32 minutes ago, sekil said:
Totally fixed with one patch! For r_i2c 😄
No way!!! So moving over to i2c fixed the boot completely??? That's it?
Well I guess I'll get a build going and upload everything!
Get some tests going!
Только что, Ukhellfire сказал:
Yes without axp chip - regulators not working - many devices not working - enable debugging - this is first stage what you loose..
Without - this is finger to the sky :)
Oh I will be! Thank you!
Finally getting somewhere! Maybe I can push to armbian at some point soon!
3 минуты назад, Ukhellfire сказал:
Yes please push all needed commits to armbian for lts version:
1. uwe5622
2. r_i2c
3. ac200 audio codec
4. yt8531c
5. sunxi-addr driver
6. dump_reg and sunxi-sysinfo drivers
7. sunxi_get_soc_chipid() and sunxi_get_serial
But while testing linux with 5.16 orangepi kernel - xfce and mate desktops crashing related to panfrost driver (((
Maybe lxde better for panfrost..
1. uwe5622
2. r_i2c
4. yt8531c
I believe there is a workaround for panfrost. I'll look I to this... is it the constant error your getting? Looping?
https://github.com/orangepi-xunlong/u-boot-orangepi/commit/11f8b71080f8311264ec7098f0be7c0b9ea459b7
Not sure if this is the right fix?
I'll be tidying my repos up, and pushing all the commits once I've had a few people confirm it boots etc...
I'm running a build now with all my patches, and the i2c config. Without panfrost though 😞
17 минут назад, Ukhellfire сказал:
Maybe this right fix for some bugs but this for h616 chip...
Yeah it is. Bur surely it can be adapted? I'll see what errors I gey get when I boot it up in a couple of hours...
Never - h616 have different gpu different cpu regs and different bugs - so no...
Errors -
[  121.584328] panfrost 1800000.gpu: js fault, js=0, status=INSTR_INVALID_PC, head=0x715ec00, tail=0x715ec00
[  121.635491] panfrost 1800000.gpu: js fault, js=0, status=INSTR_INVALID_PC, head=0x715de00, tail=0x715de00
[  121.637797] panfrost 1800000.gpu: js fault, js=0, status=INSTR_INVALID_PC, head=0x71724c0, tail=0x71724c0
[  181.666563] panfrost 1800000.gpu: js fault, js=0, status=INSTR_INVALID_PC, head=0x7171280, tail=0x7171280
[  181.687731] panfrost 1800000.gpu: js fault, js=0, status=INSTR_INVALID_PC, head=0x7173bc0, tail=0x7173bc0
[  241.728792] panfrost 1800000.gpu: js fault, js=0, status=INSTR_INVALID_PC, head=0x7172900, tail=0x7172900
[  241.744175] panfrost 1800000.gpu: js fault, js=0, status=INSTR_INVALID_PC, head=0x711f8c0, tail=0x711f8c0
[  241.750813] panfrost 1800000.gpu: js fault, js=0, status=INSTR_INVALID_PC, head=0x7172f00, tail=0x7172f00
4 hours ago, amaethon said:
It works! Nice work. Ethernet and wifi work. Only tested for a few minutes but no problems at this point.
Good news! Would be interesting to see if anything arises!
3 hours ago, Rockford the Roe said:
We're finally getting somewhere! Good to see!
59 minutes ago, sekil said:
Yes working desktop, but ac200 codec not working - maybe you loose config in kernel for acx00 chip?
This means it's never been working on my build. It's not something I've tested. Wanted to get it at least booting! Haha! With a stable I ternet connection. Think this is the most important!
There's more configs that I need to ad to the build directory to enable the sound...
I'll get this all merged and run another build off and upload!
I'll keep everyone posted!
