up automount Arbitrary…s File System Automount Point.
[   23.399307] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[   23.411050] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   23.412251] systemd[1]: Reached target Local Encrypted Volumes.
[  OK  ] Reached target Local Encrypted Volumes.
[   23.423776] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[   23.435025] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on Journal Socket.
         Starting Create list of re…odes for the current kernel...
         Mounting POSIX Message Queue File System...
         Starting Remount Root and Kernel File Systems...
         Mounting Kernel Debug File System...
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[   23.593587] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
         Starting Load Kernel Modules...
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
         Starting Set the console keyboard layout...
         Starting Nameserver information manager...
[  OK  ] Listening on Syslog Socket.
[   23.664580] lm75 2-004c: supply vs not found, using dummy regulator
[   23.665885] lm75 2-004c: hwmon2: sensor 'lm75'
[  OK  ] Listening on udev Control Socket.
         Starting udev Coldplug all Devices...
         Mounting Huge Pages File System...
[  OK  ] Reached target Paths.
[  OK  ] Started Create list of req… nodes for the current kernel.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Mounted Huge Pages File System.
         Starting Apply Kernel Variables...
         Mounting Kernel Configuration File System...
         Mounting FUSE Control File System...
         Starting Create System Users...
         Starting Load/Save Random Seed...
[  OK  ] Started Nameserver information manager.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Started Set the console keyboard layout.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /tmp...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /tmp.
[  OK  ] Reached target Local File Systems.
         Starting Set console font and keymap...
         Starting Armbian ZRAM config...
[  OK  ] Started Set console font and keymap.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started udev Coldplug all Devices.
         Starting Helper to synchronize boot up for ifupdown...
[  OK  ] Started Helper to synchronize boot up for ifupdown.
         Starting Raise network interfaces...
[   24.675339] zram: Added device: zram0
[   24.676673] zram: Added device: zram1
[   24.677991] zram: Added device: zram2
[   24.772021] input: beeper as /devices/platform/beeper/input/input2
[  OK  ] Found device /dev/ttyS2.
[   24.874214] mc: Linux media interface: v0.10
[   24.927945] videodev: Linux video capture interface: v2.00
[   24.979410] zram0: detected capacity change from 0 to 1991770112
[   24.981951] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   24.982688] sd 1:0:0:0: Attached scsi generic sg1 type 0
[   24.983416] sd 2:0:0:0: Attached scsi generic sg2 type 0
[   24.984082] sd 3:0:0:0: Attached scsi generic sg3 type 0
[   25.005308] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[   25.011029] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
[   25.013167] rockchip-vop ff900000.vop: Adding to iommu group 3
[   25.016966] panfrost ff9a0000.gpu: clock rate = 500000000
[   25.018155] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
[   25.023227] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[   25.024151] [drm] unsupported AFBC format[3231564e]
[   25.032181] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   25.032698] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 5
[   25.033504] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000010002010010
[   25.034114] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[   25.034364] xhci-hcd xhci-hcd.3.auto: irq 75, io mem 0xfe800000
[   25.035636] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   25.036361] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   25.036990] usb usb5: Product: xHCI Host Controller
[   25.037417] usb usb5: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[   25.037979] usb usb5: SerialNumber: xhci-hcd.3.auto
[   25.038736] hub 5-0:1.0: USB hub found
[   25.039126] hub 5-0:1.0: 1 port detected
[   25.039655] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   25.040149] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 6
[   25.040826] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[   25.041433] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[   25.042416] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   25.043143] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   25.043773] usb usb6: Product: xHCI Host Controller
[   25.044200] usb usb6: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[   25.044763] usb usb6: SerialNumber: xhci-hcd.3.auto
[   25.045392] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[   25.046355] hub 6-0:1.0: USB hub found
[   25.046701] hub 6-0:1.0: 1 port detected
[   25.048200] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
[   25.056487] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[   25.057660] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[   25.058935] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[   25.060618] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   25.065379] rockchip-rga ff680000.rga: HW Version: 0x03.02
[   25.066754] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   25.069888] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[   25.072076] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[   25.077909] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 0
[   25.119026] Adding 1945084k swap on /dev/zram0.  Priority:5 extents:1 across:1945084k SSFS
[   25.134837] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[   25.153702] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   25.160687] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[   25.163219] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
[   25.164990] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
[   25.175452] rkvdec ff660000.video-codec: Adding to iommu group 1
[  OK  ] Started Raise network interfaces.
[   25.285824] zram1: detected capacity change from 0 to 52428800
[   25.346696] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   25.406998] usb 4-1.4: reset SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[  OK  ] Started Armbian ZRAM config.
