Dolence Posted August 4, 2021 Posted August 4, 2021 Hi! I got this on glxgears: 111 frames in 5.0 seconds = 22.122 FPS 184 frames in 5.0 seconds = 36.786 FPS It seems to be handled in software: name of display: :0.0 display: :0 screen: 0 direct rendering: Yes Extended renderer info (GLX_MESA_query_renderer): Vendor: VMware, Inc. (0xffffffff) Device: llvmpipe (LLVM 7.0, 128 bits) (0xffffffff) Version: 18.3.6 Accelerated: no Video memory: 999MB Unified memory: no Preferred profile: core (0x1) Max core profile version: 3.3 Max compat profile version: 3.1 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.0 OpenGL vendor string: VMware, Inc. OpenGL renderer string: llvmpipe (LLVM 7.0, 128 bits) OpenGL core profile version string: 3.3 (Core Profile) Mesa 18.3.6 OpenGL core profile shading language version string: 3.30 OpenGL core profile context flags: (none) OpenGL core profile profile mask: core profile OpenGL version string: 3.1 Mesa 18.3.6 OpenGL shading language version string: 1.40 OpenGL context flags: (none) OpenGL ES profile version string: OpenGL ES 3.0 Mesa 18.3.6 OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00 How can I have hardware acceleration on Lima? Is it possible?
Werner Posted August 4, 2021 Posted August 4, 2021 Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs). With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported. Your report is invalid for one or more of the following reasons (non-exhaustive list): it is for an unsupported board or image (CSC/EOS/WIP/edge) it is for software that is not supported (such as userspace modules installed on top of the core operating system) it has been logged in the wrong forum (for example requests for help that are not actual bug reports) it lacks requested data (armbianmonitor output) it could have been easily solved by a quick search and/or reading documentation Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
ning Posted August 6, 2021 Posted August 6, 2021 you need at least mesa 20.0, xserver 1.20.13, and correct xorg.conf for lima.
