i have to update nodejs to version 14, but wenn i do
curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -sudo apt-get install -y nodejs
i become this error
bash: -d: Ungültige Option
Aufruf: bash [Lange GNU Option] [Option] ...
                bash [Lange GNU Option] [Option] Script-Datei ...
Lange GNU Optionen:
        --debug
        --debugger
        --dump-po-strings
        --dump-strings
        --help
        --init-file
        --login
        --noediting
        --noprofile
        --norc
        --posix
        --pretty-print
        --rcfile
        --restricted
        --verbose
        --version
Shell-Optionen:
        -ilrsD oder -c Kommando oder -O shopt_option            (Nur Aufruf)
        -abefhkmnptuvxBCHP oder Option -o
What can i do?
Thank you
Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs).  With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported.  Your report is invalid for one or more of the following reasons (non-exhaustive list):
  • it is for an unsupported board or image (CSC/EOS/WIP/edge)
  • it is for software that is not supported (such as userspace modules installed on top of the core operating system)
  • it has been logged in the wrong forum (for example requests for help that are not actual bug reports)
  • it lacks requested data (armbianmonitor output)
  • it could have been easily solved by a quick search and/or reading documentation
Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
vor 22 Stunden schrieb gounthar:
You could maybe just add a newline, or download https://deb.nodesource.com/setup_14.x then add -x on the first line... or change your command line like that:
curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -x
This set of commands does work for me.
When i do this, i become this message:
 curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bas        h -x
+ export DEBIAN_FRONTEND=noninteractive
+ DEBIAN_FRONTEND=noninteractive
+ SCRSUFFIX=_14.x
+ NODENAME='Node.js 14.x'
+ NODEREPO=node_14.x
+ NODEPKG=nodejs
+ test -t 1
++ which tput
++ tput colors
+ ncolors=8
+ test -n 8
+ test 8 -ge 8
++ tput cols
+ termcols=80
++ tput bold
+ bold=''
++ tput smul
+ underline=''
++ tput smso
+ standout=''
++ tput sgr0
+ normal=''
++ tput setaf 0
+ black=''
++ tput setaf 1
+ red=''
++ tput setaf 2
+ green=''
++ tput setaf 3
+ yellow=''
++ tput setaf 4
+ blue=''
++ tput setaf 5
+ magenta=''
++ tput setaf 6
+ cyan=''
++ tput setaf 7
+ white=''
+ setup
+ script_deprecation_warning
+ '[' X_14.x == X ']'
+ node_deprecation_warning
+ [[ XNode.js 14.x == \X\i\o\.\j\s\ \1\.\x ]]
+ [[ XNode.js 14.x == \X\i\o\.\j\s\ \2\.\x ]]
+ [[ XNode.js 14.x == \X\i\o\.\j\s\ \3\.\x ]]
+ [[ XNode.js 14.x == \X\N\o\d\e\.\j\s\ \0\.\1\0 ]]
+ [[ XNode.js 14.x == \X\N\o\d\e\.\j\s\ \0\.\1\2 ]]
+ [[ XNode.js 14.x == \X\N\o\d\e\.\j\s\ \4\.\x\ \L\T\S\ \A\r\g\o\n ]]
+ [[ XNode.js 14.x == \X\N\o\d\e\.\j\s\ \5\.\x ]]
+ [[ XNode.js 14.x == \X\N\o\d\e\.\j\s\ \6\.\x\ \L\T\S\ \B\o\r\o\n ]]
+ [[ XNode.js 14.x == \X\N\o\d\e\.\j\s\ \7\.\x ]]
+ [[ XNode.js 14.x == \X\N\o\d\e\.\j\s\ \8\.\x\ \L\T\S\ \C\a\r\b\o\n ]]
+ [[ XNode.js 14.x == \X\N\o\d\e\.\j\s\ \9\.\x ]]
+ [[ XNode.js 14.x == \X\N\o\d\e\.\j\s\ \1\0\.\x ]]
+ [[ XNode.js 14.x == \X\N\o\d\e\.\j\s\ \1\1\.\x ]]
+ [[ XNode.js 14.x == \X\N\o\d\e\.\j\s\ \1\3\.\x ]]
+ print_status 'Installing the NodeSource Node.js 14.x repo...'
+ echo
+ echo '## Installing the NodeSource Node.js 14.x repo...'
+ echo
++ uname -m
++ grep -Eq '^armv6'
+ PRE_INSTALL_PKGS=
+ '[' '!' -e /usr/lib/apt/methods/https ']'
+ '[' '!' -x /usr/bin/lsb_release ']'
+ PRE_INSTALL_PKGS=' lsb-release'
+ '[' '!' -x /usr/bin/curl ']'
+ '[' '!' -x /usr/bin/gpg ']'
+ print_status 'Populating apt-get cache...'
+ echo
+ echo '## Populating apt-get cache...'