[   25.543627] r8152 4-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
[   25.559204] r8152 4-1.4:1.0 eth1: v2.14.0 (2020/09/24)
[   25.559689] r8152 4-1.4:1.0 eth1: This product is covered by one or more of the following patents:
[   25.559689]          US6,570,884, US6,115,776, and US6,327,625.
[   25.559689]
[   25.561365] usbcore: registered new interface driver r8152
[   25.592939] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
         Starting Armbian memory supported logging...
[   25.867075] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
[   25.867762] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
[   26.079031] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   26.489072] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   28.015007] systemd[1]: Started Armbian memory supported logging.
[  OK  ] Started Armbian memory supported logging.
[   28.032134] systemd[1]: Starting Journal Service...
[   28.205216] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
         Starting Flush Journal to Persistent Storage...
[   28.269979] systemd-journald[719]: Received request to flush runtime journal from PID 1
[  OK  ] Started Flush Journal to Persistent Storage.
[   28.289757] Unable to handle kernel paging request at virtual address ffff800011c14110
[   28.290455] Mem abort info:
[   28.290704]   ESR = 0x96000047
[   28.290978]   EC = 0x25: DABT (current EL), IL = 32 bits
[   28.291445]   SET = 0, FnV = 0
[   28.291717]   EA = 0, S1PTW = 0
[   28.291995] Data abort info:
[   28.292252]   ISV = 0, ISS = 0x00000047
[   28.292592]   CM = 0, WnR = 1
[   28.292857] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000003668000
[   28.293445] [ffff800011c14110] pgd=00000000f7fff003, p4d=00000000f7fff003, pud=00000000f7ffe003, pmd=00000000400a8003, pte=0000000000000000
[   28.294555] Internal error: Oops: 96000047 [#1] PREEMPT SMP
[   28.295047] Modules linked in: r8152 snd_soc_hdmi_codec snd_soc_rockchip_i2s rockchip_vdec(C) hantro_vpu(C) snd_soc_core leds_pwm v4l2_h264 snd_pcm_dmaengine videobuf2_dma_contig rockchip_rga snd_pcm v4l2_mem2mem snd_timer videobuf2_vmalloc gpio_charger videobuf2_dma_sg snd pwm_fan videobuf2_memops panfrost videobuf2_v4l2 rockchipdrm fusb302 soundcore sg videobuf2_common tcpm gpu_sched dw_mipi_dsi typec videodev dw_hdmi mc analogix_dp drm_kms_helper cec rc_core gpio_beeper drm cpufreq_dt drm_panel_orientation_quirks zram ledtrig_netdev lm75 ip_tables x_tables autofs4 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear md_mod realtek dwmac_rk stmmac_platform stmmac pcs_xpcs adc_keys
[   28.300901] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G         C        5.10.12-rockchip64 #21.02.1
[   28.301675] Hardware name: Helios64 (DT)
[   28.302025] pstate: 20000085 (nzCv daIf -PAN -UAO -TCO BTYPE=--)
[   28.302566] pc : update_load_avg+0x4a0/0x590
[   28.302946] lr : enqueue_entity+0x68/0x2a8
[   28.303308] sp : ffff800011c13d00
[   28.303601] x29: ffff800011c13d00 x28: ffff000040311d00
[   28.304076] x27: ffff000040004300 x26: ffff800011cf3de0
[   28.304549] x25: 0000000000000001 x24: ffff000040b03ac0
[   28.305022] x23: ffff0000f77c7d00 x22: 0000000000000005
[   28.305495] x21: 0000000695e813be x20: ffff000040b03ac0
[   28.305968] x19: ffff0000f77c7d80 x18: 0000000000000000
[   28.306440] x17: 0000000000000000 x16: 0000000000000000
[   28.306913] x15: 0000000000000000 x14: 000000000000019e
[   28.307386] x13: 0000000000000006 x12: 0000000000000001
[   28.307859] x11: 0000000000000040 x10: ffff80001194eea8
[   28.308331] x9 : ffff80001194eea0 x8 : ffff000040400270
[   28.308804] x7 : 0000000000000000 x6 : 000000001b6d6fce
[   28.309277] x5 : 00ffffffffffffff x4 : 0000000098240015
[   28.309751] x3 : 0000000000000000 x2 : 0000000000000005
[   28.310223] x1 : 0000000000000000 x0 : 0000000695e69800
[   28.310696] Call trace:
[   28.310918]  update_load_avg+0x4a0/0x590
[   28.311268]  enqueue_entity+0x68/0x2a8
[   28.311602]  enqueue_task_fair+0x8c/0x4b8
[   28.311960]  ttwu_do_activate+0x88/0x150
[   28.312309]  sched_ttwu_pending+0xbc/0x160
[   28.312676]  flush_smp_call_function_queue+0x114/0x250
[   28.313131]  generic_smp_call_function_single_interrupt+0x14/0x20
[   28.313670]  ipi_handler+0x7c/0x370
[   28.313984]  handle_percpu_devid_fasteoi_ipi+0x9c/0x1f0
