I had to reinstall on my Linux desktop due to a hard drive failure. I copied the mounting language in my /etc/fstab file and now it times out on mounting. This is my mounting entry which worked fine before
192.168.0.123:/mnt/md0 /mnt/RAID nfs rw,_netdev,hard,intr,rsize=8192,wsize=8192,timeo=14,user 0 0
That used to work. I made no changes to my Helios4. When I try to mount it manually, this is what I get:
mount -av
mount.nfs: timeout set for Fri Jul 23 07:26:16 2021
mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,vers=4.2,addr=192.168.0.123,clientaddr=192.168.0.2'
mount.nfs: mount(2): Connection refused
mount.nfs: trying text-based options 'hard,intr,rsize=8192,wsize=8192,timeo=14,addr=192.168.0.123'
mount.nfs: prog 100003, trying vers=3, prot=6
mount.nfs: portmap query retrying: RPC: Unable to receive
mount.nfs: prog 100003, trying vers=3, prot=17
mount.nfs: portmap query failed: RPC: Unable to receive - Connection refused
mount.nfs: Connection timed out
I have no idea why the Helios4 is refusing the connection when it worked fine before. Any help would greatly be appreciated.
Moved to proper forums.
Please provide output of armbianmonitor -u
Just a hunch, have you maybe on the helios specified the ip address of your laptop? And that has changed?
     1
     2  ### lsusb:
     3
     4  Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
     5  Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
     6  Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
     7  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
     8  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
     9
    10  /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    11  /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
    12  /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    13  /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
    14  /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=orion-ehci/1p, 480M
    15
    16  ### lspci:
    17
    18
    19  ### Installed packages:
    20
    21  ii  armbian-config                  5.91                           all          Armbian configuration utility
    22  ii  armbian-firmware                5.91                           all          Linux firmware
    23  ii  armbian-tools-stretch           5.91                           armhf        Armbian tools, Cubie bt utils
    24  ii  hostapd                         3:2.7-99~armbian5.86+1         armhf        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
    25  ii  linux-base                      4.5                            all          Linux image base package
    26  ii  linux-dtb-mvebu                 5.91                           armhf        Linux DTB, version 4.14.135-mvebu
    27  ii  linux-image-mvebu               5.91                           armhf        Linux kernel, version 4.14.135-mvebu
    28  ii  linux-libc-dev                  5.70                           armhf        Linux support headers for userspace development
    29  ii  linux-stretch-root-helios4      5.91                           armhf        Armbian tweaks for stretch on helios4 (default branch)
    30  ii  linux-u-boot-helios4-default    5.91                           armhf        Uboot loader 2018.11
    31  ii  sunxi-tools                     1.4.2-2~armbian5.86+1          armhf        tools for working with Allwinner (sunxi) ARM processors
    32
    33  ### Loaded modules:
    34
    35  Module                  Size  Used by
    36  lz4hc                  16384  2
    37  lz4hc_compress         24576  1 lz4hc
    38  zram                   20480  2
    39  zsmalloc               20480  1 zram
    40  orion_wdt              16384  0
    41  pwm_fan                16384  0
    42  lm75                   20480  0
    43  marvell_cesa           28672  0
    44  ip_tables              20480  0
    45  x_tables               20480  1 ip_tables
    46  raid456               102400  0
    47  async_raid6_recov      16384  1 raid456
    48  async_memcpy           16384  2 raid456,async_raid6_recov
    49  async_pq               16384  2 raid456,async_raid6_recov
