Ireng Posted August 24, 2015 Posted August 24, 2015 Hi igor, when are you going to release the next version (4.1.15) of your debian based image? I wait for it to be able to set up the testing server soon for a new system. Thanks in advance for your contributions and for your efforts Best regards, ireng
Igor Posted August 24, 2015 Posted August 24, 2015 Images are done. The rest is manual work: uploading, writing release info, populating repository. Today / tomorrow. Naming is changed - check http://mirror.igorpecovnik.com.. maybe the image you are looking for is already mirrored. Otherwise wait an hour or so.
Ireng Posted August 24, 2015 Author Posted August 24, 2015 Hi Igor. many thanks for your reply and support! I'll chek it out! regards, Ireng
Ireng Posted August 25, 2015 Author Posted August 25, 2015 Hi igor, this morning I installed Linux cubie5 4.1.6-sunxi #20 SMP Mon Aug 24 09:27:58 CEST 2015 armv7l GNU/Linux on one of my Cubietrucks and the image booted flawless, no problems with the LCD screen, everything was visible and clear. After making my adjustments, i compiled & installed the 8812 - driver for the ALFA AWUSC036AC USB adapter, adjusted my hostapd and network configuration and everything is working fine in that sense, that the 5 GHZ wifi network is visible an no error messages from the start of hostapd! 3 thumbs Up, Igor ! Very Nice Work of the image! I can't access the new 5 GHZ wireless network only, because my password (double, triple and quadruple checked is always refused with the message: password incorrect, at this time! Best regards, Ireng
Igor Posted August 25, 2015 Posted August 25, 2015 Thanks! There is also one tiny bug which is not important but it might affect future updates - in all images . Need to rebuild and upload which takes the whole day This is a fix for Cubietruck. Will be when I reupload everything. # first check if you can install a proper one. apt-get install linux-$(lsb_release -cs)-root-next-cubietruck # if / when you can download it, remove the old file dpkg -r linux-$(lsb_release -cs)-root-cubietruck I can't access the new 5 GHZ wireless network only, because my password (double, triple and quadruple checked is always refused with the message: password incorrect, at this time! You are using development driver. OK, it's also the only operational
Ireng Posted August 25, 2015 Author Posted August 25, 2015 Hi Igor, thanks for your advice! apt-get install linux-$(lsb_release -cs)-root-next-cubietruckReading package lists... DoneBuilding dependency tree Reading state information... DoneE: Unable to locate package linux-jessie-root-next-cubietruck That is the result from the install! (with standard sources.list) Regards, Ireng
Igor Posted August 25, 2015 Posted August 25, 2015 I haven't wrote clearly. Sorry. Will be when I reupload everything. That means in a day or two I need to rebuild all packets and repository.
Ireng Posted August 25, 2015 Author Posted August 25, 2015 Ok, thanks for your answer! I can wait! :-) Just let me know whenever you're ready! Still trying to access my 5GHz wifi network ! Unfortunately unsuccessful! reagrds, hitam4450
Ireng Posted August 30, 2015 Author Posted August 30, 2015 Hi Igor! is there any tentative schedule for the release of the next DEBIAN - Cubietruck Image?? Have a nice sunday! regards, Hitam
Ireng Posted September 4, 2015 Author Posted September 4, 2015 Again, Igor!! When are you going to release the next updated image of your nice distribution?? regards, Ireng
cibomato Posted September 6, 2015 Posted September 6, 2015 Hey man, keep cool! Or did you pay thousands of dollars for an 24*7 5hr-response-time platinum support? Then go ahead. Think, we are all appreciating the very great work, Igor is doing here! And since we're not paying for it (I have spent via paypal, have you?), we will just have to wait, until things are ready. No harm meant! cibomato
Ireng Posted September 6, 2015 Author Posted September 6, 2015 @ciboamto:you're suppose to keep cool - very cool! I just gently asked about a possible realse date! Regards, Ireng
cibomato Posted September 6, 2015 Posted September 6, 2015 Don't know what's gently with "Again, Igor!!" but maybe I got this wrong, then sorry! Regards, cibomato
Ireng Posted September 6, 2015 Author Posted September 6, 2015 After a cpuple of days, it was just a reminder! It's Ok now!
Igor Posted September 6, 2015 Posted September 6, 2015 I don't see in the future Soon. There is absolutely no need - no major difference for our boards or bugs fixed. For those who are inpatient or wants to learn and explore, there is a build script / development area. I think I am already building things too fast. Doing thing to fast brings more problems and also takes the joy away. I promise some automatic beta builds, but I never said when. Still thinking what would be the best way. Usually is better to thing many times trough the process before doing it.And, I have a family which I shouldn't neglect Thank you for your patience.
Ireng Posted September 6, 2015 Author Posted September 6, 2015 Igor, no problem at all ! We are all patient and can wait.! It was just a question only! I certainly will get into building images on my own in the near future! I do run UBUNTU 14.04LTS Desktop edition (with all the latest updates) and i can free up to 100 GB on a seperate partiiton for development. The only thing I need to know, what addition packages from UBUNTU are required to compile your nicely prepared images on my on! Many thanks in advance & and a nice, relaxing *family sunday! regads, Ireng
tkaiser Posted September 6, 2015 Posted September 6, 2015 The only thing I need to know, what addition packages from UBUNTU are required to compile your nicely prepared images on my on! It's just git since all the other requirements get installed in the build process. It's that easy, just follow these steps somewhere with 20 GB free -- see https://github.com/igorpecovnik/lib apt-get -y install git git clone https://github.com/igorpecovnik/lib cp lib/compile.sh . chmod +x compile.sh ./compile.sh
Ireng Posted September 6, 2015 Author Posted September 6, 2015 @tkaiser: Thanks for your kind answer and your info. I did not ask about the packages to be compiled, i want to know about the additional requirements for cross-compiling armhf software on a X86 machine! regards, Ireng
tkaiser Posted September 6, 2015 Posted September 6, 2015 i want to know about the additional requirements for cross-compiling armhf software on a X86 machine! It's already answered. Over and out (since Igor made it so unbelievable easy to 'just do it' that any more words are just a waste of time)
Ireng Posted September 6, 2015 Author Posted September 6, 2015 Oki, thanks again, I'll try it ! Regards, hitam4450
