[SOLVED] orange pi zero "tv out" not working.
Go to solution Solved by JMCC,
Armbianmonitor:
I have found other treads that address "tv out not working" but none have been applicable.  They point to files that are not on my system.
It is an older orange pi zero.  I have installed the latest armbian image.  Here is the "lsb_release -a" return:
Distributor ID:  Ubuntu
Description:     Ubuntu 20.04.2 LTS
Release:          20.04
Codename:      focal
I am currently operating headless and the login splash screen says "Welcome to Arbian 21.02.3 Focal with Linux 5.10.21-sunxi"
I am trying to use the 13 pin connector.  Pin 2 = ground (shield) and Pin 9 = video signal (center conductor)
I have found forum threads about enabling the tv out but ...
My current installation does not have a /boot/script.bin file ...
Other forum threads also refer to files that I do not have.
One thread says:
("the OPZ will not use the tvout port, unless you add "tv" on the /etc/modules file")  I DO have the /etc/modules file and
I tried adding the letters "tv" on the second line of my /etc/modules file but still no output.
Other threads talk about editing the fex file but I can't get the fex editor compliled and installed using their instructions.
Can anyone offer some suggestions?
Thanks in advance!
This feature is known to work on old BSP kernel (3.4.y) which this how-to is referring to and which we dropped a while ago. We can't afford to maintain big quantity of very different codebase and its pointless to support low quality outdated BSP kernel. At least not very long. Mainline kernel support for H3 is actually in quite good shape, but some features might not be supported yet. Or are broken. I think someone succeeded in bringing up TV out on modern kernel. Use forum search more.
Thanks for getting back to me!  Is there an equivalent file to the /boot/script.bin in the new kernel?  Or how is the tv out managed in the new kernel?
Thanks again!
BTW I have spent 3 days searching the forums to no avail ...  Maybe I am just not good at searching ...
  • Solution
The issue has been discussed and solved in a recent post for OPi PC, it should also work for Zero
We are well aware that our support with tips and solutions can save you days, sometimes weeks and moths. But the problem is that we also have to invest time to recall, search, focus on the problem ... while you / public / users don't value this at all. Or in rare occasions. You think it's granted, but it's actually our family time/money that is going away for your/common gain. End users also doesn't support R&D at all, but you have a desire in top support, quick answers all the time, some even dare to demand and complain. Which is why we asks at least for a small compensation https://forum.armbian.com/subscriptions/ and https://forum.armbian.com/clients/donations/ so someday this source of funding will move over 0.5% of operational costs.
Please don't take it personal. Its a general problem.
  • JMCC changed the title to [SOLVED] orange pi zero "tv out" not working.
