mkultra Posted November 8, 2021 Posted November 8, 2021 according to here 5.13 is latest kernel https://www.armbian.com/odroid-c2/ but when I issue: sudo apt-get update && sudo apt-get dist-upgrade -y I'm still on 5.10....
Werner Posted November 8, 2021 Posted November 8, 2021 Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs). With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported. Your report is invalid for one or more of the following reasons (non-exhaustive list): it is for an unsupported board or image (CSC/EOS/WIP/edge) it is for software that is not supported (such as userspace modules installed on top of the core operating system) it has been logged in the wrong forum (for example requests for help that are not actual bug reports) it lacks requested data (armbianmonitor output) it could have been easily solved by a quick search and/or reading documentation Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as P2P Help or Off-Topic)
NicoD Posted November 8, 2021 Posted November 8, 2021 That is not how a kernel upgrade works. The kernel 5.10 is a supported LTS kernel. Kernel 5.13 is experimental and unsupported. It might be possible to switch kernel with armbian-config->other This might lead to to problems, so it is not adviced to do so. Things just brake when you want to use the latest bleeding egde software.
