zeyoner Posted May 22, 2021 Posted May 22, 2021 (edited) Fresh install of Armbian_21.05.1_Rockpi-4b_buster_current_5.10.35 Ran apt update/upgrade Reboot arm-config>softy>install linux headers It seems to be affecting the latest release only. Tested with Armbian_21.02.3_Rockpi-4b_buster_current_5.10.21 and it works until it's upgraded. I also tried disabling kernel upgrades before upgrading and still received this error. Edited May 22, 2021 by zeyoner
Werner Posted May 22, 2021 Posted May 22, 2021 Interesting. You can try to install them manually for now. apt install linux-headers-current-rockchip64
Solution Igor Posted May 22, 2021 Solution Posted May 22, 2021 11 hours ago, zeyoner said: It seems to be affecting the latest release only. Problem was fixed, but you need to apt upgrade and reboot.
zeyoner Posted May 23, 2021 Author Posted May 23, 2021 23 hours ago, Igor said: Problem was fixed, but you need to apt upgrade and reboot. Thank you very much Igor.
zeyoner Posted May 23, 2021 Author Posted May 23, 2021 On 5/22/2021 at 3:48 AM, Werner said: Interesting. You can try to install them manually for now. apt install linux-headers-current-rockchip64 Thanks!
