Bullseye: Automatic upgrade when unstable becomes stable?
Go to solution Solved by Igor,
Hey folks,
I want to set up my banana pi completely new with the Debian Bullseye image on armbian.com. But right now the image is marked as "unstable". Do I have to do the whole setup again when it is marked as "stable" in the near future or does it upgrade automatically (via apt-get)?
Thanks for your support. :)
Bullseye has been declared as supported a few days ago but the website has not been adjusted accordingly  yet I think.
For the moment there are only CLI images available though. Desktops need more work to be done.
  On 9/3/2021 at 10:14 AM, Igor said:
yes.
Expand
I assume this involves updating the `/etc/apt/sources.list` file first and then using `apt-get` commands to do the upgrade, but are we ok in doing this or is it recommended that we start freah with a new install?
Also, will that also work for users (like me) that are running the OS from an external SSD storage instead of the SD card?
Thank you! :)
Expand
No. If you run bullseye simply wait until rootfs updates support status to supported. Things are prepared already: https://github.com/armbian/build/commit/f61f560510b8a4ba012209f27c0b3e44909232ef
  On 9/5/2021 at 9:52 PM, Pedro Lamas said:
Thanks @Werner but in my case I'm still on Buster, so my question was more on upgrading from Buster to Bullseye!
Expand
Unfortunately userspace upgrades like Bionic to Focal or Stretch to Buster have never been officially supported by Armbian due to lack of resources for proper testing. It probably works if you freeze your firmware packages and follow official Ubuntu/Debian guide how to upgrade but if something goes wrong you won't receive help from Armbian.
