repository issues (armbian buster 4.19 OS)
I already had armbian buster installed on my nanopi neo core, i recently tried to update and upgrade but here is what m getting:
root@nanopineo:~# apt update
Get:1 http://security.debian.org buster/updates InRelease [65.4 kB]
Get:2 http://httpredir.debian.org/debian buster InRelease [122 kB]
Get:3 http://httpredir.debian.org/debian buster-updates InRelease [51.9 kB]
Hit:5 http://httpredir.debian.org/debian buster-backports InRelease
E: Repository 'http://security.debian.org buster/updates InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
Do you want to accept these changes and continue updating from this repository? [y/N]
the armbian buster image is about 2 years old, 4.19
so should i go for the newer images such as focal? or what should i do?
anw when i press Y, then i upgrade. if i rebooted the image then the nanopi is dead. i can not access it anymore as if it is not even booting (i can tell from the BLUE LED which no more blinks)
  • sami changed the title to repository issues (armbian buster 4.19 OS)
Hook up a serial console to get an idea what is happening inside after upgrade.
4 hours ago, sami said:
focal
Userspace and kernel package are independent. All flavors (Focal, Buster, Bullseye, Hirsute...) of each board share the very same kernel package.
If you do not have a serial console and want to continue using this board you can do that or use armbian-config to freeze firmware packages. This will update userspace (so Buster) packages only.
I tried things from the beginning now it is not even updating!!!!
Err:1 http://httpredir.debian.org/debian buster InRelease
  Could not resolve 'httpredir.debian.org'
Err:2 http://security.debian.org buster/updates InRelease
  Could not resolve 'security.debian.org'
Err:3 http://apt.armbian.com buster InRelease
  Could not resolve 'apt.armbian.com'
Err:4 http://httpredir.debian.org/debian buster-updates InRelease
Err:5 http://httpredir.debian.org/debian buster-backports InRelease
Reading package lists... Done
Building dependency tree
1 package can be upgraded. Run 'apt list --upgradable' to see it.
W: Failed to fetch http://httpredir.debian.org/debian/dists/buster/InRelease  Could not resolve 'httpredir.debian.org'
W: Failed to fetch http://httpredir.debian.org/debian/dists/buster-updates/InRelease  Could not resolve 'httpredir.debian.org'
W: Failed to fetch http://httpredir.debian.org/debian/dists/buster-backports/InRelease  Could not resolve 'httpredir.debian.org'
W: Failed to fetch http://security.debian.org/dists/buster/updates/InRelease  Could not resolve 'security.debian.org'
W: Failed to fetch http://apt.armbian.com/dists/buster/InRelease  Could not resolve 'apt.armbian.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Fix your DNS settings. As you can see names are not resolving.
