ddrazen Posted March 7, 2017 Posted March 7, 2017 Yes thanks I see partition in minitool partition wizard,but no boot to linux.Tested libreelec,this one boot up.Maybe need files from librelec?And which files?
balbes150 Posted March 7, 2017 Posted March 7, 2017 LE run from external media ? To start Armbian the correct dtb file.
ddrazen Posted March 7, 2017 Posted March 7, 2017 Yes LE runing from sd,when remove card boot to Android.dtb.img from LE ?
balbes150 Posted March 7, 2017 Posted March 7, 2017 Yes. Try to use this file. What image LE are you using ?
ddrazen Posted March 11, 2017 Posted March 11, 2017 I tried debian jessie and got desktop only every 15 second and blank other time,maybe is resolution problem,my monitor have 1280x1024 ?
ddrazen Posted March 11, 2017 Posted March 11, 2017 No black screen,but after some time i see desktop 0,5 second,then black 2-3min then 0.5 desktop and again black screen and so on.I think that the image which I see on the very short desktop
balbes150 Posted March 11, 2017 Posted March 11, 2017 This behavior I meet for the first time. But as the monitor is connected directly with an HDMI cable or an adapter ?
balbes150 Posted March 12, 2017 Posted March 12, 2017 Try connecting to the TV without an adapter. Most likely the reason for the adapter. Perhaps it lacked power.
balbes150 Posted March 24, 2017 Posted March 24, 2017 Image update 5.27 (20170324). Significantly upgraded the kernel. Added support wired network and WiFi. Fixed shutdown function.
ddrazen Posted March 24, 2017 Posted March 24, 2017 Jessie work perfect without adapter on my neighbor tv.Thanks!!
ddrazen Posted March 26, 2017 Posted March 26, 2017 But for me only work this version http://mxqproject.com/files/MXQ-Debian-8/MXQProject-Linux-Desktop/ .
balbes150 Posted March 26, 2017 Posted March 26, 2017 According to the information given, You have not activated multiboot. For a successful launch is a prerequisite.
ddrazen Posted March 26, 2017 Posted March 26, 2017 But when I insert libreelec sd-card, system is not going to android but I see libreelec window with KODI? Is multi-boot activated?
balbes150 Posted March 26, 2017 Posted March 26, 2017 There are several multi-boot options. The old version allows you to run the LE from the SD card, but this option multiboot not able to run or anything else, this version of the multi-boot can only run LE. To start Armbian you need to activate version of the universal multi-boot (files for its activation are part of the image Armbian, you can use the toothpick to upgrade multi-boot with the new version).
balbes150 Posted March 27, 2017 Posted March 27, 2017 Describe the exact steps you perform and the result of these steps.
ddrazen Posted March 29, 2017 Posted March 29, 2017 Formated the SD card to FAT Downloaded two of the file aml_autoscript and aml_autoscript.zip Copied these two files on microsd card 1GB Insert card into TV box (mxq with red line no bluetooth) Started Update&backup app and selected aml_autoscript.zip Pressed update, Box restarted and go back to android.?Simply Nothing. When I start MXQ box in recovery selected aml_autoscript.zip then I got error: Finding update package Opening update package verifyng update package footer is wrong signature verification failed Installation aborted. aml_autoscript and aml_autoscript.zip extracted from Armbian_5.27_S805_Ubuntu_xenial_3.10.33_mate_20170324.img.xz I have now samsung tv full hd.
balbes150 Posted March 29, 2017 Posted March 29, 2017 According to this description. *********************************** Pressed update, Box restarted and go back to android. *********************************** Multiboot you have activated. Write the image to SD card. Add to the root of the first partition (FAT) right the file "dtb.img". On the media there is a directory dtb, here You can find a working version of the dtb file, copy it and rename it.
ddrazen Posted March 29, 2017 Posted March 29, 2017 I have write image to 4gb sd card and copied dtb image for mxq and I have only black screen(no signal)
ddrazen Posted March 29, 2017 Posted March 29, 2017 I 'm wrong.copied dtb of mx201 and ubuntu start to login.thank you for help.what is password and user?
Matthew Hodgson Posted April 8, 2017 Posted April 8, 2017 Ok so here's my exact steps - I still think I am missing a step This is for Balbes150 latest armbian release for the MXQ S805 Write image to SD card using Win32disk Open SD card and drop DTB file from the DTB folders provided, onto root of SD card, rename dtb files 'meson8b-hd180.dtb' to dtb.img' Place SD card into MXQ and toothpick to start the initial boot Nothing happens 'waited 5-10 mins' also tried various other DTB files that are available Any input would be greatly received Many thanks for your hard work on this