[   28.314446]  generic_handle_irq+0x30/0x48
[   28.314802]  __handle_domain_irq+0x94/0x108
[   28.315176]  gic_handle_irq+0xc0/0x140
[   28.315510]  el1_irq+0xc0/0x180
[   28.315794]  arch_cpu_idle+0x18/0x28
[   28.316112]  default_idle_call+0x44/0x1bc
[   28.316468]  do_idle+0x204/0x278
[   28.316756]  cpu_startup_entry+0x24/0x60
[   28.317107]  secondary_start_kernel+0x170/0x180
[   28.317512] Code: 17ffff56 d2800004 52800002 17ffff42 (aa1403e2)
[   28.318058] ---[ end trace 6d00b0a42bf90e7c ]---
[   28.318467] Kernel panic - not syncing: Oops: Fatal exception in interrupt
[   28.319073] SMP: stopping secondary CPUs
[   28.319428] Kernel Offset: disabled
[   28.319740] CPU features: 0x0240022,6100200c
[   28.320116] Memory Limit: none
[   28.320401] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
Unfortunately not for me :(
  • [   46.779894] ------------[ cut here ]------------
  • [   46.780314] kernel BUG at arch/arm64/kernel/traps.c:407!
  • [   46.780785] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
  • [   46.781271] Modules linked in: snd_soc_hdmi_codec snd_soc_rockchip_i2s r8152 hantro_vpu(C) rockchip_vdec(C) snd_soc_core rockchipdrm v4l2_h264 videobuf2_dma_contig dw_mipi_dsi snd_pcm_dmaengine rockchip_rga dw_hdmi videobuf2_vmalloc snd_pcm v4l2_mem2mem analogix_dp videobuf2_dma_sg drm_kms_helper videobuf2_memops videobuf2_v4l2 snd_timer videobuf2_common cec fusb302 panfrost tcpm snd rc_core gpio_charger leds_pwm gpu_sched pwm_fan typec soundcore videodev drm mc drm_panel_orientation_quirks gpio_beeper cpufreq_dt zfs(POE) zunicode(POE) zzstd(OE) zlua(OE) zcommon(POE) nfsd znvpair(POE) zavl(POE) icp(POE) auth_rpcgss spl(OE) nfs_acl ledtrig_netdev lockd grace lm75 sunrpc ip_tables x_tables autofs4 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear md_mod realtek dwmac_rk stmmac_platform stmmac pcs_xpcs adc_keys
  • [   46.788176] CPU: 4 PID: 0 Comm: swapper/4 Tainted: P         C OE     5.10.16-rockchip64 #21.02.2
  • [   46.788180] Hardware name: Helios64 (DT)
  • [   46.788195] pstate: 00000085 (nzcv daIf -PAN -UAO -TCO BTYPE=--)
  •          Starting Create Volatile Files and Directories[   46.789848] pc : do_undefinstr+0x2ec/0x318
  • [   46.790690] lr : do_undefinstr+0x1e4/0x318
  • [   46.791118] sp : ffff800011c0b9a0
  • [   46.791413] x29: ffff800011c0b9a0 x28: ffff000040310e80
  • [   46.791888] x27: ffff000040004300 x26: ffff800011cebde0
  • [   46.792363] x25: 0000000000000001 x24: 0000000000000000
  • [   46.792837] x23: 00000000a0000085 x22: ffff800010126f5c
  • [   46.793310] x21: ffff800011c0bb80 x20: ffff800011c0ba30
  • [   46.793783] x19: ffff8000118b9948 x18: 0000000000000000
  • [   46.794257] x17: 0000000000000000 x16: 0000000000000000
  • [   46.794730] x15: 0000052528725e34 x14: 0000000000000040
  • [   46.795203] x13: 0000000000000156 x12: 0000000000000001
  • [   46.795677] x11: 0000000000000040 x10: ffff000040004368
  • [   46.796150] x9 : ffff000040004360 x8 : ffff0000404004b8
  • [   46.796623] x7 : 0000000000000000 x6 : ffff800011c0b9f8
  • [   46.797096] x5 : 00000000d5300000 x4 : ffff8000118c6270
  • [   46.797570] x3 : 0000000000010002 x2 : 0000000000010001
  • [   46.798043] x1 : ffff000040310e80 x0 : 00000000a0000085
  • [   46.798518] Call trace:
  • [   46.798740]  do_undefinstr+0x2ec/0x318
  • [   46.799079]  el1_undef+0x30/0x50
  • [   46.799368]  el1_sync_handler+0x88/0xe8
  • [   46.799711]  el1_sync+0x7c/0x100
  • [   46.800002]  __rcu_read_unlock+0x34/0x158
  • [   46.800359]  irq_find_mapping+0x70/0xf0
  • [   46.800701]  __handle_domain_irq+0xe4/0x108
  • [   46.801076]  gic_handle_irq+0xc0/0x140
  • [   46.801410]  el1_irq+0xc0/0x180
  • [   46.801693]  arch_cpu_idle+0x18/0x28
  • [   46.802012]  default_idle_call+0x44/0x1bc
  • [   46.802369]  do_idle+0x204/0x278
  • [   46.802658]  cpu_startup_entry+0x24/0x60
  • [   46.803011]  secondary_start_kernel+0x170/0x180
  • [   46.803417] Code: f9401bf7 17ffff7d a9025bf5 f9001bf7 (d4210000)
  • [   46.803964] ---[ end trace 127c975f587b5800 ]---
  • [   46.804374] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
  • [   46.805025] SMP: stopping secondary CPUs
  • [   46.805382] Kernel Offset: disabled
  • [   46.805694] CPU features: 0x0240022,6100200c
  • [   46.806070] Memory Limit: none
  • [   46.806354] Rebooting in 90 seconds..