    50  async_xor              16384  3 async_pq,raid456,async_raid6_recov
    51  async_tx               16384  5 async_xor,async_pq,raid456,async_memcpy,async_raid6_recov
    52  raid1                  32768  0
    53  raid0                  20480  0
    54  raid10                 45056  1
    55  md_mod                 98304  5 raid1,raid10,raid0,raid456
    56
    57  ### Current system health:
    58
    59  Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
    60  22:28:13:   ---      0.00   1%   0%   0%   0%   0%   1% 53.2°C  0/0
    61  22:28:14:   ---      0.00   5%   5%   0%   0%   0%   0% 50.8°C  0/0
    62  22:28:14:   ---      0.00   8%   7%   0%   1%   0%   0% 50.4°C  0/0
    63  22:28:14:   ---      0.00   7%   5%   0%   1%   0%   0% 49.9°C  0/0
    64  22:28:15:   ---      0.00   5%   5%   0%   0%   0%   0% 50.8°C  0/0
    65  22:28:16:   ---      0.00   1%   0%   0%   0%   0%   1% 56.5°C  0/0
    66  22:28:17:   ---      0.24 100%   0% 100%   0%   0%   0% 58.0°C  0/0
    67  22:28:18:   ---      0.24  91%   0%  91%   0%   0%   0% 53.7°C  0/0
    68  22:28:19:   ---      0.24   8%   7%   0%   1%   0%   0% 51.3°C  0/0
    69  22:28:19:   ---      0.24   5%   5%   0%   0%   0%   0% 51.3°C  0/0
    70
    71  ### resolv.conf
    72
    73  -rw-r--r-- 1 root root 72 Feb 20 03:07 /etc/resolv.conf
    74  # Generated by NetworkManager
    75  nameserver XXX.XXX.8.8
    76  nameserver XXX.XXX.0.1
    77
    78  ### Current sysinfo:
    79
    80  Linux 4.14.135-mvebu (helios4)  07/20/21        _armv7l_        (2 CPU)
    81
    82  avg-cpu:  %user   %nice %system %iowait  %steal   %idle
    83             0.02    0.00    1.80    0.00    0.00   98.18
    84
    85  Device:            tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
    86  mmcblk0           0.00         0.01         0.23      93625    3033460
    87  mmcblk0p1         0.00         0.01         0.23      90501    3033460
    88  sda               8.40        87.60         0.01 1176984692      86060
    89  sdb               8.40        87.60         0.01 1176983800      86060
    90  sdc               8.43        87.60         0.01 1176985004      86056
    91  sdd               8.45        87.60         0.01 1176983232      86056
    92  md0               0.00         0.00         0.00       6029          4
    93  zram0             0.09         0.00         0.34        780    4599692
    94  zram1             0.00         0.00         0.00       1196          4
    95  zram2             0.00         0.00         0.00          0          0
    96
    97  procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
    98   r  b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
    99   0  0            0      1701924        39736       163956    0    0     0     0    0    1   0   2  98   0   0
   100
   101                total        used        free      shared  buff/cache   available
   102  Mem:           2.0G        157M        1.6G         24M        198M        1.7G
   103  Swap:          1.0G          0B        1.0G
   104
   105  NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
   106  /dev/zram0                50M 21.7M  2.4M  2.7M       2 /var/log
   107  /dev/zram1 lzo        1009.2M    4K   81B   12K       2 [SWAP]
   108
   109   22:28:19 up 155 days, 12:11,  1 user,  load average: 0.24, 0.05, 0.02
   110
   111  [    1.418518] workingset: timestamp_bits=14 max_order=19 bucket_order=5
   112  [    1.420495] zbud: loaded
   113  [    1.421185] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   114  [    1.421401] FS-Cache: Netfs 'nfs' registered for caching
   115  [    1.421580] NFS: Registering the id_resolver key type
   116  [    1.421591] Key type id_resolver registered
   117  [    1.421593] Key type id_legacy registered
   118  [    1.421599] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   119  [    1.421677] fuse init (API version 7.26)
   120  [    1.421939] aufs 4.14-20171218
   121  [    1.424123] bounce: pool size: 64 pages
   122  [    1.424156] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
   123  [    1.424210] io scheduler noop registered
   124  [    1.424212] io scheduler deadline registered
