wurmfood Posted April 8, 2021 Posted April 8, 2021 Is there an accepted procedure for moving from using ramlog to logging to disk? I've looked but everything I can find is about setting up ramlog. I assume it's more complicated than just creating a partition (or ZFS dataset) and mounting it /var/log, disabling ramlog, and rebooting.
Werner Posted April 8, 2021 Posted April 8, 2021 23 minutes ago, wurmfood said: mounting it /var/log, disabling ramlog, and rebooting. Actually that is what I would do at first try. 1
wurmfood Posted April 8, 2021 Author Posted April 8, 2021 Well, for anyone else interested in trying this, here's the basic order I did: stop armbian-ramlog disable armbian-ramlog create a zfs dataset and mount it at /var/log cp -ar everything from /var/log.hdd to the new /var/log modify /etc/logrotate to disable compression (since the dataset is already using compression) modify /etc/default/armbian-ramlog to disable it there as well modify /etc/default/armbian-zram-config to adjust for new numbers (I have ZRAM_PERCENTAGE and MEM_LIMIT_PERCENTAGE at 15). reboot 3
0x349850341010010101010100 Posted July 30, 2021 Posted July 30, 2021 Hi, I had that same idea and I'm just setting this up based on your suggestions. Thank you for starting the thread. Just one thing: There is no option regarding compression in /etc/default/armbian-zram-config, or did you mean to disable another option?
wurmfood Posted July 31, 2021 Author Posted July 31, 2021 Sorry, the line about disabling was just to make sure you disable the armbian-zram-config service by setting ENABLED to false. As a warning, though, I found some problems with this if you log to a zfs share. It seems you have to make sure zfs gets loaded before the logging starts up, otherwise you can get a kernel panic on occasion. I didn't really dig into how to fix this, so I just log and swap to a usb drive instead now. 1
0x349850341010010101010100 Posted July 31, 2021 Posted July 31, 2021 5 hours ago, wurmfood said: Sorry, the line about disabling was just to make sure you disable the armbian-zram-config service by setting ENABLED to false. As a warning, though, I found some problems with this if you log to a zfs share. It seems you have to make sure zfs gets loaded before the logging starts up, otherwise you can get a kernel panic on occasion. I didn't really dig into how to fix this, so I just log and swap to a usb drive instead now. Thank you for clarifying and pointing that out. Logging to a USB drive as a swap seems like a neat workaround. It would be better though, if we could work out how to avoid the kernel panics without having to change when zfs mounts.
