Alsan Wong Posted September 10, 2016 Posted September 10, 2016 Help please! I have a bp2 which was bought almost a year ago, and use Armbian_5.14_Bananapi_Debian_jessie_3.4.112.raw as the image for couple of months. Today, I'm try to upgrade to the Armbian_5.14_Bananapi_Ubuntu_xenial_4.6.2.raw image, but the pi can't boot at all. What I do to prepare the sdcard with the following procedure: 1. remote the old partitation, and create a new fat32 partitation 2. dd bs=1M if=Armbian_5.14_Bananapi_Ubuntu_xenial_4.6.2.raw of=/dev/sdc; and sync 3. mark the written partitation as bootable with fdisk ps: I'm using fish shell, and the syntax for the dd command is valid So, what's wrong with my steps? How can I troubleshoot? Thanks in advance.
arox Posted September 10, 2016 Posted September 10, 2016 - did you download image for bananapi or bananapim2 ? - why do you create a FAT partition or edit it with fdisk - when you dd in sdc, the partition table is copied as well, so you should have notice that you have no more fat32 partition. So : - verify you got the right image - dd, sync, eject/insert SD and mount /dev/sdc1 to check fs integrity, and dismount - unplug all connector before boot to be sure the card do a full reset
Webe1959 Posted November 8, 2016 Posted November 8, 2016 I am new to this forum and to Armbian. I have a Pcduino 3B and Pcduino V2. The 3B works great with the v5.20 Armbian build. The update to v5.23 worked as well. Video is working very well and is definitely not as dark as on v5.20. Now the V2 is giving me fits. It will not boot at all using the Armbian build. If a wait long enough, it will just boot with the Ubuntu build that is in the onboard memory, usually about 10 minutes. I tried the original Ubuntu 12 and Android builds from LinkSprite and all work correctly. Yes, I followed exactly as the directions provided on your site for downloading and build the SD card. I even tried three different CD cards. All work with other builds but not the Armbian. I use the USB Image formatter and writer utilities on my Linux Mint machine to do all the SD card builds. This is the first time it hasn't worked. I love Armbian and prefer over the LinkSprite. I have resurrected my media player for my camper, and plan to pursue my automated train control system with the other. May buy another Pcduino card if can't get the V2 to run Armbian. Thank you.
Igor Posted November 9, 2016 Posted November 9, 2016 I am new to this forum and to Armbian. I have a Pcduino 3B and Pcduino V2. The 3B works great with the v5.20 Armbian build. The update to v5.23 worked as well. Video is working very well and is definitely not as dark as on v5.20. Now the V2 is giving me fits. It will not boot at all using the Armbian build. If a wait long enough, it will just boot with the Ubuntu build that is in the onboard memory, usually about 10 minutes. I tried the original Ubuntu 12 and Android builds from LinkSprite and all work correctly. Yes, I followed exactly as the directions provided on your site for downloading and build the SD card. I even tried three different CD cards. All work with other builds but not the Armbian. I use the USB Image formatter and writer utilities on my Linux Mint machine to do all the SD card builds. This is the first time it hasn't worked. I love Armbian and prefer over the LinkSprite. I have resurrected my media player for my camper, and plan to pursue my automated train control system with the other. May buy another Pcduino card if can't get the V2 to run Armbian. Thank you. We noticed some problems with recent u-boot on some A10 and A20 boards. Since I don't own this particular board, I can't deal with the problem properly. If you are willing to do few tests, I can provide you test image with some older u-boot (perhaps v2015.10 like on Cubieboard2 ?). If you are able to change it on your own and figure out which (latest) is working well, this would be even better.
Webe1959 Posted December 2, 2016 Posted December 2, 2016 I'll try your tests and report the results. Will be a while though with the holidays coming up.....
Goofy03 Posted December 3, 2016 Posted December 3, 2016 We noticed some problems with recent u-boot on some A10 and A20 boards. Since I don't own this particular board, I can't deal with the problem properly. If you are willing to do few tests, I can provide you test image with some older u-boot (perhaps v2015.10 like on Cubieboard2 ?). If you are able to change it on your own and figure out which (latest) is working well, this would be even better. Hi i try to install Armbian on my pcduino2 too but if i follow the link in your site i get 5.20 version i saw this thread and try to downgrade to 5.14 but always the same black screen of death :-) No problems with LinkSprite bloatwares too … I try to follow your test link but nothing for pcduino2 ? i could test anything you want too and right now because i need an OS for some nodjs server dev … Thanks for your work (Even if i cant see it ) Debian rocks for server …
Igor Posted December 4, 2016 Posted December 4, 2016 Hi i try to install Armbian on my pcduino2 too but if i follow the link in your site i get 5.20 version i saw this thread and try to downgrade to 5.14 but always the same black screen of death :-) No problems with LinkSprite bloatwares too … I try to follow your test link but nothing for pcduino2 ? i could test anything you want too and right now because i need an OS for some nodjs server dev … Thanks for your work (Even if i cant see it ) Debian rocks for server … I added Pcduino 2 to nighty test images. It will be available tomorrow ... please try it and report if it works for you. You are welcome
Goofy03 Posted December 4, 2016 Posted December 4, 2016 Armbian_5.24.161205_Pcduino2_Debian_jessie_3.4.113 : Pro : - is better i see something now Cons: - Screen is corrupt at boot just after the Armbian logo (For server is not a problem) - I get a kernel Panic when i reboot
Igor Posted December 5, 2016 Posted December 5, 2016 Some temporally screen corruption when kernel loads is normal, but you get a login prompt on HDMI console? Please provide some logs, that we can try to solve problems. Does kernel panic means, your board does not reboot or it just panics and reboot? Are you using wireless network? Login as root and type: armbianmonitor -u For server usage it's better to use mainline kernel. Check here how to upgrade: https://www.armbian.com/kernel/
Goofy03 Posted December 5, 2016 Posted December 5, 2016 http://sprunge.us/iOaG It just panic (many times) and reboot Yes i use a wifi usb adapter but i get kernel panic on RJ45 too … I gone try to update …
Igor Posted December 6, 2016 Posted December 6, 2016 My only A10 device, Cubieboard 1, doesn't show any sign of troubles, Try bare board, without anything on USB. If this does not help, there could be some problem with board configuration (script.bin) or simply power related issues, ...
Goofy03 Posted December 7, 2016 Posted December 7, 2016 Hi, i try to upgrade with : linux-u-boot-pcduino2-nextlinux-image-next-sunxi linux-headers-next-sunxilinux-firmware-image-next-sunxilinux-dtb-next-sunxilinux-$(lsb_release -cs)-root-next-pcduino2 And same black screen of death … I Gone chroot now thanks to my nandd
Igor Posted December 7, 2016 Posted December 7, 2016 Hi, i try to upgrade with : linux-u-boot-pcduino2-next linux-image-next-sunxi linux-headers-next-sunxi linux-firmware-image-next-sunxi linux-dtb-next-sunxi linux-$(lsb_release -cs)-root-next-pcduino2 And same black screen of death … I Gone chroot now thanks to my nandd If you still have time and will, I added mainline image to the beta builds, kernel 4.8.12, updated u-boot. Let's see if this works. Check .161207 build.
Goofy03 Posted December 7, 2016 Posted December 7, 2016 Wouhou !! Perfect ! No more glitch on bootscreen. No more kernel Panic on reboot i can really work with my pcduino2 now … Thanks I have a pcduino8 Uno too, if you want me to test something … 1