   125  [    1.424287] io scheduler cfq registered (default)
   126  [    1.424289] io scheduler mq-deadline registered
   127  [    1.424291] io scheduler kyber registered
   128  [    1.424351] io scheduler bfq registered
   129  [    1.425009] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
   130  [    1.426260] mv_xor f1060800.xor: Marvell shared XOR driver
   131  [    1.453583] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
   132  [    1.453677] mv_xor f1060900.xor: Marvell shared XOR driver
   133  [    1.489572] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
   134  [    1.504325] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
   135  [    1.505222] console [ttyS0] disabled
   136  [    1.525285] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
   137  [    1.525311] console [ttyS0] enabled
   138  [    1.527957] loop: module loaded
   139  [    1.528465] ahci-mvebu f10a8000.sata: masking port_map 0x3 -> 0x3
   140  [    1.528495] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
   141  [    1.528500] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
   142  [    1.529029] scsi host0: ahci-mvebu
   143  [    1.529218] scsi host1: ahci-mvebu
   144  [    1.529293] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 41
   145  [    1.529296] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 41
   146  [    1.529554] ahci-mvebu f10e0000.sata: masking port_map 0x3 -> 0x3
   147  [    1.529580] ahci-mvebu f10e0000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
   148  [    1.529586] ahci-mvebu f10e0000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
   149  [    1.530110] scsi host2: ahci-mvebu
   150  [    1.530251] scsi host3: ahci-mvebu
   151  [    1.530327] ata3: SATA max UDMA/133 mmio [mem 0xf10e0000-0xf10e1fff] port 0x100 irq 42
   152  [    1.530330] ata4: SATA max UDMA/133 mmio [mem 0xf10e0000-0xf10e1fff] port 0x180 irq 42
   153  [    1.530811] libphy: Fixed MDIO Bus: probed
   154  [    1.531069] libphy: orion_mdio_bus: probed
   155  [    1.534019] mvneta_bm f10c8000.bm: Buffer Manager for network controller enabled
   156  [    1.535436] mvneta f1070000.ethernet eth0: Using device tree mac address 0e:5a:0f:9d:78:b4
   157  [    1.535599] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   158  [    1.535601] ehci-pci: EHCI PCI platform driver
   159  [    1.535631] ehci-orion: EHCI orion driver
   160  [    1.535712] orion-ehci f1058000.usb: EHCI Host Controller
   161  [    1.535729] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
   162  [    1.535814] orion-ehci f1058000.usb: irq 37, io mem 0xf1058000
   163  [    1.549114] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
   164  [    1.549216] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
   165  [    1.549220] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   166  [    1.549223] usb usb1: Product: EHCI Host Controller
   167  [    1.549226] usb usb1: Manufacturer: Linux 4.14.135-mvebu ehci_hcd
   168  [    1.549229] usb usb1: SerialNumber: f1058000.usb
   169  [    1.549447] hub 1-0:1.0: USB hub found
   170  [    1.549469] hub 1-0:1.0: 1 port detected
   171  [    1.549826] xhci-hcd f10f0000.usb3: xHCI Host Controller
   172  [    1.549836] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
   173  [    1.549957] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
   174  [    1.549982] xhci-hcd f10f0000.usb3: irq 44, io mem 0xf10f0000
   175  [    1.550068] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
   176  [    1.550071] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   177  [    1.550074] usb usb2: Product: xHCI Host Controller
   178  [    1.550077] usb usb2: Manufacturer: Linux 4.14.135-mvebu xhci-hcd
   179  [    1.550080] usb usb2: SerialNumber: f10f0000.usb3
   180  [    1.550265] hub 2-0:1.0: USB hub found
   181  [    1.550281] hub 2-0:1.0: 1 port detected
   182  [    1.550400] xhci-hcd f10f0000.usb3: xHCI Host Controller
   183  [    1.550407] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
   184  [    1.550422] xhci-hcd f10f0000.usb3: Host supports USB 3.0  SuperSpeed
