Ukhellfire Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 2:59 PM, sekil said: Not booting! Try using stock uboot for orange pi 3 - i'm think you adding some bugs with your uboot patches or maybe build system have bugs.. after writing image to sd card - i'm cant see any partitions besides fat - Environment size: 4621/131068 bytes => mmc part Partition Map for MMC device 0 -- Partition Type: DOS Part Start Sector Num Sectors UUID Type 1 8192 2039808 aa174f31-01 83 But from your configs - need using partition 2! Expand Basically start again! Lol! OK I'll do that. Thing is though, the dts file I'm using, is the same as the opi3 one. But I'll give it a go. I added a couple of bits into the bootargs, but other than that, opi3 and opi3lts dts file are the same! They are both exactly the same on orangepi repo too. I think think it may be a build issue to be honest. Not sure though... 0 Quote
sekil Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 3:28 PM, Ukhellfire said: Basically start again! Lol! OK I'll do that. Thing is though, the dts file I'm using, is the same as the opi3 one. But I'll give it a go. I added a couple of bits into the bootargs, but other than that, opi3 and opi3lts dts file are the same! They are both exactly the same on orangepi repo too. I think think it may be a build issue to be honest. Not sure though... Expand Ok. Need trying build clean opi3 image and test on stock build system. 0 Quote
Ukhellfire Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 3:36 PM, sekil said: Ok. Need trying build clean opi3 image and test on stock build system. Expand I'll do that when I get home. So basically just build for opi3, and boot that. Then if it works, start porting that across to opi3-lts? Which is what I was going to do. Then decided to use orangepis files from their repos instead. Damn. Wish I'd done it from the beginning now! And ill run without any userpatches what so ever? Just armbians stock patches? Run on every build? How long you available for testing? 0 Quote
sekil Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 3:38 PM, Ukhellfire said: How long you available for testing? Expand i'm forever 😁 0 Quote
Ukhellfire Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 7:44 PM, sekil said: i'm forever 😁 Expand well ive just booted it... the op13 image. ive taken a dmesg, now just about to get it off the card and upload it! pretty sure i saw regulator issues? 0 Quote
sekil Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 7:45 PM, Ukhellfire said: well ive just booted it... the op13 image. ive taken a dmesg, now just about to get it off the card and upload it! pretty sure i saw regulator issues? Expand Im build clean opi3 image - not booting too! Buggy armbian - what more can I say.. Uart disabled for debugging, uart console with bugs - when typing, letters appear with a delay and not all are printed - the current state is terrible for opi3 - who maintain this?? strange.. to be honest - orange pi build works perfectly in this regard )) 0 Quote
Ukhellfire Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 7:52 PM, sekil said: Im build clean opi3 image - not booting too! Buggy armbian - what more can I say.. Uart disabled for debugging, uart console with bugs - when typing, letters appear with a delay and not all are printed - the current state is terrible for opi3 - who maintain this?? strange.. Expand i dont know who maintains it? heres the dmesg i was able to get. https://drive.google.com/file/d/1GHGrtHVZzMLQ0o1h_B7US2EB40pTL-OU/view?usp=sharing Im pretty certain its nothing were doing wrong. like you said, i think its just buggy. im wondering if porting a different device would work? dont think anything else is similar though. and im pretty certain its about the regulator banks. its the same error every image we try... vcc-pc-supply & vcc-pd-supply, and not finding vcc-pf-supply. vcc-pf isnt even needed for this board! its not listed in allwinners datasheets or anything! As you can see my vcc-pc and vcc-pd regulators are found and seen! But the at the bottom its throws a regulator not found vcc-pf. I don't think that's even defined for h6! It's pulling something else from config wise from somewhere else... 0 Quote
sekil Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 7:54 PM, Ukhellfire said: Im pretty certain its nothing were doing wrong. like you said, i think its just buggy. im wondering if porting a different device would work? dont think anything else is similar though. and im pretty certain its about the regulator banks. its the same error every image we try... vcc-pc-supply & vcc-pd-supply, and not finding vcc-pf-supply. vcc-pf isnt even needed for this board! its not listed in allwinners datasheets or anything! Expand For me image wont booting - stay in initramfs - without any message on uart - only in hdmi lcd.. error related to rootfs not found... but uboot loading from ext4 partition script and runing - strange what kernel want)) Need enable uart and i'm trying debug this - maybe yes some regulator not enabling mmc devices and kernel not finded rootfs.. 0 Quote
Topor Posted March 28, 2022 Posted March 28, 2022 (edited) I checked on my device and I need a password. I think it's working fine. what else can I do to help? Edited March 28, 2022 by Topor translation 0 Quote
