hive Posted March 15, 2021 Posted March 15, 2021 I'd like some help please. The ethernet device naming seems inconsistent. Sometimes one interface comes up as eth0 and sometimes as eth1, and sometimes not at all. The enp1s0 interface seems to reliably come up, but not with the right config (sometimes it uses the config for enp1s0 and sometimes for eth0). I am trying to assign status IP addresses (on different networks) to each interface, but because of the unreliable bringup of the network interfaces, I can't get a config that starts up correctly and consistency on reboots or cold boots. As a test I ran the friendly-core-lite-focal from FriendlyCore and it does not have this issue. Is there something I need to do on Arabian to get the network interface bringup to work? I have static IP configs in /etc/network/interfaces.d called eth0, eth1 (these are the same, call it network A, because the 2nd network seems to sometimes come up as eth0) , and enp1s0 (configured for my second network, call it network I'd greatly appreciate any help in making the network bring up consistent. 0 Quote
Werner Posted March 15, 2021 Posted March 15, 2021 Your issue report is invalid for one or multiple reasons (non-exhaustive enumeration): it has been stated at the wrong place it lacks fundamental requested data it could have been easily solved by a quick search and/or reading documentation unsupported userspace/image/SBC Since you refused to use the bug reporting form carefully and follow the information there as you have been asked for we have no intention to further investigate. Please add missing information if applicable. https://www.armbian.com/bugs 0 Quote
hive Posted March 15, 2021 Author Posted March 15, 2021 Sorry my mistake. I thought I was posting in the community forum first, to see if anyone has already run into this. I was not ready to file I bug--I just posted in the wrong place. 0 Quote
tparys Posted March 21, 2021 Posted March 21, 2021 FYI, the reason this post got flagged is that it's missing armbianmonitor output (see https://forum.armbian.com/topic/5699-how-to-provide-and-interpret-debug-output/). Edit your original post, and put it at the top. I think it'd be in the interest of others to identify which builds are showing this behavior. 0 Quote
Fernando Rivasplata Posted November 2, 2022 Posted November 2, 2022 I'm observing the same problem described by @hive, the 2 eth adapters are named as: enp1s0 eth0 or eth1, meaning that the second adapter switch the name between eth0 and eth1 every time the nanopi-R4s reboot for instance after a kernel upgrade, creating a bunch of issues with the nat rules, vnstat and other tools that are configured with the name of that adapter. The second problem is that the ethx (0 or 1) very often is losing its ip address and I must run the dhclient manually to get an ip address again, this adapter is connected directly to the Comcast modem. Here the armbianmonitor -u link https://paste.armbian.com/ugewezical Thank you for any help on this regarding. 1 Quote
poddmo Posted September 8, 2023 Posted September 8, 2023 I just solved persistent network name for my Armbian 23.02.2 Focal with Linux 5.15.93-rockchip64 on NanoPi R4S with a systemd .link file. I came up with this generic .link file for NanoPi R4S based on https://wiki.debian.org/NetworkInterfaceNames and the man page for systemd.link(5). user@nanopir4s:/etc/systemd/network$ cat 10-persistent-net.link #/etc/systemd/network/10-persistent-net.link [Match] #MACAddress=04:91:62:11:22:33 Path=platform-fe300000.ethernet [Link] Name=enx0 The naming of the CPU-based ethernet device (fe300000.ethernet RTL8211E) was subject to a race at boot with the PCIe ethernet device (r8169 RTL8168h/8111h). user@nanopir4s:~$ sudo dmesg | grep -E 'eth|rtl|816|fe300' [ 2.335890] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000 [ 3.118663] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found [ 3.118683] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found [ 3.118810] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock [ 3.119098] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 3.119112] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 3.119123] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11). [ 3.119140] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). [ 3.119213] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed [ 3.119222] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 3.125215] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 3.126451] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35 [ 3.126474] rk_gmac-dwmac fe300000.ethernet: DWMAC1000 [ 3.126484] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported [ 3.126494] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported [ 3.126502] rk_gmac-dwmac fe300000.ethernet: COE Type 2 [ 3.126510] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported [ 3.126519] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported [ 3.126630] rk_gmac-dwmac fe300000.ethernet: Normal descriptors [ 3.126640] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled [ 3.126648] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 3.161734] r8169 0000:01:00.0 eth0: RTL8168h/8111h, f2:ca:e6:11:22:33, XID 541, IRQ 91 [ 3.161771] r8169 0000:01:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko] [ 3.442048] r8169 0000:01:00.0 enp1s0: renamed from eth0 [ 8.069286] rk_gmac-dwmac fe300000.ethernet enx0: renamed from eth1 [ 17.312235] Generic FE-GE Realtek PHY r8169-0-100:00: attached PHY driver (mii_bus:phy_addr=r8169-0-100:00, irq=MAC) [ 17.517652] r8169 0000:01:00.0 enp1s0: Link is Down [ 17.569528] rk_gmac-dwmac fe300000.ethernet enx0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=90) [ 17.573204] rk_gmac-dwmac fe300000.ethernet enx0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 17.574462] rk_gmac-dwmac fe300000.ethernet enx0: No Safety Features support found [ 17.574550] rk_gmac-dwmac fe300000.ethernet enx0: PTP not supported by HW [ 17.575063] rk_gmac-dwmac fe300000.ethernet enx0: configuring for phy/rgmii link mode [ 21.020601] r8169 0000:01:00.0 enp1s0: Link is Up - 1Gbps/Full - flow control rx/tx [ 21.270522] rk_gmac-dwmac fe300000.ethernet enx0: Link is Up - 1Gbps/Full - flow control rx/tx First I tried by MAC address then tried the more generic path_id user@nanopir4s:~$ sudo udevadm test-builtin net_id /sys/class/net/enx0 Load module index Parsed configuration file /usr/lib/systemd/network/99-default.link Parsed configuration file /usr/lib/systemd/network/73-usb-net-by-mac.link Parsed configuration file /etc/systemd/network/10-persistent-net.link Created link configuration context. Using default interface naming scheme 'v245'. ID_NET_NAMING_SCHEME=v245 ID_NET_NAME_MAC=enx049162112233 ID_OUI_FROM_DATABASE=Microchip Technology Inc. Unload module index Unloaded link configuration context. user@nanopir4s:~$ sudo udevadm test-builtin path_id /sys/class/net/enx0 Load module index Parsed configuration file /usr/lib/systemd/network/99-default.link Parsed configuration file /usr/lib/systemd/network/73-usb-net-by-mac.link Parsed configuration file /etc/systemd/network/10-persistent-net.link Created link configuration context. ID_PATH=platform-fe300000.ethernet ID_PATH_TAG=platform-fe300000_ethernet Unload module index Unloaded link configuration context. 0 Quote