   185  [    1.550455] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
   186  [    1.550512] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
   187  [    1.550516] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   188  [    1.550519] usb usb3: Product: xHCI Host Controller
   189  [    1.550521] usb usb3: Manufacturer: Linux 4.14.135-mvebu xhci-hcd
   190  [    1.550524] usb usb3: SerialNumber: f10f0000.usb3
   191  [    1.550690] hub 3-0:1.0: USB hub found
   192  [    1.550705] hub 3-0:1.0: 1 port detected
   193  [    1.550885] xhci-hcd f10f8000.usb3: xHCI Host Controller
   194  [    1.550895] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
   195  [    1.551008] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
   196  [    1.551030] xhci-hcd f10f8000.usb3: irq 45, io mem 0xf10f8000
   197  [    1.551108] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
   198  [    1.551112] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   199  [    1.551114] usb usb4: Product: xHCI Host Controller
   200  [    1.551117] usb usb4: Manufacturer: Linux 4.14.135-mvebu xhci-hcd
   201  [    1.551120] usb usb4: SerialNumber: f10f8000.usb3
   202  [    1.551298] hub 4-0:1.0: USB hub found
   203  [    1.551313] hub 4-0:1.0: 1 port detected
   204  [    1.551443] xhci-hcd f10f8000.usb3: xHCI Host Controller
   205  [    1.551450] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
   206  [    1.551459] xhci-hcd f10f8000.usb3: Host supports USB 3.0  SuperSpeed
   207  [    1.551491] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
   208  [    1.551546] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
   209  [    1.551550] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   210  [    1.551553] usb usb5: Product: xHCI Host Controller
   211  [    1.551556] usb usb5: Manufacturer: Linux 4.14.135-mvebu xhci-hcd
   212  [    1.551558] usb usb5: SerialNumber: f10f8000.usb3
   213  [    1.551722] hub 5-0:1.0: USB hub found
   214  [    1.551736] hub 5-0:1.0: 1 port detected
   215  [    1.551963] usbcore: registered new interface driver usb-storage
   216  [    1.552066] mousedev: PS/2 mouse device common for all mice
   217  [    1.552525] armada38x-rtc f10a3800.rtc: rtc core: registered f10a3800.rtc as rtc0
   218  [    1.552631] i2c /dev entries driver
   219  [    1.552926] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator
   220  [    1.555283] GPIO line 496 (board-rev-0) hogged as input
   221  [    1.555477] GPIO line 497 (board-rev-1) hogged as input
   222  [    1.555671] GPIO line 501 (usb-overcurrent-status) hogged as input
   223  [    1.556378] armada_thermal f10e4078.thermal: res size = 8
   224  [    1.557174] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
   225  [    1.557432] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
   226  [    1.557743] cpu cpu1: opp_list_debug_create_link: Failed to create link
   227  [    1.557747] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
   228  [    1.557882] sdhci: Secure Digital Host Controller Interface driver
   229  [    1.557884] sdhci: Copyright(c) Pierre Ossman
   230  [    1.558051] sdhci-pxav3 f10d8000.sdhci: Got CD GPIO
   231  [    1.612167] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
   232  [    1.612335] sdhci-pltfm: SDHCI platform and OF driver helper
   233  [    1.613179] ledtrig-cpu: registered to indicate activity on CPUs
   234  [    1.613226] hidraw: raw HID events driver (C) Jiri Kosina
   235  [    1.613307] usbcore: registered new interface driver usbhid
   236  [    1.613309] usbhid: USB HID core driver
   237  [    1.613630] ipip: IPv4 and MPLS over IPv4 tunneling driver
   238  [    1.613942] Initializing XFRM netlink socket
   239  [    1.614382] NET: Registered protocol family 10
   240  [    1.626622] Segment Routing with IPv6
   241  [    1.626688] NET: Registered protocol family 17
   242  [    1.626704] NET: Registered protocol family 15
   243  [    1.626734] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
   244  [    1.626773] 8021q: 802.1Q VLAN Support v1.8
   245  [    1.626797] Key type dns_resolver registered
   246  [    1.626967] ThumbEE CPU extension supported.