Boots on my end also :) Ethernet works
                                 root@orangepi3-lts
      █ █ █ █ █ █ █ █ █ █ █      OS: Armbian (22.05.0-trunk) aarch64
     ███████████████████████     Host: OrangePi 3 LTS
   ▄▄██                   ██▄▄   Kernel: 5.15.32-sunxi64
   ▄▄██    ███████████    ██▄▄   Uptime: 3 mins
   ▄▄██   ██         ██   ██▄▄   Packages: 1315 (dpkg)
   ▄▄██   ██         ██   ██▄▄   Shell: bash 5.0.17
   ▄▄██   ██         ██   ██▄▄   Resolution: 3840x2160
   ▄▄██   █████████████   ██▄▄   Terminal: /dev/pts/0
   ▄▄██   ██         ██   ██▄▄   CPU: (4) @ 1.800GHz
   ▄▄██   ██         ██   ██▄▄   Memory: 172MiB / 1989MiB
                                 root@orangepi3-lts
I'm so glad to be hearing all these positive things! Been a long time coming! Haha!
Well sorry to say guys, but another new build!
This time ( @sekil), hopefully with working sound! Audio jack that is.
Please note, I haven't tested this build myself. Having a bit of a chilled day today with the family. I'll be doing more later tonight and tomorrow!
https://drive.google.com/file/d/1ht9CnWaoTUTx4btbVgFPZrFeiZTVbl3J/view?usp=drivesdk
Once this has been tested, and I can safely say everyone is happy, I'll push my changes to armbian for everyone else to use!
At the moment, I don't think bluetooth is working? It crashes when you try turning it on.
This I believe to be low priority at the moment. But once things are stable, I'll look into these lower end bugs. Very probably just a config issue or something. Never know!
28 минут назад, Ukhellfire сказал:
Im not testing new build but Im think no :(
Im trying with proper kernel config - mfd ac200 running but codec - no.. no logs in dmesg about codec. Very strange ((
What changes you made in new build - only config?
Ironically I've enabled the codec and added a whole load of configs for it! So fingers crossed it's sorted! I only ever just enabled the build for opi3 lts in the build. Only now have I enabled the audio...
Audio from Jack output works for me :) did speaker-test
aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pulse
    PulseAudio Sound Server
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default:CARD=allwinnerac200c
    allwinner,ac200-codec, 508f000.i2s-acx00-dai acx00-codec-0
    Default Audio Device
sysdefault:CARD=allwinnerac200c
dmix:CARD=allwinnerac200c,DEV=0
    Direct sample mixing device
dsnoop:CARD=allwinnerac200c,DEV=0
    Direct sample snooping device
hw:CARD=allwinnerac200c,DEV=0
    Direct hardware device without any conversions
plughw:CARD=allwinnerac200c,DEV=0
    Hardware device with all software conversions
usbstream:CARD=allwinnerac200c
    USB Stream Output
default:CARD=sun9ihdmi
    sun9i-hdmi, SUN9I-HDMI PCM i2s-hifi-0
sysdefault:CARD=sun9ihdmi
dmix:CARD=sun9ihdmi,DEV=0
dsnoop:CARD=sun9ihdmi,DEV=0
hw:CARD=sun9ihdmi,DEV=0
plughw:CARD=sun9ihdmi,DEV=0
usbstream:CARD=sun9ihdmi
    sun9i-hdmi
    USB Stream Output
root@orangepi3-lts:~# speaker-test
speaker-test 1.2.2
Playback device is default
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 256 to 262144
Period size range from 128 to 32768
Using max buffer size 262144
Periods = 4
was set period_size = 32768
was set buffer_size = 262144
 0 - Front Left
Time per period = 2.740674
 0 - Front Left
Time per period = 2.757094
 0 - Front Left
Time per period = 2.740576
2 hours ago, sekil said:
Great! Im install it and using :)
Yes i'm tst and codec working!
Good :)
Good to hear! We got there! Well I guess I'll submit a pull request now then!
Then I'll look into the Bluetooth! It crashes everytime you try turn it on. Haven't looked at logs or anything yet though, so haven't got a clue what's going on!