+ echo
+ exec_cmd 'apt-get update'
+ exec_cmd_nobail 'apt-get update'
+ echo '+ apt-get update'
+ apt-get update
+ bash -c 'apt-get update'
Holen:1 http://security.debian.org buster/updates InRelease [65,4 kB]
OK:3 http://httpredir.debian.org/debian buster InRelease
Holen:4 http://httpredir.debian.org/debian buster-updates InRelease [51,9 kB]
Holen:5 http://httpredir.debian.org/debian buster-backports InRelease [46,7 kB]
Holen:2 https://mirrors.netix.net/armbian/apt buster InRelease [18,4 kB]
Holen:6 http://security.debian.org buster/updates/main armhf Packages [351 kB]
Holen:7 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27,8 kB]
Holen:8 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2021-05-11-1400.52.pdiff [677 B]
Holen:9 https://mirrors.netix.net/armbian/apt buster/main armhf Packages [867 kB]
Holen:10 https://mirrors.netix.net/armbian/apt buster/main armhf Contents (deb) [24,4 MB]
Holen:11 https://mirrors.netix.net/armbian/apt buster/buster-utils armhf Packages [73,9 kB]
Holen:12 https://mirrors.netix.net/armbian/apt buster/buster-utils armhf Contents (deb) [12,8 kB]
Holen:13 https://mirrors.netix.net/armbian/apt buster/buster-desktop armhf Packages [28,4 kB]
Es wurden 25,9 MB in 3 min 7 s geholt (139 kB/s).
Paketlisten werden gelesen... Fertig
+ '[' 'X lsb-release' '!=' X ']'
+ print_status 'Installing packages required for setup: lsb-release...'
+ echo
+ echo '## Installing packages required for setup: lsb-release...'
+ echo
+ exec_cmd 'apt-get install -y lsb-release > /dev/null 2>&1'
+ exec_cmd_nobail 'apt-get install -y lsb-release > /dev/null 2>&1'
+ echo '+ apt-get install -y lsb-release > /dev/null 2>&1'
+ bash -c 'apt-get install -y lsb-release > /dev/null 2>&1'
++ lsb_release -d
++ grep 'Ubuntu .*development'
main: Zeile 206: lsb_release: Kommando nicht gefunden.
++ echo 1
+ IS_PRERELEASE=1
+ [[ 1 -eq 0 ]]
++ lsb_release -c -s
main: Zeile 212: lsb_release: Kommando nicht gefunden.
+ DISTRO=
+ check_alt SolydXK solydxk-9 Debian stretch
+ '[' X == Xsolydxk-9 ']'
+ check_alt Kali sana Debian jessie
+ '[' X == Xsana ']'
+ check_alt Kali kali-rolling Debian bullseye
+ '[' X == Xkali-rolling ']'
+ check_alt 'Sparky Linux' Tyche Debian stretch
+ '[' X == XTyche ']'
+ check_alt 'Sparky Linux' Nibiru Debian buster
+ '[' X == XNibiru ']'
+ check_alt 'MX Linux 17' Horizon Debian stretch
+ '[' X == XHorizon ']'
+ check_alt 'MX Linux 18' Continuum Debian stretch
+ '[' X == XContinuum ']'
+ check_alt 'MX Linux 19' 'patito feo' Debian buster
+ '[' X == 'Xpatito feo' ']'
+ check_alt 'Linux Mint' maya Ubuntu precise
+ '[' X == Xmaya ']'
+ check_alt 'Linux Mint' qiana Ubuntu trusty
+ '[' X == Xqiana ']'
+ check_alt 'Linux Mint' rafaela Ubuntu trusty
+ '[' X == Xrafaela ']'
+ check_alt 'Linux Mint' rebecca Ubuntu trusty
+ '[' X == Xrebecca ']'
+ check_alt 'Linux Mint' rosa Ubuntu trusty
+ '[' X == Xrosa ']'
+ check_alt 'Linux Mint' sarah Ubuntu xenial
+ '[' X == Xsarah ']'
+ check_alt 'Linux Mint' serena Ubuntu xenial
+ '[' X == Xserena ']'
+ check_alt 'Linux Mint' sonya Ubuntu xenial
+ '[' X == Xsonya ']'
+ check_alt 'Linux Mint' sylvia Ubuntu xenial
+ '[' X == Xsylvia ']'
+ check_alt 'Linux Mint' tara Ubuntu bionic
+ '[' X == Xtara ']'
+ check_alt 'Linux Mint' tessa Ubuntu bionic
+ '[' X == Xtessa ']'
+ check_alt 'Linux Mint' tina Ubuntu bionic
+ '[' X == Xtina ']'
+ check_alt 'Linux Mint' tricia Ubuntu bionic
+ '[' X == Xtricia ']'
+ check_alt 'Linux Mint' ulyana Ubuntu focal
+ '[' X == Xulyana ']'
+ check_alt 'Linux Mint' ulyssa Ubuntu focal
+ '[' X == Xulyssa ']'
+ check_alt LMDE betsy Debian jessie
+ '[' X == Xbetsy ']'
