As far as I can see on odroid wiki for the lcd and fan enabling the links leads to ubuntu files.
I want to install latest armbian for odroid xu4q board and omv5 so I'm wondering if I can use these files or do I need some other files to enable lcd and fan on cloudshell2 + odroid xu4q and armbian?
Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs).  With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported.  Your report is invalid for one or more of the following reasons (non-exhaustive list):
  • it is for an unsupported board or image (CSC/EOS/WIP/edge)
  • it is for software that is not supported (such as userspace modules installed on top of the core operating system)
  • it has been logged in the wrong forum (for example requests for help that are not actual bug reports)
  • it lacks requested data (armbianmonitor output)
  • it could have been easily solved by a quick search and/or reading documentation
Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
Better in Community forums ... yes. tl;dr; If you are using Armbian with stock kernel, then low level settings are the same and that how-to should work. If you use modern kernel, then those things could be different and not yet implemented.