   247  [    1.626975] Registering SWP/SWPB emulation handler
   248  [    1.627743] registered taskstats version 1
   249  [    1.627772] zswap: loaded using pool lzo/zbud
   250  [    1.628412] Btrfs loaded, crc32c=crc32c-generic
   251  [    1.631419] Key type encrypted registered
   252  [    1.632304] USB-PWR: supplied by power_brick_12V
   253  [    1.632738] input: gpio-keys as /devices/platform/gpio-keys/input/input0
   254  [    1.654360] mmc0: new high speed SDHC card at address aaaa
   255  [    1.654759] mmcblk0: mmc0:aaaa SP32G 29.7 GiB
   256  [    1.655695]  mmcblk0: p1
   257  [    2.011871] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
   258  [    2.011891] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
   259  [    2.011910] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
   260  [    2.011925] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
   261  [    2.012374] ata3.00: ATA-10: WDC WD20EFAX-68FB5N0, 82.00A82, max UDMA/133
   262  [    2.012381] ata3.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32)
   263  [    2.012417] ata4.00: ATA-10: WDC WD20EFAX-68FB5N0, 82.00A82, max UDMA/133
   264  [    2.012421] ata1.00: ATA-10: WDC WD20EFAX-68FB5N0, 82.00A82, max UDMA/133
   265  [    2.012427] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32)
   266  [    2.012432] ata4.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32)
   267  [    2.012455] ata2.00: ATA-10: WDC WD20EFAX-68FB5N0, 82.00A82, max UDMA/133
   268  [    2.012461] ata2.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32)
   269  [    2.012856] ata3.00: configured for UDMA/133
   270  [    2.012894] ata4.00: configured for UDMA/133
   271  [    2.012914] ata1.00: configured for UDMA/133
   272  [    2.012938] ata2.00: configured for UDMA/133
   273  [    2.013301] scsi 0:0:0:0: Direct-Access     ATA      WDC WD20EFAX-68F 0A82 PQ: 0 ANSI: 5
   274  [    2.013800] sd 0:0:0:0: Attached scsi generic sg0 type 0
   275  [    2.013843] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
sysctl: permission denied on key 'vm.mmap_rnd_bits'
sysctl: permission denied on key 'vm.stat_refresh'
   276  [    2.013850] sd 0:0:0:0: [sda] 4096-byte physical blocks
   277  [    2.013891] sd 0:0:0:0: [sda] Write Protect is off
   278  [    2.013899] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
   279  [    2.014209] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
   280  [    2.014226] scsi 1:0:0:0: Direct-Access     ATA      WDC WD20EFAX-68F 0A82 PQ: 0 ANSI: 5
   281  [    2.014716] sd 1:0:0:0: Attached scsi generic sg1 type 0
   282  [    2.015145] scsi 2:0:0:0: Direct-Access     ATA      WDC WD20EFAX-68F 0A82 PQ: 0 ANSI: 5
   283  [    2.015263] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
   284  [    2.015271] sd 1:0:0:0: [sdb] 4096-byte physical blocks
   285  [    2.015304] sd 1:0:0:0: [sdb] Write Protect is off
   286  [    2.015311] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
   287  [    2.015366] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
   288  [    2.015633] sd 2:0:0:0: Attached scsi generic sg2 type 0
   289  [    2.016068] scsi 3:0:0:0: Direct-Access     ATA      WDC WD20EFAX-68F 0A82 PQ: 0 ANSI: 5
   290  [    2.016305] sd 0:0:0:0: [sda] Attached SCSI removable disk
   291  [    2.016516] sd 3:0:0:0: Attached scsi generic sg3 type 0
   292  [    2.016604] sd 3:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
   293  [    2.016611] sd 3:0:0:0: [sdd] 4096-byte physical blocks
   294  [    2.016721] sd 3:0:0:0: [sdd] Write Protect is off
   295  [    2.016728] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
   296  [    2.016792] sd 2:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
   297  [    2.016799] sd 2:0:0:0: [sdc] 4096-byte physical blocks
   298  [    2.016834] sd 2:0:0:0: [sdc] Write Protect is off
   299  [    2.016841] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
   300  [    2.016852] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
