I tried the instruction provided on topic http://forum.armbian.com/index.php/topic/1526-armbian-in-read-only-mode/?hl=overlayfs#entry11877 but I received kernel panic and the system doesn't boot any more. I mount the SD card on my laptop, I comment the line overlayroot="tmpfs" in /etc/overlayroot.conf and the system boot again.
The package apt-get install overlayroot is not available.
In installed it manualy from http://packages.ubuntu.com/en/xenial/overlayroot
When I installed the package cryptsetup it return un error that cannot determine the root partition from /etc/fstab
Please be so kind and write step by step instructions howto make the root file system read-only.
Include also the final content of /etc/overlayroot.conf and /etc/fstab
Best regards,
Those instructions are O.K. Perhaps something is broken. Did you test it on Ubuntu Xenial ?
If I use the overlay as above, does this protect the SD from corruption if my board is subject to random power outages?
I saw in another post about removing commit and adding sync to fstab, are there any other steps I can take to make it more reliable in the case of random power outages?
Thanks.
J
This is not designed for such scenarios per se.
Yes, that would help.
@ionciubotaru
It's possible that this feature is broken on Jessie. I tested on Xenial like Johnny Blue.
