forgive me for asking such a seemingly stupid thing, but I can't find any info about it.
i have a H6 Q+ tv box with Armbian_20.10_Arm-64_buster_current_5.9.0 on it, updated via apt-get update & upgrade but the kernel is still 5.9.
now i've seen that the latest applicable image would be Armbian_21.05.0-trunk_Aw-h6-tv_buster_current_5.10.20, but i can't understand how to upgrade
from sudo armbian-config - system - other i can switch only to "linux-image-current-arm-64=20.08 (5.7.16-arm-64)" or "linux-image-current-arm-64=20.07 (5.7.7-arm-64)". Is that correct? should I switch to one of these two?
with cat /etc/armbian-release I get
# PLEASE DO NOT EDIT THIS FILE
BOARD=arm-64
BOARD_NAME="ARM-64"
BOARDFAMILY=arm-64
BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
BUILD_REPOSITORY_COMMIT=62b8c07-dirty
DISTRIBUTION_CODENAME=buster
DISTRIBUTION_STATUS=supported
VERSION=20.10
LINUXFAMILY=arm-64
BRANCH=current
ARCH=arm64
IMAGE_TYPE=user-built
BOARD_TYPE=conf
INITRD_ARCH=arm64
KERNEL_IMAGE_TYPE=Image
thank you very much
14 часов назад, andker сказал:
The version of the image you are using is not official and there are no kernel updates for it via network repositories. You can try to build the latest version of the kernel yourself (directly on the device itself from under the Armbian system) and manually install it.
in my device only legacy versions works........why jammy version not have legacy? all the other versions have......ill giv a try but its my first time
The focus of armbian is supporting mainline linux.  There really isn't any interest in supporting the legacy kernels.  The legacy kernels are not supported and because of their age are full of known security vulnerabilities.  However the build framework will let you build one if you need to.
