Hey guys
Hope everyone doing well
I have a Orange Pi Zero running 21.02.2 Focal and Pi-hole installed.
When I run "sudo apt update" this is the output:
root@PiHoleNapoli:~# sudo apt update
Get:1 http://deb.debian.org/debian stable InRelease [116 kB]
Hit:2 http://mirrors.dotsrc.org/armbian-apt focal InRelease
Hit:3 http://ports.ubuntu.com focal InRelease
Get:4 http://deb.debian.org/debian stable-updates InRelease [39.4 kB]
Get:5 http://ports.ubuntu.com focal-updates InRelease [114 kB]
Ign:6 http://deb.debian.org/debian-security stable/updates InRelease
Err:7 http://deb.debian.org/debian-security stable/updates Release
  404  Not Found [IP: 151.101.86.132 80]
Get:8 http://ports.ubuntu.com focal-backports InRelease [101 kB]
Get:9 http://deb.debian.org/debian stable/main armhf Packages [10.8 MB]
Get:10 http://ports.ubuntu.com focal-updates/universe armhf Packages [883 kB]
Get:11 http://ports.ubuntu.com focal-updates/main armhf Packages [1,040 kB]
Reading package lists... Done
E: The repository 'http://deb.debian.org/debian-security stable/updates Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
N: Repository 'http://deb.debian.org/debian stable InRelease' changed its 'Version' value from '11.0' to '11.1'
Anyone can help to resolve this error ?
Thanks
Offhand, probably not a great idea to mix and match Debian and Ubuntu repositories. You may want to reinstall with the Debian derived Armbian before continuing. There's a very good chance you'll end up with library versioning issues, unless you know what you're doing.
That said, it looks like you put "stable/updates" instead of "stable-updates" in your /etc/apt/sources.list ...
@ismurdegusthe following content are the right sources for focal (no debian url needed for security).
Fill the named 2 files with this content and your update should be safe ;)
deb http://ports.ubuntu.com/ focal main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ focal main restricted universe multiverse
deb http://ports.ubuntu.com/ focal-security main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ focal-security main restricted universe multiverse
deb http://ports.ubuntu.com/ focal-updates main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ focal-updates main restricted universe multiverse
deb http://ports.ubuntu.com/ focal-backports main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ focal-backports main restricted universe multiverse
/etc/apt/sources.list.d/armbian.list
deb http://apt.armbian.com/region/EU/ focal main focal-utils focal-desktop
This will find any debian repository entries on your system. You will need to fix, or remove these files.
$ grep -l debian /etc/apt/sources.list /etc/apt/sources.list.d/*
Best bet is to open these files with a text editor (nano is fairly simple if you're new), and comment any lines that have debian in them with a '#' at the start.
$ sudo nano -w /etc/apt/sources.list.d/my-debian-file
<make your edits>
<hit Control-O, Enter to save>
<hit Control-X to exit>
Hey @tparys thanks you did it!
So I run your command: grep -l debian /etc/apt/sources.list /etc/apt/sources.list.d/*
Edit the list by add # with nano
Save the file
Run again apt update & apt upgrade
No errors!
Thanks a lot for your help!
<make your edits>
You do not even need to do extra saving via ^O since nano will ask if chances should be saved when trying to exit :)
