noisyislands Posted January 16, 2022 Posted January 16, 2022 Hello everyone! I bought Khadas VIM1 board and Official FAN(Ali Link) but seems to be not working with Armbian Bullseye, how I can run it? Thanks. 0 Quote
Igor Posted January 16, 2022 Posted January 16, 2022 On 1/16/2022 at 11:26 AM, noisyislands said: I bought Khadas VIM1 board Expand Which revision of board you have? https://www.armbian.com/khadas-vim1/ To be able to boot Armbian SD card image and ... 0 Quote
ning Posted January 16, 2022 Posted January 16, 2022 @noisyislands have you tried start fan manually by sysfs interface. by default fan will be start at cpu temp 85C 0 Quote
noisyislands Posted January 17, 2022 Author Posted January 17, 2022 On 1/16/2022 at 3:44 PM, Igor said: Which revision of board you have? https://www.armbian.com/khadas-vim1/ To be able to boot Armbian SD card image and ... Expand It is 1.4 Revision Version On 1/16/2022 at 11:11 PM, ning said: @noisyislands have you tried start fan manually by sysfs interface. by default fan will be start at cpu temp 85C Expand Oh, 85C it's to much. I don't sure is it here ls /sys/fs/cgroup cgroup.controllers cgroup.procs cgroup.threads cpu.stat init.scope memory.stat sys-kernel-config.mount user.slice cgroup.max.depth cgroup.stat cpuset.cpus.effective dev-hugepages.mount io.stat proc-sys-fs-binfmt_misc.mount sys-kernel-debug.mount cgroup.max.descendants cgroup.subtree_control cpuset.mems.effective dev-mqueue.mount memory.numa_stat sys-fs-fuse-connections.mount system.slice ls /sys/class backlight chromeos drm hidraw ieee80211 mdio_bus net ptp rtc sas_phy sound tpm vc wakeup bdi devcoredump extcon hnae input mem pci_bus pwm sas_device sas_port spi_master tpmrm vfio watchdog block devfreq firmware hwmon iommu misc phy rc sas_end_device scsi_device spi_slave tty video4linux zram-control bluetooth devlink gpio i2c-adapter leds mmc_host power_supply regulator sas_expander scsi_disk tee udc virtio-ports bsg dma graphics i2c-dev lirc mtd pps rfkill sas_host scsi_host thermal usb_role vtconsole Sorry for the late response, I am able to post here only once per 24h UPDI've found thermal devices and their current state is 0, how can I configure it? ls /sys/class/thermal/ cooling_device0 cooling_device1 thermal_zone0 0 Quote
Igor Posted January 17, 2022 Posted January 17, 2022 On 1/17/2022 at 12:14 PM, noisyislands said: It is 1.4 Revision Version Expand This revision we have in our smoke test rig. Check once again and proceed with steps written on Khadas VIM1 download pages (i reflash my VIM1 to eMMC yesterday). Also try alternative method by downloading Krescue (for VIM1) and removing eMMC content similar as described here. On 1/17/2022 at 12:14 PM, noisyislands said: Sorry for the late response, I am able to post here only once per 24h Expand We are forced to limit speed of end users questions, because our ability to support is extremely limited.This way you can unlock it at once and help a bit. 0 Quote
noisyislands Posted January 17, 2022 Author Posted January 17, 2022 On 1/17/2022 at 12:29 PM, Igor said: This revision we have in our smoke test rig. Check once again and proceed with steps written on Khadas VIM1 download pages (i reflash my VIM1 to eMMC yesterday). Also try alternative method by downloading Krescue (for VIM1) and removing eMMC content similar as described here. We are forced to limit speed of end users questions, because our ability to support is extremely limited.This way you can unlock it at once and help a bit. Expand I've installed Armbian from SD card to eMMC. Seems to be my Fan not working(Fan hardware issue) or thermal configuration sets is too high-temperature level(85C as ning says) 0 Quote
devhell Posted April 20, 2022 Posted April 20, 2022 @noisyislands I found this script for fan control https://github.com/hyphop/khadas-utils/blob/master/utils/fan 1 Quote
noisyislands Posted January 6, 2023 Author Posted January 6, 2023 @devhell Thank you, I've copy this script and it's working! 0 Quote
