Have an old K-R42. How can this image be flashed? Linux "upgrade_tool uf hirsute-preinstalled-desktop-arm64+raspi.img" results in
Loading firmware...
Loading firmware failed!
Thanks
@Slackstick The image name you have quoted doesn't resemble any armbian build I am aware of.  Where did you find this image you are trying to install?  If it isn't armbian based then this is not the correct place to be asking your question.
Sorry, used the wrong image and wrong commands.
It flashed with "sudo ./upgrade_tool di -b  Armbian_21.05.0-trunk_Rk3188_hirsute_current_5.10.9.img", but image didn't start (screen black).
Expand
These images are not intended for such use. They are written to the SD card by the appropriate program for recording images. Also on your device, you may need to adapt the standard firmware to run external systems from the SD card.
