Zhexue. Posted October 18, 2021 Posted October 18, 2021 Armbianmonitor: http://ix.io/3C9T Hello all, I have a question today regarding ARMBIAN - Linux and the configuration of the ZRAM .... Under the ARMBIAN for RockPI 4 I have a ZRAM for the SWAP and a ZRAM for /var/log. Is it possible that I change this configuration and use the eMMC memory for these two areas? Because the big problem with /var/log is that it is simply too small and thus constantly runs into "ERROR" -> volume full. Thank you very much and I am looking forward to constructive contributions to solve my problem. Kind regards
Werner Posted October 19, 2021 Posted October 19, 2021 Check /etc/default/armbian-zramconfig or whatever the file was called.
Zhexue. Posted October 19, 2021 Author Posted October 19, 2021 Hey Werner, thank you very much for this help. And YES, that was it. In first time, I disable the following 2 Services: * armbian-ramlog.service * armbian-zram-config.service With ONLY disabling the service "armbian-zram-config.service", it was not enough. But now, it is work and I am happy, because one of my system has still shutdown this night while the volume "/var/log" is going to 100%.... Thank you very much for your help... Z. Matthias
