download: Armbian_20.10_Arm-64_focal_current_5.9.0.img.xz    || or ||  Armbian_20.10_Arm-64_focal_current_5.9.0. desktop
link: https://users.armbian.com/balbes150/arm-64/
download: Armbian_21.02.0-trunk_Aw-h6-tv_focal_current_5.10.9.img    || or ||  Armbian_21.05.0-trunk_Aw-h6-tv_focal_current_5.10.25_xfce_desktop.img.xz
link: https://users.armbian.com/balbes150/aw-h6-tv/
burn the image into sdcard:
link:
download this file:
https://forum.armbian.com/applications/core/interface/file/attachment.php?id=5742Unavailable
RUN:
# sudo fdisk -l
Disk /dev/sdc: 14.57 GiB, 15631122432 bytes, 30529536 sectors
Disk model: Cruzer Blade
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x81e64ae2
Device     Boot   Start      End Sectors  Size Id Type
/dev/sdc1         32768  1081343 1048576  512M  e W95 FAT16 (LBA)
/dev/sdc2       1081344 10239999 9158656  4.4G 83 Linux
# card=/dev/sdc
# sudo dd if=/dev/zero of=${card} bs=1024 seek=544 count=128
on u-boot-sunxi-with-spl-h6-noname.bin path
# sudo dd if=u-boot-sunxi-with-spl-h6-noname.bin of=${card} bs=1024 seek=8
remove the SDCARD
put it on
enjoy it
thanks to: @balbes150, @hamza_iraki, @NicoD, @hexdump and others.
from this link:
Wifi work
WIFI Solved Problem
Works
just try this:
To get wifi working:
sudo mv /lib/firmware/brcm/brcmfmac4330-sdio.txt /lib/firmware/brcm/brcmfmac4330-sdio.txt.old
sudo ln -s  /lib/firmware/brcm/brcmfmac-ap6330-sdio.txt /lib/firmware/brcm/brcmfmac4330-sdio.txt
thanks to: @hannah
  On 4/29/2021 at 7:57 PM, wperw said:
Hi, I've this one but thelabel say H616 4 + 32,.
The H616 version is also supported?
Expand
No, there is no current Armbian support for the H616 CPU variant.  Work is being done, but the general guidance is that support for this may be a year or so in the future.