And at some point, look into the panfrost issue!
DONE!
https://github.com/armbian/build/pull/3628
@Ukhellfire Hi, thanks for your hard work. About bluetooth in orange pi firmware repository they use ini files for bluetooth configuration. But in armbian firmware files I couldn't find that configuration files. Maybe problem it is.
Orange pi firmware: https://github.com/orangepi-xunlong/firmware bt_configure_pskey.ini, bt_configure_rf.ini.
Armbian firmware: https://github.com/armbian/firmware
Also I know orange pi zero 2 using same wifi-bt chip and armbian support orange pi zero2.
But I don't know how to connect these dots because I don't fully understand the firmware logic. Maybe it helps.
And I tested your armbian-build repository with orangepi 3 lts:
Here the dmesg output (I attached full dmesg output.):
$ dmesg | grep "WCN"
[    5.719903] WCN: marlin_init entry!
[    5.720466] WCN: wcn config bt wake host
[    5.720738] WCN_ERR: dts node for bt_wake not found
[    5.720743] WCN: marlin2 parse_dt some para not config
[    5.726542] WCN: marlin_probe ok!
[    5.745541] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0
[    5.866430] WCN: start_marlin [MARLIN_WIFI]
[    5.866455] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
[    5.866462] WCN: the first power on start
[    5.973497] WCN: marlin chip en dummy pull up -- need manually set GPIO
[    6.001836] WCN: marlin_scan_finish!
[    6.001974] WCN: then marlin start to download
[    6.002190] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
[    6.002202] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
[    6.855652] WCN: combin_img 0 marlin_firmware_write finish and successful
[    6.855945] WCN: marlin_start_run read reset reg val:0x1
[    6.855952] WCN: after do marlin_start_run reset reg val:0x0
[    6.856119] WCN: s_marlin_bootup_time=6856119014
[    6.861907] WCN: clock mode: TSX
[    6.862252] WCN: marlin_write_cali_data sync init_state:0x7923f405
[    6.889800] WCN: marlin_write_cali_data sync init_state:0x7923f405
[    6.919142] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
[    6.919173] WCN: sdio_config bt_wake_host trigger:[high]
[    6.919177] WCN: sdio_config irq:[inband]
[    6.919180] WCN: sdio_config wake_host_level_duration_time:[20ms]
[    6.919185] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
[    6.919188] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config)
[    6.919617] WCN: marlin_write_cali_data finish
[    6.919865] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[    6.945833] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[    6.973847] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[    7.002644] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[    7.029731] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[    7.057746] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
[    7.057772] WCN: marlin_bind_verify confuse data: 0xcfe38251b04db73419dc5cae40581e72
[    7.057790] WCN: marlin_bind_verify verify data: 0x1ed7454972563e2294bc7cf590020acc
[    7.058307] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
[    7.085749] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
[    7.092404] WCN: get_cp2_version entry!
[    7.134884] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
[    7.134920] WCN: switch_cp2_log - close entry!
[    7.136147] WCN: WCND at cmd read:OK
[    7.136197] WCN: then marlin download finished and run ok
[    7.136212] WCN: start_loopcheck
[    7.136222] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 0
[    7.136233] WCN: can not power off, other module is on
[    7.169655] WCN: get_board_ant_num [one_ant]
As you can see there is an error about bluetooth.
dmesg.txt
Edited by Eemeien
added last sentence
There's actuslly a second branch for the bt-fix. It is something I'm working on slowly. Didn't notice the config firmware files though! Thank you'll I'll have a play with those!
OK. I will check second repo soon.
I'm currently working on bluetooth, I'll let you know if there's any progress.
Do we need dts change for BT?
We are using stock dts files from orangepi latest 5.16 kernel. But dependant on if it's the same as armbians kernel (nearly identical I think) something may need changing. Shouldn't do though
I do reckon getting them firmware files into place would be the first thing to try. I'll be giving this a go later.