+ check_alt LMDE cindy Debian stretch
+ '[' X == Xcindy ']'
+ check_alt LMDE debbie Debian buster
+ '[' X == Xdebbie ']'
+ check_alt elementaryOS luna Ubuntu precise
+ '[' X == Xluna ']'
+ check_alt elementaryOS freya Ubuntu trusty
+ '[' X == Xfreya ']'
+ check_alt elementaryOS loki Ubuntu xenial
+ '[' X == Xloki ']'
+ check_alt elementaryOS juno Ubuntu bionic
+ '[' X == Xjuno ']'
+ check_alt elementaryOS hera Ubuntu bionic
+ '[' X == Xhera ']'
+ check_alt elementaryOS odin Ubuntu focal
+ '[' X == Xodin ']'
+ check_alt Trisquel toutatis Ubuntu precise
+ '[' X == Xtoutatis ']'
+ check_alt Trisquel belenos Ubuntu trusty
+ '[' X == Xbelenos ']'
+ check_alt Trisquel flidas Ubuntu xenial
+ '[' X == Xflidas ']'
+ check_alt Trisquel etiona Ubuntu bionic
+ '[' X == Xetiona ']'
+ check_alt 'Uruk GNU/Linux' lugalbanda Ubuntu xenial
+ '[' X == Xlugalbanda ']'
+ check_alt BOSS anokha Debian wheezy
+ '[' X == Xanokha ']'
+ check_alt BOSS anoop Debian jessie
+ '[' X == Xanoop ']'
+ check_alt BOSS drishti Debian stretch
+ '[' X == Xdrishti ']'
+ check_alt BOSS unnati Debian buster
+ '[' X == Xunnati ']'
+ check_alt bunsenlabs bunsen-hydrogen Debian jessie
+ '[' X == Xbunsen-hydrogen ']'
+ check_alt bunsenlabs helium Debian stretch
+ '[' X == Xhelium ']'
+ check_alt bunsenlabs lithium Debian buster
+ '[' X == Xlithium ']'
+ check_alt Tanglu chromodoris Debian jessie
+ '[' X == Xchromodoris ']'
+ check_alt PureOS green Debian sid
+ '[' X == Xgreen ']'
+ check_alt PureOS amber Debian buster
+ '[' X == Xamber ']'
+ check_alt Devuan jessie Debian jessie
+ '[' X == Xjessie ']'
+ check_alt Devuan ascii Debian stretch
+ '[' X == Xascii ']'
+ check_alt Devuan beowulf Debian buster
+ '[' X == Xbeowulf ']'
+ check_alt Devuan ceres Debian sid
+ '[' X == Xceres ']'
+ check_alt Deepin panda Debian sid
+ '[' X == Xpanda ']'
+ check_alt Deepin unstable Debian sid
+ '[' X == Xunstable ']'
+ check_alt Deepin stable Debian buster
+ '[' X == Xstable ']'
+ check_alt Pardus onyedi Debian stretch
+ '[' X == Xonyedi ']'
+ check_alt 'Liquid Lemur' lemur-3 Debian stretch
+ '[' X == Xlemur-3 ']'
+ check_alt 'Astra Linux' orel Debian stretch
+ '[' X == Xorel ']'
+ check_alt Ubilinux dolcetto Debian stretch
+ '[' X == Xdolcetto ']'
+ '[' X == Xdebian ']'
+ print_status 'Confirming "" is supported...'
+ echo
+ echo '## Confirming "" is supported...'
+ echo
+ '[' -x /usr/bin/curl ']'
+ exec_cmd_nobail 'curl -sLf -o /dev/null '\''https://deb.nodesource.com/node_14.x/dists//Release'\'''
+ echo '+ curl -sLf -o /dev/null '\''https://deb.nodesource.com/node_14.x/dists//Release'\'''
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists//Release'
+ bash -c 'curl -sLf -o /dev/null '\''https://deb.nodesource.com/node_14.x/dists//Release'\'''
+ RC=22
+ [[ 22 != 0 ]]
+ print_status 'Your distribution, identified as "", is not currently supported, please contact NodeSource at https://github.com/nodesource/distributions/issues if you think this is incorrect or would like your distribution to be considered for support'
+ echo
+ echo '## Your distribution, identified as "", is not currently supported, please contact NodeSource at https://github.com/nodesource/distributions/issues if you think this is incorrect or would like your distribution to be considered for support'
+ echo
+ exit 1
vor 15 Stunden schrieb Werner:
I'm not sure if is a error or a layer 8 problem.....
when you say its a erorr i will make a bug report
The software you are trying to install/update is userspace and therefor out of scope from Armbian.
Support is only possible for software that Armbian ships.