Ukhellfire Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 8:05 PM, sekil said: For me image wont booting - stay in initramfs - without any message on uart - only in hdmi lcd.. error related to rootfs not found... but uboot loading from ext4 partition script and runing - strange what kernel want)) Expand This is what makes me think it's possibly voltage related. Don't know if this is possible. But I seem to be getting further than anyone else. And that's the only thing that's different. Although saying that, the orangepi image works, but armbian doesn't. It has to be an armbian codebase issue. I wonder if it's a "build" issue rather than a uboot/kernel issue? 🤔 0 Quote
sekil Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 8:19 PM, Ukhellfire said: I wonder if it's a "build" issue rather than a uboot/kernel issue? 🤔 Expand Need logs from kernel but i'm dont see this - need enable early console 0 Quote
Ukhellfire Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 8:27 PM, sekil said: Need logs from kernel but i'm dont see this - need enable early console Expand How do I do that? Early printtk? 0 Quote
sekil Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 8:36 PM, Ukhellfire said: How do I do that? Early printtk? Expand Need edit boot.scr script - https://github.com/armbian/build/blob/master/config/bootscripts/boot-sunxi.cmd change Цитата setenv earlycon "off" Expand to Цитата setenv earlycon "on" Expand And you see debug messages for kernel booting 0 Quote
Ukhellfire Posted March 28, 2022 Posted March 28, 2022 On 3/28/2022 at 9:18 PM, sekil said: Need edit boot.scr script - https://github.com/armbian/build/blob/master/config/bootscripts/boot-sunxi.cmd change to And you see debug messages for kernel booting Expand oh ok thank you! ill do this and get back to you... On 3/28/2022 at 9:18 PM, sekil said: Need edit boot.scr script - https://github.com/armbian/build/blob/master/config/bootscripts/boot-sunxi.cmd change to And you see debug messages for kernel booting Expand Found this: https://github.com/armbian/build/commit/6a5363370318c15c25bdee534a61672e6d9ca304 Now orange pi have removed half of this patch. And the commit lightly touches on exactly what we're seeing the the regulators issues... 0 Quote
Ukhellfire Posted March 29, 2022 Posted March 29, 2022 On 3/28/2022 at 8:17 PM, Topor said: I checked on my device and I need a password. I think it's working fine. what else can I do to help? Expand It should be asking you to set a root password? This is the armbian setup at the beginning, before you log in... 0 Quote
Ukhellfire Posted March 29, 2022 Posted March 29, 2022 On 3/28/2022 at 9:18 PM, sekil said: setenv earlycon "on" Expand So I've done another build for the opi3 lts, done with early console turned on, and one for the opi3. I will try booting these shortly, maybe tonight. Been a bit tight on time last night and tonight. I've uploaded the opi3-lts one here: https://drive.google.com/file/d/1s7BKzNnWFvrHC35w4oORbrkzmeos7jkl/view?usp=drivesdk Just incase anyone wants to try it. It's had that patch mentioned above removed. I have no idea if it's even going to do anything. I haven't tested yet. I doubt it though. As soon as I burn it to card and boot it, I'll post up logs and everything too. We will get to the bottom of this! Haha! 0 Quote
sekil Posted March 29, 2022 Posted March 29, 2022 I'm enable early console - but this not helping to showing messages when booting on lcd or uart (( Good news - i'm test new build from orangepi build with latest 5.16 kernel - all working and internal sound card!!!! 0 Quote
Ukhellfire Posted March 29, 2022 Posted March 29, 2022 On 3/29/2022 at 9:14 PM, sekil said: I'm enable early console - but this not helping to showing messages when booting on lcd or uart (( Good news - i'm test new build from orangepi build with latest 5.16 kernel - all working and internal sound card!!!! Expand Ah well ill stop where I am then! Haha! I think I'll build that to be honest. And then in the background keep trying out armbian. I'm just annoyed it turned into such a task! Theoretically it should be fairly straightforward. I bet any money it's one tiny line somewhere that needs changing. I can feel it! Haha! Might have to buy a second board in the near future just for developing! Haha! 0 Quote
Ukhellfire Posted March 31, 2022 Posted March 31, 2022 So apparently stopping isn't in my remit. I've been thinking/playing uboot. I want to experiment... If anyone would be so kind to help me? @sekil @Kamileon @orangepifan @Rockford the Roe?? Basically I'm compiling 2 different images. One with orangepis stock uboot, and armbians kernel etc. Then I'll be compiling a second one, with armbians uboot, and orangepis 5.16 kernel and armbian. This way I will be able to narrow down to whether this is actually a uboot or a kernel issue. My money is on uboot... But you never know... Anyway, here's the link for the first image. This has armbians kernel, with orangepis uboot. https://drive.google.com/file/d/1NAFxJAj9CgHNkrPICbQIKsLXZhutQbCo/view?usp=drivesdk Thanks in advance guys! Look forward to the feedback! 0 Quote
