Hey.
I'm trying to install Home Assistant through "softy" in the armbian-config tool on my nanopi neo plus 2.
The process seems like it goes through, but I can't connect to the interface (ip-address:8123).
Would someone be able to point me to the script that softy uses for this installation, so I can try to do the steps manually?
(I wish to install with Home Assistant with "supervision", and haven't been able to do it with their guides, so now I'm trying throuhg armbian-config).
Regards
Anders
The method to install home assistant supervised in the armbian script does not work any more, even if you have a version of their script there are assets it tries to pull from web locations which have been removed so you have to use their new method.
This part of the Armbian script:
debconf-apt-progress -- apt-get install -y apparmor-utils apt-transport-https avahi-daemon ca-certificates \
	dbus jq network-manager socat software-properties-common
curl -sL "https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh" | \
	bash -s -- -m  ${machine}
should be replaced with:
apt-get install \
jq \
wget \
curl \
udisks2 \
libglib2.0-bin \
network-manager \
dbus -y
#next line is for 64bit platforms, need arm7 instead of aarch64 for 32bits
wget https://github.com/home-assistant/os-agent/releases/download/1.2.2/os-agent_1.2.2_linux_aarch64.deb
dpkg -i os-agent_1.0.0_linux_x86_64.deb
wget https://github.com/home-assistant/supervised-installer/releases/latest/download/homeassistant-supervised.deb
dpkg -i homeassistant-supervised.deb
I would not advise using armbian-config to do this since it it very easy to miss error messages since when the installer finishes the screen instantly refreshes and errors are lost, then you have to hunt for a log file if one exists.
apt-get install \
jq \
wget \
curl \
udisks2 \
libglib2.0-bin \
network-manager \
dbus -y
You made some fault in your script for the os agent. You download the aarch64 but dpkg the x86_64 what is not dowloaded. Correct script should be complete:
apt-get install \
jq \
wget \
curl \
udisks2 \
libglib2.0-bin \
network-manager \
dbus -y
dpkg -i os-agent_1.2.2_linux_aarch64.deb
Or for people who want a littlebit simple in three commands:
sudo apt-get install jq wget curl udisks2 libglib2.0-bin network-manager dbus -y
#next line is for 64bit platforms, need arm7 instead of aarch64 for 32bits. You need to run this command in SU mode!
sudo su
The supervised version has a lot more functions than the standard home assistant but is not officially supported to run on Armbian. But my experience is that it wil run awesome and stable!