   301  [    2.016896] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
   302  [    2.018324] sd 1:0:0:0: [sdb] Attached SCSI removable disk
   303  [    2.018776] sd 2:0:0:0: [sdc] Attached SCSI removable disk
   304  [    2.019033] sd 3:0:0:0: [sdd] Attached SCSI removable disk
   305  [    2.019971] Freeing unused kernel memory: 1024K
   306  [    2.066014] random: systemd-udevd: uninitialized urandom read (16 bytes read)
   307  [    2.066285] random: systemd-udevd: uninitialized urandom read (16 bytes read)
   308  [    2.066330] random: systemd-udevd: uninitialized urandom read (16 bytes read)
   309  [    2.363490] md/raid10:md0: active with 4 out of 4 devices
   310  [    2.393322] random: fast init done
   311  [    2.486500] md0: detected capacity change from 0 to 4000529252352
   312  [    2.821801] async_tx: api initialized (async)
   313  [    3.248590] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
   314  [    3.339212] random: crng init done
   315  [    3.339218] random: 7 urandom warning(s) missed due to ratelimiting
   316  [    3.689317] systemd[1]: System time before build time, advancing clock.
   317  [    3.703082] ip_tables: (C) 2000-2006 Netfilter Core Team
   318  [    3.727753] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
   319  [    3.727941] systemd[1]: Detected architecture arm.
   320  [    3.754664] systemd[1]: Set hostname to <helios4>.
   321  [    4.045470] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
   322  [    4.065388] systemd[1]: Listening on Journal Socket.
   323  [    4.077320] systemd[1]: Listening on Journal Audit Socket.
   324  [    4.091507] systemd[1]: Listening on Journal Socket (/dev/log).
   325  [    4.107500] systemd[1]: Listening on udev Control Socket.
   326  [    4.123405] systemd[1]: Reached target Remote File Systems.
   327  [    4.139565] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
   328  [    4.394086] marvell-cesa f1090000.crypto: CESA device successfully registered
   329  [    4.396646] lm75 0-004c: hwmon2: sensor 'lm75'
   330  [    4.443766] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
   331  [    4.866967] systemd-journald[235]: Received request to flush runtime journal from PID 1
   332  [    5.245518] orion_wdt: Initial timeout 171 sec
   333  [    5.388607] zram: Added device: zram0
   334  [    5.388807] zram: Added device: zram1
   335  [    5.389730] zram: Added device: zram2
   336  [    5.545296] zram1: detected capacity change from 0 to 1058217984
   337  [    5.631424] Adding 1033412k swap on /dev/zram1.  Priority:5 extents:1 across:1033412k SSFS
   338  [    5.909965] zram0: detected capacity change from 0 to 52428800
   339  [    6.521216] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
   340  [    7.067054] EXT4-fs (md0): recovery complete
   341  [    7.067065] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: discard
   342  [    9.414066] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
   343  [    9.431147] nr_pdflush_threads exported in /proc is scheduled for removal
   344  [    9.490185] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
   345  [   11.613505] mvneta f1070000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
   346  [   11.613523] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
   347  [404999.141602] mvneta f1070000.ethernet eth0: Link is Down
   348  [406195.088570] mvneta f1070000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
   349  [1694283.900809] md: data-check of RAID array md0
   350  [1713878.962099] md: md0: data-check done.
   351  [4113309.689665] md: data-check of RAID array md0
   352  [4132908.488867] md: md0: data-check done.
   353  [6532336.261381] md: data-check of RAID array md0
   354  [6551934.240206] md: md0: data-check done.
   355  [7636727.092602] mvneta f1070000.ethernet eth0: Link is Down
   356  [7636728.109759] mvneta f1070000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
   357  [9556119.551723] md: data-check of RAID array md0
   358  [9575714.138632] md: md0: data-check done.