sekil Posted April 1, 2022 Posted April 1, 2022 I'm success debug this - Need edit config/bootscripts/boot-sun50i-next.cmd (previos i'm edit wrong other sunxi script) - change setenv verbosity "1" to setenv verbosity "9" Problem in kernel - axp806 chip not starting with r_rsb - need change to r_i2c! [ 1.847585] sunxi-rsb 7083000.rsb: RSB running at 3000000 Hz [ 1.847942] axp20x-rsb sunxi-rsb-745: AXP20x variant AXP806 found [ 1.848401] axp20x-rsb sunxi-rsb-745: Failed to set masks in 0x40: -5 [ 1.848427] axp20x-rsb sunxi-rsb-745: failed to add irq chip: -5 [ 1.848444] axp20x-rsb: probe of sunxi-rsb-745 failed with error -5 0 Quote
Kamileon Posted April 1, 2022 Posted April 1, 2022 On 3/31/2022 at 9:55 PM, Ukhellfire said: Anyway, here's the link for the first image. This has armbians kernel, with orangepis uboot. https://drive.google.com/file/d/1NAFxJAj9CgHNkrPICbQIKsLXZhutQbCo/view?usp=drivesdk Expand Still same result as before, drop to initram, in dmesg same pin problems 0 Quote
Ukhellfire Posted April 1, 2022 Posted April 1, 2022 On 4/1/2022 at 4:34 AM, sekil said: I'm success debug this - Need edit config/bootscripts/boot-sun50i-next.cmd (previos i'm edit wrong other sunxi script) - change setenv verbosity "1" to setenv verbosity "9" Problem in kernel - axp806 chip not starting with r_rsb - need change to r_i2c! [ 1.847585] sunxi-rsb 7083000.rsb: RSB running at 3000000 Hz [ 1.847942] axp20x-rsb sunxi-rsb-745: AXP20x variant AXP806 found [ 1.848401] axp20x-rsb sunxi-rsb-745: Failed to set masks in 0x40: -5 [ 1.848427] axp20x-rsb sunxi-rsb-745: failed to add irq chip: -5 [ 1.848444] axp20x-rsb: probe of sunxi-rsb-745 failed with error -5 Expand Was this using the image I just uploaded with orangepi uboot? Or was this one you built? On 4/1/2022 at 5:57 AM, Kamileon said: Still same result as before, drop to initram, in dmesg same pin problems Expand This is good! It means we're getting somewhere, it means uboot makes no difference. Possibly kernel then! 0 Quote
sekil Posted April 1, 2022 Posted April 1, 2022 On 4/1/2022 at 6:18 AM, Ukhellfire said: Was this using the image I just uploaded with orangepi uboot? Or was this one you built? Expand This with my clean armbian build.. Current i'm build new image with r_i2c changes in dts and try again.. 0 Quote
Ukhellfire Posted April 1, 2022 Posted April 1, 2022 On 4/1/2022 at 6:21 AM, sekil said: This with my clean armbian build.. Current i'm build new image with r_i2c changes in dts and try again.. Expand Ah OK! Would be interesting to see your results! If this is stock armbian, rsb should work! Do you have repos for your configs? Or is it all local? 0 Quote
sekil Posted April 1, 2022 Posted April 1, 2022 On 4/1/2022 at 6:25 AM, Ukhellfire said: Ah OK! Would be interesting to see your results! If this is stock armbian, rsb should work! Do you have repos for your configs? Or is it all local? Expand I'm dont have time to make my very quick changes to git or.. Should work? i'm on stock armbian - not working - why you think that on lts version rsb should work? For me i'm have problems with rsb with Glodroid kernel and uboot - i'm change to r_i2c and this gone.. 0 Quote
Ukhellfire Posted April 1, 2022 Posted April 1, 2022 On 4/1/2022 at 6:33 AM, sekil said: I'm dont have time to make my very quick changes to git or.. Should work? i'm on stock armbian - not working - why you think that on lts version rsb should work? For me i'm have problems with rsb with Glodroid kernel and uboot - i'm change to r_i2c and this gone.. Expand Because other boards use it, and orangepi moved it rsb when they released their 5.16 kernel didn't they? No they didn't! I take that back! Apologies! Well well well... ironically, if you read back on this thread, that's exactly what I suggested originally. But got told it wouldn't make any difference! 0 Quote
sekil Posted April 1, 2022 Posted April 1, 2022 On 4/1/2022 at 6:43 AM, Ukhellfire said: Because other boards use it, and orangepi moved it rsb when they released their 5.16 kernel didn't they? Expand 5.16 using r_i2c for axp chip in LTS version only! - i'm think this is beacuse maybe bug in HW schematic for LTS or something else.. but need using r_i2c! 0 Quote
Ukhellfire Posted April 1, 2022 Posted April 1, 2022 On 4/1/2022 at 6:47 AM, sekil said: 5.16 using r_i2c for axp chip in LTS version only! - i'm think this is beacuse maybe bug in HW schematic for LTS or something else.. but need using r_i2c! Expand Well I guess I'll be making some changes! Although I need to check, I think I didn't change this when I re-imported! Nope. I'm using rsb. Re-re-re-import here I come! Haha! Thanks for the heads up! That makes perfect sense to the fact that it wouldn't find the defined regulator banks properly! 0 Quote
sekil Posted April 1, 2022 Posted April 1, 2022 On 4/1/2022 at 6:49 AM, Ukhellfire said: Well I guess I'll be making some changes! Although I need to check, I think I didn't change this when I re-imported! Expand Please say - how make patches for only my changes (and later place this patches to uaserpatches) - now i'm make many changes to compilation scripts to disable cleaning kernel sources and so on - very very bad idea.. And armbian build system very very slow (( UPD: Ok - i'm make patches - this simple :) 1 Quote
