Werner Posted March 25, 2021 Posted March 25, 2021 Quite a while ago developers decided to rename the dev branch to edge to reflect its purpose better: https://armbian.atlassian.net/browse/AR-233 This now finally happened. Our documentation has been adjusted as well. For details feel free to check these commits: https://github.com/armbian/documentation/commit/6c9985c9f5a0f593ab2593eb8054b6c658445d25 https://github.com/armbian/build/commit/0cdffb29b07305209efb12cf3b5ac6032d3a1153 For those who do automated and/or scripted building take note to adjust it accordingly. 3
guidol Posted April 1, 2021 Posted April 1, 2021 maybe a stupid little question Is there an "official" way to update kernel-package from dev to edge without recompiling/installing the newest image? I did manually for one of my NanoPi Neo2: apt remove linux-u-boot-nanopineo2-dev -y apt remove linux-dtb-dev-sunxi64 -y apt remove linux-image-dev-sunxi64 -y apt remove linux-buster-root-dev-nanopineo2 -y dpkg -i ./linux-u-boot-edge-nanopineo2_21.05.0-trunk_arm64.deb dpkg -i ./linux-buster-root-edge-nanopineo2_21.05.0-trunk_arm64.deb dpkg -i ./linux-dtb-edge-sunxi64_21.05.0-trunk_arm64.deb dpkg -i ./linux-image-edge-sunxi64_21.05.0-trunk_arm64.deb dpkg -i ./armbian-zsh_21.05.0-trunk_all.deb dpkg -i ./armbian-firmware_21.05.0-trunk_all.deb dpkg -i ./armbian-config_21.05.0-trunk_all.deb _ _ ____ _ _ _ ____ | \ | | _ \(_) | \ | | ___ ___ |___ \ | \| | |_) | | | \| |/ _ \/ _ \ __) | | |\ | __/| | | |\ | __/ (_) | / __/ |_| \_|_| |_| |_| \_|\___|\___/ |_____| Welcome to Armbian 21.05.0-trunk Buster with bleeding edge Linux 5.11.11-sunxi64 No end-user support: built from trunk package bsp-kernel[21.05.0-trunk] u-boot[21.05.0-trunk] dtb [21.05.0-trunk] firmware [21.05.0-trunk] config[21.05.0-trunk] branch[edge] System diagnosis information has been uploaded to http://ix.io/2UJG
Werner Posted April 1, 2021 Author Posted April 1, 2021 8 minutes ago, guidol said: Is there an "official" way to update kernel-package from dev to edge without recompiling/installing the newest image? Not as I am aware of. Needs to be done manually.
Igor Posted April 1, 2021 Posted April 1, 2021 Manual way: removing current -dev armbian packages and install -edge variants. But stable base doesn't have u-boot packages ...
guidol Posted April 1, 2021 Posted April 1, 2021 2 hours ago, Igor said: Manual way: removing current -dev armbian packages and install -edge variants. But stable base doesn't have u-boot packages ... @Igor I replaced (by the meaning of u-boot) linux-u-boot-nanopineo2-dev with linux-u-boot-nanopineo2-edge ( linux-u-boot-edge-nanopineo2_21.05.0-trunk_arm64.deb ) But Iam searching for the -edge replacement for linux-buster-root-dev-nanopineo2, because apt has only for "linux edge": [EDIT] this was created at ./output/debs/buster/linux-buster-root-edge-nanopineo2_21.05.0-trunk_arm64.deb Did edit the instructions above
