RagnerBG Posted September 4, 2016 Posted September 4, 2016 Hello, i have some troubles with analog out of my Orange Pi PC. I thought i have the right cable which is assembled similar to this way: or more like this: But i almost break my device plugin it. This what have to be right channel (red) and pin 2 in the first picture, is shorted with pin 1 to GND when plugged. This confuse me a little, because the other way have to be similar to this: So before i resolder it this way, if anyone knows the correct order of jack pins, or have the right cable and can measure it, please let me know.
zador.blood.stained Posted September 5, 2016 Posted September 5, 2016 Both the schematic and multimeter test with solderable TRRS jack confirm that sleeve (pin 1 from first picture) is the ground and first ring (pin 2 from first picture) should be video signal, so you need to have the first configuration (1 = ground, 2 = video, 3 = right, 4 = left) I have the cable from WD TV Live set-top box, and it uses compatible configuration (1 = common ground, 2 = right, 3 = left, 4 = video signal), if you don't count wrong connector colors.
RagnerBG Posted September 5, 2016 Author Posted September 5, 2016 Thank you for your answer. It's appears my multimeter low battery is causing strange measurements . So you are right, this is the correct order and looks like i have the correct cable. I guess, i've made some major stupidity to use video out as one of audio channels. One of those days .
olivluca Posted September 9, 2017 Posted September 9, 2017 If I plug a stereo jack (hence bridging the video signal to ground), do I risk breaking the video output? In fact, I have already done it, I don't plan to use the analog video but, who knows, maybe I'll need it later.
martinayotte Posted September 9, 2017 Posted September 9, 2017 Yes, shorting video could damage it ! You're better to solder wire to an external jack.
olivluca Posted September 9, 2017 Posted September 9, 2017 Thank you. Oh, well, the damage is done already.