   359  [11975146.058893] md: data-check of RAID array md0
   360  [11994739.680076] md: md0: data-check done.
   361
   362
   363  vm.admin_reserve_kbytes = 8192
   364  vm.block_dump = 0
   365  vm.compact_unevictable_allowed = 1
   366  vm.dirty_background_bytes = 0
   367  vm.dirty_background_ratio = 10
   368  vm.dirty_bytes = 0
   369  vm.dirty_expire_centisecs = 3000
   370  vm.dirty_ratio = 20
   371  vm.dirty_writeback_centisecs = 500
   372  vm.dirtytime_expire_seconds = 43200
   373  vm.drop_caches = 0
   374  vm.extfrag_threshold = 500
   375  vm.highmem_is_dirtyable = 0
   376  vm.laptop_mode = 0
   377  vm.legacy_va_layout = 0
   378  vm.lowmem_reserve_ratio = 32    32
   379  vm.max_map_count = 65530
   380  vm.min_free_kbytes = 3463
   381  vm.mmap_min_addr = 4096
   382  vm.nr_pdflush_threads = 0
   383  vm.oom_dump_tasks = 1
   384  vm.oom_kill_allocating_task = 0
   385  vm.overcommit_kbytes = 0
   386  vm.overcommit_memory = 0
   387  vm.overcommit_ratio = 50
   388  vm.page-cluster = 0
   389  vm.panic_on_oom = 0
   390  vm.percpu_pagelist_fraction = 0
   391  vm.stat_interval = 1
   392  vm.swappiness = 100
   393  vm.user_reserve_kbytes = 64331
   394  vm.vfs_cache_pressure = 100
   395  vm.watermark_scale_factor = 10
   396
   397  ### interrupts:
   398             CPU0       CPU1
   399   17: 2900226778 3397521340     GIC-0  29 Edge      twd
   400   18:          0          0      MPIC   5 Level     armada_370_xp_per_cpu_tick
   401   19:          0          0      MPIC   3 Level     arm-pmu
   402   20:        211          0     GIC-0  34 Level     mv64xxx_i2c
   403   21:          0          0     GIC-0  35 Level     mv64xxx_i2c
   404   22:        762          0     GIC-0  44 Level     ttyS0
   405   36:    6693030    4165444      MPIC   8 Level     eth0
   406   37:          0          0     GIC-0  50 Level     ehci_hcd:usb1
   407   38:          0          0     GIC-0  51 Level     f1090000.crypto
   408   39:          0          0     GIC-0  52 Level     f1090000.crypto
   409   40:          0          0     GIC-0  53 Level     f10a3800.rtc
   410   41:  225226275          0     GIC-0  58 Level     ahci-mvebu[f10a8000.sata]
   411   42:  226148189          0     GIC-0  60 Level     ahci-mvebu[f10e0000.sata]
   412   43:     153044          0     GIC-0  57 Level     mmc0
   413   44:          0          0     GIC-0  48 Level     xhci-hcd:usb2
   414   45:          0          0     GIC-0  49 Level     xhci-hcd:usb4
   415   46:          2          0     GIC-0  54 Level     f1060800.xor
   416   47:          2          0     GIC-0  97 Level     f1060900.xor
   417   48:          0          0  f1018100.gpio  23 Level     0-0020
   418   49:          1          0  f1018100.gpio  20 Edge      f10d8000.sdhci cd
   419   50:          6          0  f1018100.gpio  18 Edge      Wake-On-LAN
   420  IPI0:          0          1  CPU wakeup interrupts
   421  IPI1:          0          0  Timer broadcast interrupts
   422  IPI2:  203285205   32150280  Rescheduling interrupts
   423  IPI3:    3140055    1275471  Function call interrupts
   424  IPI4:          0          0  CPU stop interrupts
   425  IPI5:   23062240   23212920  IRQ work interrupts
   426  IPI6:          0          0  completion interrupts
   427  Err:          0
All your firmware packages are way outdated. Consider upgrading to supported packages.