and another ...
[   57.770744] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: sched_ttwu_pending+0x160/0x160
[   57.771683] CPU: 5 PID: 0 Comm: swapper/5 Tainted: P         C OE     5.10.16-rockchip64 #21.02.2
[   57.772459] Hardware name: Helios64 (DT)
[   57.772808] Call trace:
[   57.773034]  dump_backtrace+0x0/0x200
[   57.773363]  show_stack+0x18/0x68
[   57.773667]  dump_stack+0xcc/0x124
[   57.773971]  panic+0x174/0x374
[   57.774247]  __stack_chk_fail+0x3c/0x40
[   57.774590]  send_call_function_single_ipi+0x0/0x20
[   57.775024]  flush_smp_call_function_queue+0x114/0x250
[   57.775479]  generic_smp_call_function_single_interrupt+0x14/0x20
[   57.776017]  ipi_handler+0x7c/0x370
[   57.776331]  handle_percpu_devid_fasteoi_ipi+0x9c/0x1f0
[   57.776793]  generic_handle_irq+0x30/0x48
[   57.777149]  __handle_domain_irq+0x94/0x108
[   57.777523]  gic_handle_irq+0xc0/0x140
[   57.777856]  el1_irq+0xc0/0x180
[   57.778140]  arch_cpu_idle+0x18/0x28
[   57.778458]  default_idle_call+0x44/0x1bc
[   57.778814]  do_idle+0x204/0x278
[   57.779103]  cpu_startup_entry+0x28/0x60
[   57.779451]  secondary_start_kernel+0x170/0x180
[   57.779858] SMP: stopping secondary CPUs
[   57.780212] Kernel Offset: disabled
[   57.780523] CPU features: 0x0240022,6100200c
[   57.780900] Memory Limit: none
[   57.781186] Rebooting in 90 seconds..
That's great to hear gprovost! I didn't save any of the traces but I'm also having panics on 5.10.16, it always happens within a minute of booting it so I'm back on 5.9.14 which has been more stable (only panics once or twice a month).
well, it could be that 'm with ubuntu, or maybe that i don't need anything more than plain ext4, samba and nfs, but i have
 _   _      _ _            __   _  _
| | | | ___| (_) ___  ___ / /_ | || |
| |_| |/ _ \ | |/ _ \/ __| '_ \| || |_
|  _  |  __/ | | (_) \__ \ (_) |__   _|
|_| |_|\___|_|_|\___/|___/\___/   |_|
Welcome to Armbian 21.02.2 Groovy with Linux 5.10.16-rockchip64
No end-user support: work in progress & unsupported (groovy) userspace!
System load:   2%               Up time:       9 days 13:21
Memory usage:  34% of 3.71G     Zram usage:    6% of 1.85G      IP:            192.168.1.150
CPU temp:      44°C             Usage of /:    56% of 15G
[ 0 security updates available, 26 updates total: apt upgrade ]
Last check: 2021-02-27 00:00
[ General system configuration (beta): armbian-config ]
and it has been stable for more than 3 weeks before last reboot, which was required after an update
Could you guys update to latest  kernel (linux-image-current-rockchip64_21.02.3_arm64 / LK 5.10.21)  and revert to ondemand governor with the full range of frequency in case you were on performance mode.
Also remove any vdd voltage tweak you might have put in /boot/boot.cmd. If you had vdd tweak you will need to rebuild u-boot boot script after removing the lines in /boot/boot.cmd
Let us know how the new kernel improves the stability.
